    BLTouch Probe Won't Deploy
    5.2k
    • Charlieundefined
      Charlie @JoergS5
      @joergs5
      No worries. I greatly appreciate your willingness to help!
      In this case, I am homing X, then Y, then Z. With that said, the issue also occurs using the "Home All" button in DWC.
      • fcwiltundefined
        fcwilt @Charlie
        @charlie said in BLTouch Probe Won't Deploy:
        @joergs5
        So homing just Z with the DWC Home Z button does not work? Just want to be sure I understand what is happening.
        Charlieundefined 1 Reply Last reply Reply Quote 0
        • Charlieundefined
          Charlie @JoergS5
          @joergs5
          homex.g
          ; Voron.
          ; 0:/sys/homex.g
          ; Called to home the X axis via G28 X.
          ; 2020/10/24/20:00
          G91               ; Set axes (not extruders) to relative positioning mode.
          G1 H2 Z5 F6000    ; Lift Z relative to current position.
          G1 H1 X355 F6000  ; Move quickly to X endstop (1 of 2 passes).
          G1 H0 X-3 F6000   ; Move away from X endstop.
          G1 H1 X10 F360    ; Move slowly to X axis endstop once more (2 of 2 passes).
          G1 H2 Z-5 F6000   ; Lower Z relative to current position.
          G90               ; Set axes (not extruders) to absolute positioning mode.
          homey.g
          ; Voron
          ; 0:/sys/homey.g
          ; Called to home the Y axis via G28 Y.
          ; 2020/10/24/20:01
          G1 H1 Y360 F6000  ; Move quickly to Y endstop (1 of 2 passes).
          G1 H0 Y-3 F6000   ; Move away from Y endstop.
          G1 H1 Y10 F360    ; Move slowly to X axis endstop once more (2 of 2 passes).
          homeall.g
          ; Voron.
          ; 0:/sys/homeall.g
          ; Called to home all axes via G28.
          ; 2020/10/24/21:00
          G1 H1 X355 Y360 F6000  ; Move quickly to X or Y axis endstop and stop there.
          G1 H1 X355 F6000       ; Move quickly to X endstop and stop there.
          G1 H1 Y360 F6000       ; Move quickly to Y endstop and stop there.
          G1 H0 X-3 Y-3 F6000    ; Move away from X and Y endstops.
          G1 H1 X10 F360         ; Move slowly to X endstop once more.
          G1 H1 Y10 F360         ; Move slowly to Y endstop once more.
          G1 X175 Y151.5 F6000   ; Move X and Y axes so the Z probe is at the center of the bed.
          M558 F600 H2 A1        ; Set Z probe. Feed rate: 600 mm/min. Dive height: 2 mm. Times to probe: 1.
          G30                    ; Z probe quickly (1 of 2 passes).
          M558 F120 H5 A1        ; Set Z probe. Feed rate: 120 mm/min. Dive height: 5 mm. Times to probe: 1.
          G30                    ; Home Z by probing the bed slowly (2 of 2 passes).
          • JoergS5undefined
            JoergS5 @Charlie
            @charlie you may need to exchange the order or M950 and M558:
            in the M950 documentation https://duet3d.dozuki.com/Wiki/M950 :
            "M950 must come before any commands that refer to the device being created."
            So M950, then M558 which uses the servo part of BLTouch.
            I am not sure about this. In the examples I know, M950 is first, M558 next, but the two commands don't have a reference to each other. But it's worth a try. M558 may expect to know the M950 values.
            • Charlieundefined
              Charlie @fcwilt
              @fcwilt
              That is correct. Homing just Z doesnt work.
              It also doesnt work if I use "Home All".
              fcwiltundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @Charlie
                @fcwilt
                OK let's take the homing code out of the picture.
                Can you reset the printer and successfully home X and Y?
                • JoergS5undefined
                  JoergS5 @Charlie
                  @charlie a last additional idea: M208 has Z minimum 0 and the BLTouch starts at 3 mm height. It may be that it cannot probe below 0 because of M208. This was changed in 3.4 somewhere if I remember correct, but if you use 3.3 firmware, it may be a try to set the M208 Z limit below 0.
                  • Charlieundefined
                    Charlie @fcwilt
                    @fcwilt
                    Im assuming that "reset" means sending an M999 command, or powering off the duet. In that case, X and Y works wonderfully when I home them individually. Furthermore, the X and Y portions of the Home All function work as intended as well.
                    • Charlieundefined
                      Charlie @JoergS5
                      @joergs5
                      Unfortunately, this did not fix the issue. I appreciate the attempt though!
                      • fcwiltundefined
                        fcwilt @Charlie
                        @fcwilt
                        Great.
                        So with X and Y homed:
                        • move X and Y to center of the bed either by jogging or issuing G1 commands
                        • issue a G92 Z3 to force Z to be marked as homed (this allows jogging Z)
                        • jog Z to 3 mm off the bed (now the logical and physical Z positions are in sync)
                        • change to the DWC Console page
                        • issue a G30
                        Post what happens.
                        • Charlieundefined
                          Charlie @fcwilt
                          @fcwilt
                          So I did this, but with one exception. I didnt jog the z to be 3mm off the bed, as I was concerned about crashing the nozzle.
                          The probe did not deploy, and the error: "Error: Probe was not triggered during probing move" was displayed on the console.
                          • Charlieundefined
                            Charlie @JoergS5
                            @joergs5 said in BLTouch Probe Won't Deploy:
                            Something odd happened that may help those smarter than I!
                            I issued an M208 S1 Z-100 command in the DWC console (which is along the lines of what I believed you asked me to do). I then issued a G30 command. Please keep in mind that this was after I did what @fcwilt asked, which was to issue a G92 Z3 command.
                            The print head seemed to move down around 3mm, and then the probe deployed.
                            • fcwiltundefined
                              fcwilt @Charlie
                              I made a post but came back to find your new post.
                              I need to think.
                              • fcwiltundefined
                                fcwilt @Charlie
                                @charlie
                                OK what are your current probe configuration commands (M950 M558 G31)?
                                • Charlieundefined
                                  Charlie @fcwilt
                                  @fcwilt
                                  Here is the current Z Probe section of the config.g file, containing the M950, M558, and G31.
                                  ; Z Probe
                                  M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"  ; Set Z probe type.
        ; K (Z probe number): 0 (1).
        ; P (Z Probe type): 9 (BLTouch probe).
        ; F (Feed rate. Probing speed [mm/min]): 120.
        ; H (Dive height [mm]): 3.
        ; R (Recovery time [seconds]): 0.
        ; T (Travel speed [mm/min]): 6,000.
        ; A (Max number of times to probe each point): 1.
        ; B (Heaters): 0 (Leave all heaters on while probing).
        ; C (Endstop input): 0. (Mainboard) io4.in.
                                  M950 S0 C"0.io4.out"                           ; Create GPIO/servo pin.
        ; S (Output/servo pin number): 0.
        ; C (Pin name): 0. (Mainboard) io4.out.
                                  G31 P500 X0 Y22.0 Z3.105 K0                    ; Set Z probe.
        ; P (Trigger value): 500.
        ; X (Probe X offset [mm]): 0.
        ; Y (Probe Y offset [mm]): 22.000.
        ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.).
        ; K (Z probe number): 0.
                                  M557 X25:325 Y25:313.5 P3                      ; Define Z probe mesh grid (This is the probe point grid, not the nozzle grid).
        ; X (Min:Max X coordinates to probe [mm]): 35 (Min) : 325 (Max).
        ; Y (Min:Max Y coordinates to probe [mm]): 25 (Min) : 313.5 (Max).
        ; P (Points to probe in each direction): 3.
                                  fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @Charlie
                                    @charlie
                                    Let's changes things just a bit:
                                    M558 P9 C"0.io4.in" H3 T6000 F120 A1 R0.2 B0
                                    G31 P25 X0 Y22.0 Z3.105
                                    Reset and try what I suggested before BUT lets use G92 Z7 instead of G92 Z3
                                    • Charlieundefined
                                      Charlie @fcwilt
                                      @fcwilt
                                      Same problem. Probe did not deploy. Same error: "Error: Probe was not triggered during probing move"
                                      • fcwiltundefined
                                        fcwilt @Charlie
                                        And yet when you issued the M208 S1 Z-100 and then the G30 it seemed to work?
                                        • Charlieundefined
                                          Charlie @fcwilt
                                          @fcwilt
                                          This is correct, but I cant seem to replicate the scenario in which it worked.
                                          • fcwiltundefined
                                            fcwilt @Charlie
                                            @fcwilt
                                            Well we are overlooking something simple.
                                            Did you post what the DWC Z Probe readout value is?
