    please help me blv setting
    129
    7.8k
      jay_s_uk @A Former User
      @sgk said in please help me blv setting:
      M563 P0 S"T0" D0 H1 F1
      the fan defined here should be F0 not F1
      nothing else looks out of place.
      which bits do you have issues with?
      and which firmware version are you running? M115 will tell you
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @jay_s_uk
        @jay_s_uk Board: Duet 2 WiFi (2WiFi)
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
        Duet WiFi Server Version: 1.26
          @jay_s_uk said in please help me blv setting:
          which bits do you have issues with?I do not understand
            @sgk what problems are you having?
              @jay_s_uk when I print my pieces where the cubes are of a really bad quality even with my cr10 which is not in good condition I have better impression. I have changed a lot of things on my blv and always a shit quality excused me word
                @sgk well make the change i suggested here and then print another cube and see how that comes out
                https://forum.duet3d.com/topic/26387/please-help-me-blv-setting/11
                • jay_s_ukundefined jay_s_uk referenced this topic
                  @jay_s_uk ok thank you sir jay
                    A Former User @A Former User
                    @sgk IMG_20211214_175003_edit_44301871742718.jpg IMG_20211214_175015_edit_44289470931262.jpg
                      @sgk
                      it’s the same if it’s not worse
                      • oliofundefined
                        oliof
                        Looks like you need to to flow and temperature calibration. Here is a website which may help you with that https://teachingtechyt.github.io/calibration.html
                          A Former User @oliof
                          @oliof
                          I have done plenty of times😭
                          • oliofundefined
                            oliof @A Former User
                            @sgk you have massive deformation at the bottom of the cube which looks like the heated bed is way too hot, and the extrusion looks very uneven but not spotty/spidery, except for the stringing. Maybe share the gcode file with us (you can upload it) so we can take a look.
                              @oliof
                              the deformation is the fan
                                @sgk xyzCalibration_cube.gcode
                                engikeneerundefined 1 Reply Last reply Reply Quote 0
                                • engikeneerundefined
                                  engikeneer @A Former User
                                  @sgk what material is it that you are printing?
                                  Looking at your gcode file you have set the bed to 90C. That is waaaaay too hot for PLA and I doubt your extruder temp of 195C would be correct if it was PETG or ABS.
                                  Leads me to think that @oliof was right and the deformation at the bottom of the part is because it is too hot and the part is melting!
                                  TYPE:Custom
                                  M104 S195; set extruder temp
                                  M140 S90 ; set bed temp
                                  M109 S195 ; wait for extruder temp
                                  M190 S90 ; wait for bed temp
                                  i3 clone with a bunch of mods
                                  A Former User? 3 Replies Last reply Reply Quote 0
                                    A Former User @engikeneer
                                    but if I have but not 90 it does not adhere to the bed.
                                    pla
                                      @engikeneer
                                      and as we see in the photo it is already peeling off on the corner
                                        @engikeneer I've been fighting for months, I've changed a lot of things but still the same I'm at the end of the line
                                        • oliofundefined
                                          @sgk what is your print surface?
                                            @oliof 350x350mm
