    HEVO triple kinematic bed configuration
    1.1k
    • fcwiltundefined
      fcwilt @dingo007
      @dingo007 said in HEVO triple kinematic bed configuration:
      @fcwilt
      ok whats your configuration look like, ill never accomplish this without help 🙂
      I would be glad to generate one but the one I have working is for a Duet 2 WiFi/Duex 5 setup.
      • dingo007undefined
        dingo007 @dingo007
        @dingo007
        i have a 300x300 triple Z scew... and a BLTouch, no endstops on Z with a Duet3 board... think you can take a crack at it getting a config done for levelling
        right now
        M569 P0.3 S0 ; physical drive 0.3 goes forwards
        M569 P0.4 S0 ; physical drive 0.4 goes forwards
        M569 P0.5 S1 ; physical drive 0.5 goes forwards
        M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping
        M350 X16 Y16 Z16:16:16 E16 I1 ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00:400.00:400.00 E420.00 ; set steps per mm
        M566 X900.00 Y900.00 Z60.00:60:60 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00:180.00:180.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00:20.00:20.00 E250.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800:800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X300 Y300 Z350 S0 ; set axis maxima
          dc42 administrators @dingo007
          @dingo007 that config looks OK to me, but you need to add a M671 command to tell the firmware the coordinates of the leadscrews. You will also need to construct a bed.g file.
          dingo007undefined 1 Reply Last reply Reply Quote 0
          • dingo007undefined
            dingo007 @dc42
            great are those cordinate defined as where the lead screw physically is, or where it mounts to the bed, as there are ball screws under the hot bed, these are extended a bit inwards by the mount from the lead screws, basically we followed the HEVO triple Z axis design, tough its modified a bit.
            Front Left
            Center rear
            However notice the screw is offset and the rear is actually mounted at the rail
            ill look around for an example bed.g
              Phaedrux Moderator @dingo007
              Did you look here?
              If it's a triple lead screw with 3 motors then this should apply: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
              Specifically: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
              • dingo007undefined
                dingo007 @Phaedrux
                @phaedrux
                3 Z Screws will ball mounts at X:Y 20:20, 125:290 and 230:20
                So Im pretty sure im not understanding the M671 Logic i read in that guide. Ive tried from the guide however
                12/3/2021, 7:35:22 AM Error: Some computed corrections exceed configured limit of 0.50mm: 2.467 -0.039 0.029
                12/3/2021, 7:34:42 AM G32
                110 points probed, min error -1.395, max error 2.579, mean 0.493, deviation 0.962
                Height map saved to file 0:/sys/heightmap.csv
                config.g
                M350 X16 Y16 Z116:16:16 E16 I1 ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z1280.00:1280.00:1280.00 E420.00 ; set steps per mm
                ; Screws
                M671 X20:20:230 Y190:10:125 S0.5 ; leadscrews at rear left, front middle and rear right
                config-overide.g
                ; config-override.g file generated in response to M500 at 2021-12-02 20:40
                ; Heater model parameters
                M307 H0 R0.206 C393.800:393.800 D2.19 S1.00 V23.3 B0 I0
                M307 H1 R1.679 C247.000:247.000 D7.08 S1.00 V23.7 B0 I0
                ; Workplace coordinates
                G10 L2 P1 X0.00 Y0.00 Z0.00
                G10 L2 P2 X0.00 Y0.00 Z0.00
                G10 L2 P3 X0.00 Y0.00 Z0.00
                G10 L2 P4 X0.00 Y0.00 Z0.00
                G10 L2 P5 X0.00 Y0.00 Z0.00
                G10 L2 P6 X0.00 Y0.00 Z0.00
                G10 L2 P7 X0.00 Y0.00 Z0.00
                G10 L2 P8 X0.00 Y0.00 Z0.00
                G10 L2 P9 X0.00 Y0.00 Z0.00
                and bed.g
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Nov 30 2021 22:33:03 GMT+0700 (Indochina Time)
                G29 ; probe the bed and enable compensation
                G28 ; home
                G30 P0 X20 Y20 Z-99999 ; probe near a leadscrew
                G30 P1 X125 Y290 Z-99999 ; probe near a leadscrew
                G30 P2 X230 Y20 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                fcwiltundefined dingo007undefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @dingo007
                  @dingo007
                  You don't want to do a G29 in bed.g - that file is just for auto-leveling of the bed.
                  The file mesh.g is for creating the height map needed for mesh bed compensation.
                  So first get auto-leveling working and then work on mesh bed compensation.
                  • dingo007undefined
                    dingo007 @dingo007
                    @dingo007
                    I removed the G29 And still thats whats giving me the error, so im not sure im measuring the probe points right. is it where the physical screws actually are? or where the ball mounts are under the board??
                    G32
                    Error: Some computed corrections exceed configured limit of 0.50mm: 0.026 3.362 -1.291
                    config.g
                    ; Configuration file for Duet 3 (firmware version 3.3)
                    M550 P"300" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet ; Set idle timeout
                    ; Screws
                    M671 X20:125:230 Y20:300:20 S0.5 ; leadscrews at rear left, front middle and rear right
                    M208 X250 Y320 Z480 S0 ; set axis maxima
                    bed.g
                    ; bed.g
                    ;G29 ; probe the bed and enable compensation
                    G28 ; home
                    G30 P1 X125 Y300 Z-99999 ; probe near a leadscrew
                    • fcwiltundefined
                      fcwilt @dingo007
                      @dingo007
                      Well that is not really an error, more of an informational message.
                      You have the S parameter in your M671 set to 0.5 which limits the correct for a single pass to 0.5 mm which is not very much. The default value is 1.0.
                      You see that one of the adjustments required was going to be 3.362.
                      So as a test change the S parameter to 4.0 and see what happens.
                      dingo007undefined 1 Reply Last reply Reply Quote 1
                      • dingo007undefined
                        dingo007 @fcwilt
                        @fcwilt
                        G32
                        Leadscrew adjustments made: 0.167 0.270 -0.504, points used 3, (mean, deviation) before (-0.022, 0.343) after (0.000, 0.000)
                        mmm think i nailed it now...
                        • fcwiltundefined
                          fcwilt @dingo007
                          @fcwilt
                          G32
                          You can if you wish put those three G30 command inside while loop with a few other commands and it will run multiple passes until an acceptable degree of levelness (is that word) is reached.
                          Here is an example:
                          ; start of bed.g
                          while true
                              G30 P0 X-145 Y-65 Z-99999    ; probe near ball stud #1
                              G30 P1 X0    Y100 Z-99999    ; probe near ball stud #2
                              G30 P2 X145  Y-65 Z-99999 S3 ; probe near ball stud #3
                            ; check results - exit loop if results are good
                            if move.calibration.initial.deviation < 0.02
                              break
                            ; check pass limit - abort if pass limit reached
                            if iterations = 5
                              M291 P"Bed Leveling Aborted" R"Pass Limit Reached"
                              abort "Bed Leveling Aborted - Pass Limit Reached"
                          ; end of bed .g
                          You would just need to put your own G30 commands in there.
                            This post is deleted!
                            • dingo007undefined
                              dingo007 @fcwilt
                              @fcwilt
                              ok here is the top and bottom side cad of the bed, plus the photos of it above, im literally not sure what/where to measure. Am I measuring at the screws, or the ball studs, which align under the board and offset slightly with a bracket, am i measuring at the screws, or the ball studs, also do i include the offset from the board to the ball stud? and you will also notice on the rear screw it has a mount from the Z rail with a ball screw, the board sits on it centered.
                              for M671 ... I tried the below thinking i would measure at the ball screws, yet when i run the G32 leveling the right and read go way out of whack.
                              ; Screws
                              M671 X20:125:230 Y20:280:20 S4.5 ; leadscrews at rear left, front middle and rear right
                              and in bed.g
                              G30 P0 X20 Y20 Z-99999 ; probe near a ball stud
                              G30 P1 X125 Y280 Z-99999 ; probe near a ballstud
                              G30 P2 X230 Y20 Z-99999 S3 ; probe near a ballstud and calibrate 3 motors
                              jay_s_ukundefined dingo007undefined 2 Replies Last reply Reply Quote 0
                                jay_s_uk @dingo007
                                @dingo007 measure at the pivot point, i.e. the ball studs.
                                so the ball stud locations should go in M671
                                the M671 order should be the same order as the motors are defined in M584
                                so Z0.0:0.1:0.2 and M671 should be the location for the ball studs in that order
                                • dingo007undefined
                                  dingo007 @dingo007
                                  @dingo007
                                  ok and this is compared to the machine home position X0Y0 including the probe offset ?? so im measuring from that point to the pivots i take it.
                                    jay_s_uk @dingo007
                                    @dingo007 yep
                                      The measurement doesn't need to be 100% exact to work either. The closer the better, but don't fret over half a mm.
