    please help me blv setting
    129
    7.8k
    • oliofundefined
      oliof @A Former User
      @sgk you have massive deformation at the bottom of the cube which looks like the heated bed is way too hot, and the extrusion looks very uneven but not spotty/spidery, except for the stringing. Maybe share the gcode file with us (you can upload it) so we can take a look.
        A Former User @oliof
        @oliof
        the deformation is the fan
          A Former User @A Former User
          @sgk xyzCalibration_cube.gcode
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @A Former User
            @sgk what material is it that you are printing?
            Looking at your gcode file you have set the bed to 90C. That is waaaaay too hot for PLA and I doubt your extruder temp of 195C would be correct if it was PETG or ABS.
            Leads me to think that @oliof was right and the deformation at the bottom of the part is because it is too hot and the part is melting!
            TYPE:Custom
            M104 S195; set extruder temp
            M140 S90 ; set bed temp
            M109 S195 ; wait for extruder temp
            M190 S90 ; wait for bed temp
            i3 clone with a bunch of mods
            A Former User? 3 Replies Last reply Reply Quote 0
              A Former User @engikeneer
              but if I have but not 90 it does not adhere to the bed.
              pla
                @engikeneer
                and as we see in the photo it is already peeling off on the corner
                  @engikeneer I've been fighting for months, I've changed a lot of things but still the same I'm at the end of the line
                  • oliofundefined
                    @sgk what is your print surface?
                      @oliof 350x350mm
                      • oliofundefined
                        oliof
                        what material? painter's tape, PEI, Pertinax, Buildtak,....?
                          @oliof pei
                          • oliofundefined
                            @sgk make sure there is no protective sleeve still on the PEI. Then clean it with Isopropyl Alcohol. Then give it a scuff with steel wool.
                            For PEI the right temperature for PLA is 55-65C. If that doesn't stick there is another issue you will need to fix. 90C is definitely wrong.
                              @oliof I put a new pei plate it may be the same because the aluminum plate is 10mm
                              • oliofundefined
                                oliof
                                depends on where your thermistor sits. But going 90C is still wrong. I would suggest to let the bed soak for 10-15min at 60C then try again.
                                  @oliof ok
                                  • oliofundefined
                                    oliof
                                    Don't forget to reslice with adjusted bed heat settings.
                                      @oliof yes but that has nothing to do with the quality of the piece if
                                      • oliofundefined
                                        oliof
                                        Let's solve one problem at a time. I you don't have proper adhesion, the rest of the print will always look bad no matter what. So that needs fixing first.
                                          @oliof yes ok thank you
                                            @oliof
                                            I put new pei my ca does not adhere to 60 degrees
