    CONSTANT AJAX disconnect errors
    307
    55.1k
      It doesn't really matter. It's probably most useful if you run M122 shortly after the disconnection, and again at the end of the print.
      Also please report your printer geometry, steps/mm and maximum travel speed.
      • mhackneyundefined
        mhackney
        After print completed, reconnected and M122 from DWC:
        MaxReps: 411, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 10976ms, Underruns: 0, 0
        Delta, M92: 800 steps/mm M350: 64 microsteps
        Max travel: X Y Z 7200
        My 3D Printing blog: http://www.sublimelayers.com
        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
          Thanks. The MaxReps is too high, so the step ISR is starving the webserver of CPU cycles. For now, I suggest you reduce either max travel speed or microstepping. When I have implemented dynamically varying microstepping, you will be able to increase them again.
          • mhackneyundefined
            mhackney
            is reducing microsteps to 32 enough? or do I just need to test it?
              Reducing to 32 will probably be enough, but run M122 and check MaxReps again at the end of a print.
                I have created a new wiki page at https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors with suggestions for users who experience this issue.
                I have it on my list to investigate the CPU starvation cause and see what can be done to reduce its impact or at least provide easier diagnosis.
                • mhackneyundefined
                  mhackney
                  Thanks David, will do on the M122.
                  The interesting thing is, how or even IF this would affect idle connectivity? Since changing this, I have not had a disconnect just idling in an hour, whereas I would barely stay connected for 10 minutes up until now.
                    No, this issue should not affect the connection when the printer is not moving, because no step interrupts will be generated. However, I've seen it once when I homed the printer with high microstepping selected, starting with the head close to the bed so that the homing move was a long one.
                    • mhackneyundefined
                      mhackney
                      Odd! I am still connected - over 90 minutes - and until I made that change I've not stayed connected for more than 10 minutes on idle since upgrading to 1.19.2. And this is without homing or anything, just starting up and letting sit.
                      • Jareryundefined
                        Jarery
                        M122 via usb shortly after a disconnect during a print
                        MaxReps: 5, StepErrors: 0, FreeDm: 122, MinFreeDm 120, MaxWait: 246857ms, Underruns: 0, 0
                        WiFi signal strength -38dBm
                        Reconnections 0
                        HTTP sessions: 1 of 8
                          That all looks good, assuming you only ran M122 once so that the MaxReps value was from the whole of the print so far. Did the Ajax error message box give the error reason as Timeout? Were you able to reconnect the web interface?
                          • KeeganBundefined
                            KeeganB
                            Well, I just had the printer on and connected for about 6+ hours, 4 of which were printing. I didn't have a single disconnect from DWC on my computer and was able to connect to it multiple times from my iPhone. That is a night and day difference from when I made this post, where I was getting disconnected every few minutes. I was also plugged into USB the whole time.
                            The only changes I made were changing the channels on my router (the old channels were not auto, and were not defaults though) and fixing my error in my config file for the printer's name and password.
                            My next "test" will be to do similar tomorrow, but with the USB unplugged.
                            Artemis
                            Rostock Max v2
                            Orion
                            • mhackneyundefined
                              mhackney
                              David, here's more information and things are not improving…
                              Shortly after my last post about the printer staying connected for 90 minutes, it disconnected - completely on idle. RSSI was about -81. So I installed the new wifi extender and connected Duet to it. RSSI is now -34 and stable. Every device in my office near the extender has significantly better signal. This was about 9pm yesterday.
                              This morning I checked and the DWC showed still connected. I homed to verify and the printer homed. Then I immediately got a disconnect. I am completely unable to connect after an hour. In Pronterface I ran M122 and it seemed to have stopped responding after partially sending the results. Here's what I got:
                              M221
                              SENDING:M221
                              Extrusion factor override for extruder 0: 100.0%
                              M122
                              SENDING:M122
                              Used output buffers: 32 of 32 (32 max)
                              RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
                              Board ID: 08DAM-999TL-MQ4S8-6J9F6-3SJ6L-T4BBW
                              Static ram used: 21176
                              Dynamic ram used: 96168
                              Recycled dynamic r
                              However, the Home button still functions butafter homing and running M122 again, I get the exact same truncated results shown above. I'm going to reboot and keep an eye on it.
                              • mhackneyundefined
                                mhackney
                                Here's the M122 after the reboot:
                                M122
                                Used output buffers: 3 of 32 (10 max)
                                Dynamic ram used: 96104
                                Recycled dynamic ram: 1504
                                Stack ram used: 1304 current, 5116 maximum
                                Never used ram: 7172
                                Last reset 00:00:22 ago, cause: software
                                Last software reset reason: User, spinning module GCodes, available RAM 6932 bytes (slot 4)
                                Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                Error status: 0
                                Free file entries: 10
                                SD card longest block write time: 0.0ms
                                MCU temperature: min 28.7, current 30.0, max 30.1
                                Supply voltage: min 24.5, current 24.6, max 24.9, under voltage events: 0, over voltage events: 0
                                Driver 0: stalled standstill
                                Driver 1: stalled standstill
                                Driver 2: stalled standstill
                                Driver 3: standstill
                                Driver 4: standstill
                                Date/time: 2017-09-15 09:36:48
                                Slowest main loop (seconds): 0.007894; fastest: 0.000034
                                MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                Bed compensation in use: none
                                Bed heater = 0, chamber heater = -1
                                Heater 1 is on, I-accum = 0.0
                                Segments left: 0
                                Movement lock held by null
                                http is idle in state(s) 0
                                telnet is idle in state(s) 0
                                file is idle in state(s) 0
                                serial is idle in state(s) 0
                                aux is idle in state(s) 0
                                daemon is idle in state(s) 0
                                queue is idle in state(s) 0
                                Code queue is empty.
                                Network state is running
                                WiFi firmware version 1.19.2
                                WiFi MAC address 5c:cf:7f:2b:e6:eb
                                WiFi Vcc 3.10, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 38904
                                WiFi IP address 192.168.1.190
                                WiFi signal strength -50dBm
                                Reconnections 0
                                Socket states: 2 0 0 0 0 0 0 0
                                Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                • Jareryundefined
                                  Jarery
                                  @dc42:
                                  The print was a short one, only 5 min i think, the disconnect happened at about the 2:00 min mark, I ran the M122 command via pronterface at about 2:30 mark.
                                  • I do not recall the Ajax error for that one, I believe it always states the same message. I'll record it next time.
                                  • Unable to reconnect via browser connect button, maybe 20 tries, then reconnected after a wireless module off/ on command (run via paneldue as a macro)
                                  Edit: microsteps are at 16 with interpolation.
                                  • mhackneyundefined
                                    mhackney
                                    After rebooting Duet I started a print. It remained connected and is still connected now after about an hour. Here is the MaxReps after the print completed:
                                    MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 10979ms, Underruns: 0, 0
                                    This is after turning down microsteps from 64 to 32 as you recommended yesterday.
                                    • KeeganBundefined
                                      KeeganB
                                      Well, I spoke too soon.
                                      Yesterday's print was done via DWC over about 3-4 hours with the USB cord plugged in the whole time.
                                      Today I disconnected the USB, connected to DWC, and started a print. before the hot end even finished preheating it has disconnnected and I was unable to reconnect.
                                      M122
                                      SENDING:M122
                                      Used output buffers: 3 of 32 (9 max)
                                      Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
                                      Recycled dynamic ram: 1440
                                      Stack ram used: 4048 current, 9068 maximum
                                      Never used ram: 3220
                                      Last reset 01:43:44 ago, cause: power up
                                      Last software reset reason: User, spinning module GCodes, available RAM 4348 bytes (slot 0)
                                      Error status: 0
                                      [ERROR] Error status: 0
                                      Free file entries: 9
                                      SD card longest block write time: 75.2ms
                                      MCU temperature: min 30.2, current 33.1, max 33.8
                                      Supply voltage: min 11.6, current 11.8, max 12.3, under voltage events: 0, over voltage events: 0
                                      Driver 0: stalled
                                      Driver 1: stalled
                                      Driver 2: stalled
                                      Driver 3: stalled
                                      Date/time: 2017-09-15 19:05:18
                                      Slowest main loop (seconds): 0.104980; fastest: 0.000000
                                      MaxReps: 4, StepErrors: 0, FreeDm: 164, MinFreeDm 144, MaxWait: 962417ms, Underruns: 4, 0
                                      Scheduled moves: 422, completed moves: 403
                                      Bed probe heights: 0.021 -0.103 0.041 0.235 0.119
                                      Heater 0 is on, I-accum = 0.3
                                      Heater 1 is on, I-accum = 0.6
                                      Segments left: 1
                                      Movement lock held by file
                                      file is doing "G1 X7.961 Y8.640 E11.0987" in state(s) 0
                                      serial is ready with "M122" in state(s) 0
                                      WiFi MAC address 5c:cf:7f:ef:51:6f
                                      WiFi flash size 4194304, free heap 39712
                                      WiFi IP address 10.0.1.38
                                      WiFi signal strength -44dBm
                                      Reconnections 0
                                      HTTP sessions: 2 of 8
                                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                      Artemis
                                      Rostock Max v2
                                      Orion
                                      • KeeganBundefined
                                        KeeganB
                                        I just came back to my computer and the Safari window that had DWC in it was up, and it had apparently reconnected itself?
                                        Artemis
                                        Rostock Max v2
                                        Orion
                                          T3P3Tony administrators
                                          Keegan is there a correlation between USB cable plugged in and stability of the connection?
                                          • KeeganBundefined
                                            KeeganB
                                            @T3P3Tony:
                                            I really have no idea. It was a theory I was testing. After a couple days of disconnects I noticed my first successful 4hr print with 6hr connection time was when I was also plugged in to USB. Then the next day I tried it without the USB and got nearly an immediate disconnect. Then about an hour later the same DWC window in Safari had reconnected on its own?! It's been working and connected since then for nearly 10 hours. (No usb)
                                            Artemis
                                            Rostock Max v2
                                            Orion
