    please help me blv setting
    129
    7.8k
      A Former User
      Hello I have just lived through months of hardship the most difficult days of my life. how to adjust my printer as my prints are really bad i know some people it can be very simple and are able to resolve quickly but i constantly fail and get frustrated at this point i dont understand anything could someone help me, i dont know what to do more than take to throw this whole printer away. to anyone i asked for help other sites are not friendly please help me
      at this stage i don't know what to do i want to give up but i like 3d printing😭 😭
        A Former User @A Former User
        @sgk IMG_20211213_112348_edit_4278662018617.jpg IMG_20211213_111959_edit_4302555630592.jpg IMG_20211213_111955_edit_4321347058714.jpg IMG_20211213_111941_edit_4334689355587.jpg IMG_20211213_111928_edit_4348254760273.jpg
          jay_s_uk @A Former User
          @sgk want to start of posting your config and which issues you are looking to tackle first?
            A Former User @jay_s_uk
            @jay_s_uk
            thank you thank you for answering me.
              @sgk Capture d’écran 2021-12-14 160326.jpg Capture d’écran 2021-12-14 160308.jpg Capture d’écran 2021-12-14 160247.jpg Capture d’écran 2021-12-14 160217.jpg
                @sgk can you copy and paste the information rather then screenshots?
                use the
                circled button when posted so its properly formatted for us to read.
                Also, what board are you using and what firmware are you running? (M115 will tell you)
                A Former User? 3 Replies Last reply Reply Quote 0
                  This post is deleted!
                    M208 X-23 Y0 Z0 S1 ; Set axis minima
                    M208 X320 Y320 Z350 S0 ; Set axis maxima
                                              ; ======================== Z-Probe =========================
                    M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
                    G31 P500 X-2.24 Y-20.81 Z1.300 ; Set Z probe trigger value, offset and trigger height
                    M557 X20:270 Y20:270 S240 ; Define mesh grid
                                             ; ======================== Heaters =========================
                    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
                    M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                    M307 H0 R0.272 C388.6 D16.77 S1.00 V23.6 ; Heatbed PID
                    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; define E0 temperature sensor
                    M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1
                    M307 H1 R2.697 C168.9:154.1 D9.06 S1.00 V23.6 ; Hotend PID .4mm
                    M143 H1 S260 ; set temperature limit for heater 0 to 260C
                    M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
                      @jay_s_uk M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M669 K1 ; select CoreXY mode
                                      ; ======================= Endstops =========================
                      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                      M575 P1 S1 B57600 ; Set things up for the PanelDue
                                                  ; Filament sensor
                      M591 D0 P1 C"e0stop" S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0
                                  ; ======================= Drives ===========================
                      M569 P0 S0 ; Drive 0 goes backwards blv: its was S1
                      M569 P1 S0 ; Drive 1 goes backwards blv: its was S1
                      M569 P2 S0 ; Drive 2 goes forwards
                      M569 P3 S1 ; Drive 3 goes backwards WAS 0
                      M569 P4 S0 ; Drive 4 goes forwards
                      M584 X0 Y1 Z2:4 E3 ; set drive mapping
                                   ; ===================== Drive Settings =====================
                      M92 X200.00 Y200.00 Z800 E714.36 ; Set steps per mm for orbiter
                      ;M566 X600 Y600 Z800 E600 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
                      M203 X20000 Y20000 Z600 E7200 ; Set maximum speeds (mm/min)
                      ;M201 X1000 Y1000 Z100 E600 ; Set accelerations (mm/s^2)
                      M906 X1500 Y1500 Z1000 E500 I10 ; Set motor currents (mA) and motor idle factor in per cent
                      ;M84 S30 ; Set idle timeout
                      M566 X600 Y600 Z800 E1200
                      M201 X1000 Y1000 Z800 E1200
                      ;M203 E3600 or E7200 ;max speed mm/min
                      ;M566 E600 ;instantaneous speed change mm/min
                      ;M201 E600 or E800 ;acceleration mm/s^2
                      ;M906 E500 or E1200 I10 ;motor current mA idle current 10%
                      ; ===================== Axis Limits ========================
                                                 ; ======================== Tools ===========================
                      M563 P0 S"T0" D0 H1 F1 ; Define tool 0
                                                ; ========================= Fans ===========================
                      ;hotend fan/ hotend
                      M106 P1 S1 H1 C"hotend" T45 ; set fan 1 value. Thermostatic control is turned on 100% at 45deg
                      ;Tool Fan/ Layer Fan
                      M106 P0 S0.5 H-1 C"buse" ; set fan 0 value. Thermostatic control is turned off
                      ;MB cooling fan layer
                      M950 F2 C"fan2" Q250 ;H-1 ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 S0.10 H-1 F250 C"AC alimentation" ; set fan 2 value. Thermostatic control is turned off
                                                  ; ===================== Custom settings ====================
                      ;M572 D0 S0.02 ;pressure advance - you may need to finetune it
                      ;M207 S1.5 F3600 or F7200 Z0.2 ;firmware retraction
                      M572 D0 S0.01 ;pressure advance Set bowden extruder elasticity compensation for E0
                      M207 S1.5 F3600 Z0.01 ; Set firmware retraction parameters
                      M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                                                               ; Scanner support (debug)
                      ;M750
                                                         ; Set up DHT sensor on channels 101-102
                      ;M305 P101 X405 S"DHT temperature" T11
                      ;M305 P102 X455 S"DHT humidity [%]" T11
        ; Automatic power saving
                      M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                                 ; ====================== Miscellaneous =====================
                      M500 ; save
                      T0 ; select first tool
                      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                        @jay_s_uk
                        sorry some ask me to take a screenshot.
                          @sgk said in please help me blv setting:
                          the fan defined here should be F0 not F1
                          nothing else looks out of place.
                          which bits do you have issues with?
                          and which firmware version are you running? M115 will tell you
                          A Former User? 2 Replies Last reply Reply Quote 0
                            @jay_s_uk Board: Duet 2 WiFi (2WiFi)
                            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
                            Duet WiFi Server Version: 1.26
                              @jay_s_uk said in please help me blv setting:
                              which bits do you have issues with?I do not understand
                                @sgk what problems are you having?
                                  @jay_s_uk when I print my pieces where the cubes are of a really bad quality even with my cr10 which is not in good condition I have better impression. I have changed a lot of things on my blv and always a shit quality excused me word
                                    @sgk well make the change i suggested here and then print another cube and see how that comes out
                                    https://forum.duet3d.com/topic/26387/please-help-me-blv-setting/11
                                    • jay_s_ukundefined jay_s_uk referenced this topic
                                      @jay_s_uk ok thank you sir jay
                                        @sgk IMG_20211214_175003_edit_44301871742718.jpg IMG_20211214_175015_edit_44289470931262.jpg
                                          @sgk
                                          it’s the same if it’s not worse
                                          • oliofundefined
                                            oliof
                                            Looks like you need to to flow and temperature calibration. Here is a website which may help you with that https://teachingtechyt.github.io/calibration.html
