    seeing if i can get assistance with bed connectins
    1.5k
    • Gixxerfastundefined
      Gixxerfast @frnknstn
      @frnknstn OK, so you have dragged the little bubble icon to max and no fan movement?
      Then we need to see the wiring please
      Your fan config should be good now
      Promise to say "It's alive, it's alive" when it starts working 🙂
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      frnknstnundefined 2 Replies Last reply Reply Quote 0
      • frnknstnundefined
        frnknstn @Gixxerfast
        @gixxerfast could i have the wires backwards wouldnt they spin backwards? Probably a dumb question but i thought id ask. Trying to get this pic off my phone to show ya
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        • frnknstnundefined
          @gixxerfast said in seeing if i can get assistance with bed connectins:
          Funny cause i call it Frankenstein
          Gixxerfastundefined 2 Replies Last reply Reply Quote 0
            @frnknstn No, they don't spin backwards AFAIK. They can actually be really sad sometimes if wired incorrectly (afaik)
            frnknstnundefined 1 Reply Last reply Reply Quote 0
              @frnknstn said in seeing if i can get assistance with bed connectins:
              Yeah, that's why it's fun 🙂 LOL
              • frnknstnundefined
                @gixxerfast alright i have to pause here...i have to grab the wife from work then i will be back, again i appreciate it alot.
                  @frnknstn OK, anyhow. The black wire should be facing the SD-card when connected to the two pin connectors.
                  • frnknstnundefined
                    @gixxerfast so i had out7 backwards. i swapped the wires around and now the parts blower work. on control panel tool fan and fan 0 turn it on. out8 nothing
                    • frnknstnundefined
                      frnknstn @frnknstn
                      also i checked wiring they are both black towards sd card slot
                      • frnknstnundefined
                        frnknstn @frnknstn
                        @frnknstn sorry i was incorrect 8 was backwards too
                        • frnknstnundefined
                          frnknstn @frnknstn
                          @frnknstn fixedfan 8 now 7 is controlled by both fan controls
                          • frnknstnundefined
                            frnknstn @frnknstn
                            @frnknstn ```
                            As of right now my extruder fan is on always, the other fan comes on with the control buttons
                            M950 F0 C"out7" Q500                                     ; Parts cooling create fan 0 on pin out7 and set its frequency
                            M106 P0 S0 H-1
                            M950 F1 C"out8" Q500                                     ; Extruder create fan 1 on pin out8 and set its frequency
                            M106 P1 T0 H1
                            frnknstnundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                            • frnknstnundefined
                              frnknstn @frnknstn
                              @frnknstn i see tool fan is only active while hotend is active
                                Phaedrux Moderator @frnknstn
                                Show us your tool definition.
                                  M106 P1 T0 H1
                                  As far as I can see all is working as it should. Maybe you could have the hotend fan turn on at 45C something like this:
                                  M106 P1 S1 H1 T45
                                  Apart from that, don't you think the fans are working as they should now?
                                  • frnknstnundefined
                                    @gixxerfast fans seem good. I'm going to work on z probe now to figure that out. This is my code so far
                                    G90                                         ; Send absolute coordinates...
                                    M83                                         ; ...but relative extruder moves
                                    M550 P"duet3"                        	; Set machine name
                                    M552 S1                                     	; Enable network
                                    ;*** Access point is configured manually via M587
                                    M586 P0 S1                                  ; Enable HTTP
                                    M586 P1 S0                                  ; Disable FTP
                                    M586 P2 S0                                  ; Disable Telnet
                                    M575 P1 S1 B57600							; Panel Due
                                    ; Printer geometry
                                    M669 K1                	                    ; Select CoreXY mode
                                    M208 X0:330 Y0:285.75 Z0:350                ; Axis Limits
                                    M564 H0							            ; allow unhomed movement
                                    ;------- drives from top---------------------------------------------------
                                    ;  B -------+------ A
                                    ;   | P.02 | P.03 |
                                    ;   -------+-------  Z-Drives
                                    ;   | P0.1 | P0.4 |
                                    ;        Front
                                    ; Drive Mappings
                                    M569 P0.0 S1 V0                             ; Drive 0: E Axis
                                    M569 P0.1 S1 V0                             ; Drive 1: Z-LeftFront Axis
                                    M569 P0.2 S0 V0                             ; Drive 2: Z-LeftRear Axis
                                    M569 P0.3 S1 V0                             ; Drive 3: Z-RightRear Axis
                                    M569 P0.4 S0 V0                             ; Drive 4: Z-RightFront Axis
                                    M569 P1.0 S1 V0                             ; Drive 5: Expansion: B motor (X-axis)
                                    M569 P1.1 S1 V0                             ; Drive 6: Expansion: A motor (Y-axis)
                                    ; Motor remapping for dual Z and axis Limits
                                    M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0                              ; Motor mapping
                                    M671 X-76.2:-76.2:406.4:406.4 Y0:374.65:374.65:0 S20	        ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front
                                    ; Microstepping and Speed
                                    M350 X32 Y32 E16 Z16 I1                     ; Configure microstepping with interpolation
                                    M92 X200.00 Y200.00 Z200.00 E400.00         ; Set steps per mm	1.8 motors
                                    ; Speeds, Acceleration and Jerk
                                    M566 X400.00 Y400.00 Z25.00 E600.00 P1          ; Set maximum instantaneous speed changes (mm/min)
                                    M203 X12000.00 Y12000.00 Z1000.00 E3600.00      ; Set maximum speeds (mm/min)
                                    M201 X3000.00 Y3000.00 Z100.00 E3600.00        ; Set accelerations (mm/s^2)
                                    ; Motor currents
                                    M906 X1200.00 Y1200.00 Z1200.00 E700.00 I60        ; Set motor currents (mA) and motor idle factor in percent
                                    M84 S600                                            ; Set idle timeout
                                    ; Endstops for each Axis
                                    M574 X2 S1 P"io0.in" 					 	; Set X endstop controlled by switch
                                    M574 Y2 S1 P"io1.in"                      	; Set Y endstop controlled by switch
                                    M558 P8 C"io3.in" H5 F120 T60000                                 ; set Z probe type to unmodulated and the dive height + speeds
                                    G31 P500 X0 Y0 Z2.5                                                 ; set Z probe trigger value, offset and trigger height
                                    M557 X15:215 Y15:195 S20                                            ; define mesh grid
                                    ; Stallgaurd Sensitivy (maybe use to pause print after crash)
                                    M915 X S2 F0 H200 R0		                ; Set X axis Sensitivity  1.8 motors
                                    M915 Y S2 F0 H200 R0		                ; Set y axis Sensitivity  1.8 motors
                                    ; Input Shaper and Accelerometer
                                    ;M955 P0 C"io4.out+io4.in"
                                    ;M593 F46.75 S0.2
                                    ;M593 F19 P4 S0.3 ; experimental
                                    ; Z Probe Offset (Probe behind Afterburner)
                                    G31 P500 X0 Y0 Z1.5
                                    M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138                ; configure sensor 0 as thermistor on pin temp0
                                    M950 H0 C"out_0" T0                                                 ; create bed heater output on out0 and map it to sensor 0
                                    M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode
                                    M140 H0                                                             ; map heated bed to heater 0
                                    M143 H0 S120                                                        ; set temperature limit for heater 0 to 120C
                                    M308 S1 P"temp_1" Y"thermistor"  A"Hotend" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin temp1
                                    M950 H1 C"out_1" T1                                                 ; create nozzle heater output on out1 and map it to sensor 1
                                     M307 H1 B0 R2.442 C100.2 D3.38 S1.00                          ; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S280                                                        ; set temperature limit for heater 1 to 280C
                                    M106 P0 S0 H-1
                                    M106 P1 T45 H1
                                    ; Fans Electronic compartment & Exhaust
                                    ;M950 F1 C"out3" Q100				    ; Creates Case Fan 1
                                    ;M106 P1 T40 S150 H0                 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed
                                    ;M950 F2 C"out4" Q100				    ; Creates Case Fan 2
                                    ;M106 P2 T40 S150 H0                  ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed
                                    ;M950 F5 C"out7" Q100				    ; Creates Case Fan 2
                                    ;M106 P5 T95 S50 H0                  ; Exhaust fan
                                    ; Filament Runout sensor
                                    ;M950 J4 C"io5.in"               ; Input 4 filament sensor
                                    ;M581 P4 T2 S1 R1                ; Filament Sensor P4 triggers  inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1)
                                    ;M591 D0 P1 C"io5.in" S1			; Filament Sensor
                                    M563 P0 D0 H1
                                    G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
                                    G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
                                    T0
                                      jay_s_uk @frnknstn
                                      M563 P0 D0 H1
                                      Add F0 at the end of here to tie your part cooling fan to your tool
                                        Gixxerfast @jay_s_uk
                                        @jay_s_uk Not really neccessary for other reason than to make it really clear 🙂
                                        From https://duet3d.dozuki.com/Wiki/M563:
                                        "F The print cooling fan of the tool, default 0. Use this parameter if you are not using fan 0 as the print cooling fan for the tool you are defining."
                                        • frnknstnundefined
                                          @gixxerfast i made the change thank you
                                          ; Printer geometry
                                          ;   | P.02 | P.03 |
                                          ;   | P0.1 | P0.4 |
                                          ;        Front
                                          ; Drive Mappings
                                          ; Motor remapping for Quad Z and axis Limits
                                          ; Motor currents
                                          ;M593 F46.75 S0.2
                                          G31 P500 X0 Y0 Z1.5
                                          M106 P0 S0 H-1
                                          M106 P1 T45 H1
                                          M563 P0 D0 H1 F0
                                          T0
