    BLTouch Probe Won't Deploy
    4.9k
    • fcwiltundefined
      fcwilt @Charlie
      @charlie
      If you have one probe you can leave the K parameter off everywhere. It defaults to 0 in anycase.
      My BLTouch connected to a Duet 2 Wifi works fine and I have no K parameters anywhere.
      I'm still baffled by your problem. I also still believe we are overlooking something simple.
        Are you sure you've removed all cases of K0?
        Can you try this?
        Power cycle your printer
        Before doing anything else, send M401 and M402 to test that the pin deploys and retracts.
        If that works, send G30 by itself. Does the pin deploy? Does it give an error? Does the Z axis move?
        Charlieundefined 2 Replies Last reply Reply Quote 0
        • Charlieundefined
          Charlie @Phaedrux
          @phaedrux said in BLTouch Probe Won't Deploy:
          Here is the new Z Probe section of the config.g
          ; Z Probe
          M558 P9 F120 H8 R0 T6000 A1 B0 C"0.io4.in"  ; Set Z probe type.
                                                         ; K (Z probe number): 0 (1).
                                                         ; P (Z Probe type): 9 (BLTouch probe).
                                                         ; F (Feed rate. Probing speed [mm/min]): 120.
                                                         ; H (Dive height [mm]): 3.
                                                         ; R (Recovery time [seconds]): 0.
                                                         ; T (Travel speed [mm/min]): 6,000.
                                                         ; A (Max number of times to probe each point): 1.
                                                         ; B (Heaters): 0 (Leave all heaters on while probing).
                                                         ; C (Endstop input): 0. (Mainboard) io4.in.
          M950 S0 C"0.io4.out"                           ; Create GPIO/servo pin.
                                                         ; S (Output/servo pin number): 0.
                                                         ; C (Pin name): 0. (Mainboard) io4.out.
          G31 P500 X0 Y22.0 Z3.105                    ; Set Z probe.
                                                         ; P (Trigger value): 500.
                                                         ; X (Probe X offset [mm]): 0.
                                                         ; Y (Probe Y offset [mm]): 22.000.
                                                         ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.).
                                                         ; K (Z probe number): 0.
          M557 X25:325 Y25:313.5 P3                      ; Define Z probe mesh grid (This is the probe point grid, not the nozzle grid).
                                                         ; X (Min:Max X coordinates to probe [mm]): 35 (Min) : 325 (Max).
                                                         ; Y (Min:Max Y coordinates to probe [mm]): 25 (Min) : 313.5 (Max).
                                                         ; P (Points to probe in each direction): 3.
          homez.g
          ; Voron.
          ; 0:/sys/homez.g
          ; Called to home the Z axis via G28 Z.
          ; 2020/10/24/20:02
          G91                   ; Set axes (not extruders) to relative positioning mode.
          G1 H2 Z5 F6000        ; Lift Z relative to current position.
          G90                   ; Set axes (not extruders) to absolute positioning mode.
          G1 X175 Y151.5 F6000  ; Move X and Y axes so the Z probe is at the center of the bed.
          M558 F600 H2 A1       ; Set Z probe. Feed rate: 600 mm/min. Dive height: 2 mm. Times to probe: 1.
          G30                   ; Z probe quickly (1 of 2 passes).
          M558 F120 H5 A1       ; Set Z probe. Feed rate: 120 mm/min. Dive height: 5 mm. Times to probe: 1.
          G30                   ; Home Z by probing the bed slowly (2 of 2 passes).
          and I no longer have the "0" on the deployprobe and retractprobe file names.
          Pin does deploy and retract with M401 and M402 respectively.
          When calling G30. I get this error.
          g30
          Error: G30: Insufficient axes homed for bed probing
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Charlie
            @charlie said in BLTouch Probe Won't Deploy:
            g30
            X and Y have to be homed - are they?
            Charlieundefined 1 Reply Last reply Reply Quote 0
            • Charlieundefined
              Charlie @Phaedrux
              So, after getting this error:
              g30
              I threw G92 X0, and then G92 Y0 in the console.
              The probe did deploy in this instance.
              • Charlieundefined
                Charlie @fcwilt
                @fcwilt
                Yes, homed X and Y after getting that error. The probe did deploy in this case.
                • fcwiltundefined
                  fcwilt @Charlie
                  @charlie
                  So it seems all is working and it's just a question of you being sure that X and Y are homed before trying to use the probe.
                  That is one of the reasons I include a Z axis endstop sensor on all my printers so I can home Z without having to worry about homing X and Y first.
                  • Charlieundefined
                    Charlie @fcwilt
                    @fcwilt said in BLTouch Probe Won't Deploy:
                    The problem is that the probe isnt deploying when I am actually calling a homez.g or homeall.g. It is only deploying when I am following the exact workflow that @Phaedrux outlines here.
                    @Phaedrux
                      Phaedrux Moderator @Charlie
                      I wonder if it has something to do with your homeall setting the dive height to be less than the trigger height.
                      I also thought that G30 would work regardless of X and Y being homed since it should only trigger movement in Z.
                        The only other thing I can recommend for troubleshooting is to generate a basic config using the online tool and only customizing it manually to account for the basics and seeing if it works as expected.
                        Are you using toolboards or expansion boards or just the 6HC?
                        Charlieundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • Charlieundefined
                          Charlie @Phaedrux
                          In this instance of attempting to home, I am using the "Home Z" button on the DWC. Here is my most current homez.g file.
                          ; Voron.
                          ; 0:/sys/homez.g
                          ; 2020/10/24/20:02
                            M558 F600 H2 A1
                            This sets your dive height to 2mm, but your probe trigger height is over 3mm.
                            Do you see how that could be an issue?
                            • Charlieundefined
                              Charlie @Phaedrux
                              Yes, I definitely see how that can be an issue. With that said, I set that value to 8mm and the issue persists.
                              • Charlieundefined
                                Charlie @Phaedrux
                                I am using 6HC and an expansion board.
                                Do you need to be in G91 to run a G30? If I send a G90, then G30, I have the probing issue. If I send G91, then G30, it seems to probe. Is this my issue?
                                • fcwiltundefined
                                  fcwilt @Charlie
                                  In you homing files where you are using G30 you are invoking G30 twice.
                                  Now this is not related to your problem but you don't really need to do it twice.
                                  So, as a test, change the code so you only do it once and be sure the dive height is large enough.
                                  As a reference my dive height setting is 5 and the Z trigger height setting is 1.8. and I always start probing at Z=10.
                                  • fcwiltundefined
                                    fcwilt @Charlie
                                    I double checked my code to be sure and it is always put into G90 mode before do the G30.
                                    • JoergS5undefined
                                      JoergS5 @Charlie
                                      The code is in GCodes3.cpp DeployZProbe() and RetractZProbe(), and looks ok.
                                      Im not sure what this means. Please let me know if you would like to provide more information.
                                      This was analysis of the firmware source code. It accepts 0 in the deploy/retract files and also K0. It was only a check, you don't need to do anything.
                                      About your problem, I am currently thinking about whether moving -3 away from the endstop is maybe too low and not reset to no-contact or contact (I don't know your endstop), so the endstop may not trigger at the next slow move, which is G1 H1 and doesn't set the endstop triggered then.
                                      E. g. such a type:
                                      approached with high speed, 3 mm back may be too low.
                                      • Charlieundefined
                                        Charlie @fcwilt
                                        Correct. I am using the first G30 to do a coarse home, and then the second G30 to do a fine home.
                                        I tried doing one G30, and the probe still did not deploy.
                                        What do you mean that you always start probing at 10mm? Isnt that dependent on your last print height?
                                        • Charlieundefined
                                          Charlie @fcwilt
                                          Okay, thats the way that it used to work for me as well. Now the probe wont deploy unless I have a G91 before my M558 and G30 in my homez.g file.
                                          • fcwiltundefined
                                            fcwilt @Charlie
                                            Did you remove the double G30s in the homing files?
