    BLTouch Probe Won't Deploy
    5.2k
    • fcwiltundefined
      fcwilt @Charlie
      @charlie said in BLTouch Probe Won't Deploy:
      @fcwilt
      Im assuming that "reset" means sending an M999 command, or powering off the duet. In that case, X and Y works wonderfully when I home them individually. Furthermore, the X and Y portions of the Home All function work as intended as well.
      Great.
      So with X and Y homed:
      • move X and Y to center of the bed either by jogging or issuing G1 commands
      • issue a G92 Z3 to force Z to be marked as homed (this allows jogging Z)
      • jog Z to 3 mm off the bed (now the logical and physical Z positions are in sync)
      • change to the DWC Console page
      • issue a G30
      Post what happens.
      Charlieundefined 1 Reply Last reply Reply Quote 0
      • Charlieundefined
        Charlie @fcwilt
        @fcwilt
        So I did this, but with one exception. I didnt jog the z to be 3mm off the bed, as I was concerned about crashing the nozzle.
        The probe did not deploy, and the error: "Error: Probe was not triggered during probing move" was displayed on the console.
        • Charlieundefined
          Charlie @JoergS5
          @joergs5 said in BLTouch Probe Won't Deploy:
          @charlie a last additional idea: M208 has Z minimum 0 and the BLTouch starts at 3 mm height. It may be that it cannot probe below 0 because of M208. This was changed in 3.4 somewhere if I remember correct, but if you use 3.3 firmware, it may be a try to set the M208 Z limit below 0.
          Something odd happened that may help those smarter than I!
          I issued an M208 S1 Z-100 command in the DWC console (which is along the lines of what I believed you asked me to do). I then issued a G30 command. Please keep in mind that this was after I did what @fcwilt asked, which was to issue a G92 Z3 command.
          The print head seemed to move down around 3mm, and then the probe deployed.
          • fcwiltundefined
            fcwilt @Charlie
            I made a post but came back to find your new post.
            I need to think.
            • fcwiltundefined
              fcwilt @Charlie
              @charlie
              OK what are your current probe configuration commands (M950 M558 G31)?
              • Charlieundefined
                Charlie @fcwilt
                @fcwilt
                Here is the current Z Probe section of the config.g file, containing the M950, M558, and G31.
                ; Z Probe
                M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"  ; Set Z probe type.
                                                               ; K (Z probe number): 0 (1).
                                                               ; P (Z Probe type): 9 (BLTouch probe).
                                                               ; F (Feed rate. Probing speed [mm/min]): 120.
                                                               ; H (Dive height [mm]): 3.
                                                               ; R (Recovery time [seconds]): 0.
                                                               ; T (Travel speed [mm/min]): 6,000.
                                                               ; A (Max number of times to probe each point): 1.
                                                               ; B (Heaters): 0 (Leave all heaters on while probing).
                                                               ; C (Endstop input): 0. (Mainboard) io4.in.
                M950 S0 C"0.io4.out"                           ; Create GPIO/servo pin.
                                                               ; S (Output/servo pin number): 0.
                                                               ; C (Pin name): 0. (Mainboard) io4.out.
                G31 P500 X0 Y22.0 Z3.105 K0                    ; Set Z probe.
                                                               ; P (Trigger value): 500.
                                                               ; X (Probe X offset [mm]): 0.
                                                               ; Y (Probe Y offset [mm]): 22.000.
                                                               ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.).
                                                               ; K (Z probe number): 0.
                M557 X25:325 Y25:313.5 P3                      ; Define Z probe mesh grid (This is the probe point grid, not the nozzle grid).
                                                               ; X (Min:Max X coordinates to probe [mm]): 35 (Min) : 325 (Max).
                                                               ; Y (Min:Max Y coordinates to probe [mm]): 25 (Min) : 313.5 (Max).
                                                               ; P (Points to probe in each direction): 3.
                fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @Charlie
                  @charlie
                  Let's changes things just a bit:
                  M558 P9 C"0.io4.in" H3 T6000 F120 A1 R0.2 B0
                  G31 P25 X0 Y22.0 Z3.105
                  Reset and try what I suggested before BUT lets use G92 Z7 instead of G92 Z3
                  • Charlieundefined
                    Charlie @fcwilt
                    @fcwilt
                    Same problem. Probe did not deploy. Same error: "Error: Probe was not triggered during probing move"
                    • fcwiltundefined
                      fcwilt @Charlie
                      And yet when you issued the M208 S1 Z-100 and then the G30 it seemed to work?
                      • Charlieundefined
                        Charlie @fcwilt
                        @fcwilt
                        This is correct, but I cant seem to replicate the scenario in which it worked.
                        • fcwiltundefined
                          fcwilt @Charlie
                          @fcwilt
                          Well we are overlooking something simple.
                          Did you post what the DWC Z Probe readout value is?
                          • Charlieundefined
                            Charlie @fcwilt
                            @fcwilt
                            Z Probe readout value is 0, and remains 0 for the entire homing attempt.
                            Charlieundefined 1 Reply Last reply Reply Quote 1
                            • Charlieundefined
                              Charlie @Charlie
                              Im unsure as to whether this means anything, but the BLTouch light remains a solid red when the machine is idle, as well as before and during the homing process. Of course the light shuts off when I power off the machine to prevent crashing, but the probe also deploys when power is turned off while the Z probe is occuring.
                              • fcwiltundefined
                                fcwilt @Charlie
                                Well it's getting late and I've got to get some sleep.
                                Sorry we couldn't get it sorted in this session.
                                I will run some tests with my BLTouch and see I can determine what conditions could be causing your problems.
                                Talk to you later.
                                Good night.
                                • Charlieundefined
                                  Charlie @fcwilt
                                  @fcwilt
                                  No worries, same here. Thank you so much for the time that you have put into this issue. I greatly appreciate it!
                                  Im hoping that this isnt an interference issue that will require shielding.
                                  Thanks again! Good night.
                                  • Charlieundefined
                                    Charlie @Phaedrux
                                    @phaedrux
                                    It is clear. I was just confused regarding the use of "Servo pin number" in M950 vs "Servo index" in M280. But honestly, thats more an issue with me. 😝
                                    Unfortunately, this issue persists.
                                      Phaedrux Moderator @Charlie
                                      M558 K0
                                      Can you try without the K0? If you only have a single probe, best to leave it off.
                                      Can you please share your full config.g?
                                      What exactly do you have in your deployprobe.g and retractprobe.g files in the sys folder?
                                      Does M401 and M402 work to deploy or retract the probe?
                                      Does the probe deploy when you send G30?
                                      Does the BLTouch pin deploy and retract when power is first applied?
                                      How exactly is the BLtouch wired?
                                      And The results of M122 and M98 P"config.g"?
                                      Also send M558, G31, by themselves are see what they return.
                                      JoergS5undefined Charlieundefined 8 Replies Last reply Reply Quote 0
                                      • JoergS5undefined
                                        JoergS5 @Phaedrux
                                        @phaedrux said in BLTouch Probe Won't Deploy:
                                        I want to add that the filenames are deployprobe0.g and retractprobe0.g (so with 0 added), but I thought it is ok because of the K0.
                                        The code is in GCodes3.cpp DeployZProbe() and RetractZProbe(), and looks ok.
                                        The filenames must be all lowercase.
                                        • JoergS5undefined
                                          JoergS5 @Charlie
                                          @charlie maybe your BLtouch is too near to the bed, please check
                                          (from https://forum.duet3d.com/topic/17329/bl-touch/4)
                                          and then a higher height like H5 in the M558.
                                          • Charlieundefined
                                            Charlie @Phaedrux
                                            Unfortunately this doesnt change the outcome. I appreciate the attempt though.
