    Replace the wire with Bluetooth Module HC-05
    PanelDue
    • Laiwxnundefined
      Laiwxn
      I have two HC-05 Buletooth module,I want to use them to replace the wire between the PanelDUE and the main board.Wow,It works very well.😊
      But when I shutdown the mainboard,the paneldue still in standby mode,not the connecting mode.There is no heartbeat between The paneldue and the mainboard? Thanks.
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @Laiwxn
        @laiwxn can you Share the wiring and the Code.
        You could try Resetting the paneldue with M999
        Laiwxnundefined 1 Reply Last reply Reply Quote 0
        • Laiwxnundefined
          Laiwxn @PCR
          @pcr the paneldue doesn't refresh the status automatically?
          • mfs12undefined
            mfs12
            @Laiwxn, the connection times out and some point and get's back into connecting state. In standby tab although, the polling is interrupted.
            Does this also happen in any other tab than setup screen?
            Visit me on github at https://github.com/mfs12/
            • mfs12undefined mfs12 marked this topic as a question
            • mfs12undefined
              mfs12
              Marking as solved due to inactivity. if the issue still persist feel free to reopen the thread.
              • mfs12undefined mfs12 has marked this topic as solved
              • JoergS5undefined JoergS5 referenced this topic
