HEVO triple kinematic bed configuration
I removed the G29 And still thats whats giving me the error, so im not sure im measuring the probe points right. is it where the physical screws actually are? or where the ball mounts are under the board??
G32
Error: Some computed corrections exceed configured limit of 0.50mm: 0.026 3.362 -1.291config.g
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Nov 30 2021 22:33:03 GMT+0700 (Indochina Time); General preferences
M550 P"300" ; set printer name
M669 K1 ; select CoreXY mode; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet ; Set idle timeout; Drives
M569 P0.3 S0 ; physical drive 0.3 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping
M350 X16 Y16 Z116:16:16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1280.00:1280.00:1280.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00:60:60 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00:180.00:180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00:20.00:20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800:800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Screws
M671 X20:125:230 Y20:300:20 S0.5 ; leadscrews at rear left, front middle and rear right; Axis Limits
M208 X250 Y320 Z480 S0 ; set axis maximabed.g
; bed.g
;G29 ; probe the bed and enable compensationG28 ; home
G30 P0 X20 Y20 Z-99999 ; probe near a leadscrew
G30 P1 X125 Y300 Z-99999 ; probe near a leadscrew
G30 P2 X230 Y20 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors -
Well that is not really an error, more of an informational message.
You have the S parameter in your M671 set to 0.5 which limits the correct for a single pass to 0.5 mm which is not very much. The default value is 1.0.
You see that one of the adjustments required was going to be 3.362.
So as a test change the S parameter to 4.0 and see what happens.
@fcwilt
G32
Leadscrew adjustments made: 0.167 0.270 -0.504, points used 3, (mean, deviation) before (-0.022, 0.343) after (0.000, 0.000)mmm think i nailed it now...
@dingo007 said in HEVO triple kinematic bed configuration:
@fcwilt
G32
You can if you wish put those three G30 command inside while loop with a few other commands and it will run multiple passes until an acceptable degree of levelness (is that word) is reached.
Here is an example:
; start of bed.g while true G30 P0 X-145 Y-65 Z-99999 ; probe near ball stud #1 G30 P1 X0 Y100 Z-99999 ; probe near ball stud #2 G30 P2 X145 Y-65 Z-99999 S3 ; probe near ball stud #3 ; check results - exit loop if results are good if move.calibration.initial.deviation < 0.02 break ; check pass limit - abort if pass limit reached if iterations = 5 M291 P"Bed Leveling Aborted" R"Pass Limit Reached" abort "Bed Leveling Aborted - Pass Limit Reached" ; end of bed .g
You would just need to put your own G30 commands in there.
This post is deleted! -
ok here is the top and bottom side cad of the bed, plus the photos of it above, im literally not sure what/where to measure. Am I measuring at the screws, or the ball studs, which align under the board and offset slightly with a bracket, am i measuring at the screws, or the ball studs, also do i include the offset from the board to the ball stud? and you will also notice on the rear screw it has a mount from the Z rail with a ball screw, the board sits on it centered.
for M671 ... I tried the below thinking i would measure at the ball screws, yet when i run the G32 leveling the right and read go way out of whack.
; Screws
M671 X20:125:230 Y20:280:20 S4.5 ; leadscrews at rear left, front middle and rear rightand in bed.g
G30 P0 X20 Y20 Z-99999 ; probe near a ball stud
G30 P1 X125 Y280 Z-99999 ; probe near a ballstud
G30 P2 X230 Y20 Z-99999 S3 ; probe near a ballstud and calibrate 3 motors
@dingo007 measure at the pivot point, i.e. the ball studs.
so the ball stud locations should go in M671
the M671 order should be the same order as the motors are defined in M584
so Z0.0:0.1:0.2 and M671 should be the location for the ball studs in that order -
ok and this is compared to the machine home position X0Y0 including the probe offset ?? so im measuring from that point to the pivots i take it.
@dingo007 yep
The measurement doesn't need to be 100% exact to work either. The closer the better, but don't fret over half a mm.
