    CONSTANT AJAX disconnect errors
    307
    55.1k
    • mhackneyundefined
      mhackney
      is reducing microsteps to 32 enough? or do I just need to test it?
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        Reducing to 32 will probably be enough, but run M122 and check MaxReps again at the end of a print.
          I have created a new wiki page at https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors with suggestions for users who experience this issue.
          I have it on my list to investigate the CPU starvation cause and see what can be done to reduce its impact or at least provide easier diagnosis.
          • mhackneyundefined
            mhackney
            Thanks David, will do on the M122.
            The interesting thing is, how or even IF this would affect idle connectivity? Since changing this, I have not had a disconnect just idling in an hour, whereas I would barely stay connected for 10 minutes up until now.
              No, this issue should not affect the connection when the printer is not moving, because no step interrupts will be generated. However, I've seen it once when I homed the printer with high microstepping selected, starting with the head close to the bed so that the homing move was a long one.
              • mhackneyundefined
                mhackney
                Odd! I am still connected - over 90 minutes - and until I made that change I've not stayed connected for more than 10 minutes on idle since upgrading to 1.19.2. And this is without homing or anything, just starting up and letting sit.
                • Jareryundefined
                  Jarery
                  M122 via usb shortly after a disconnect during a print
                  MaxReps: 5, StepErrors: 0, FreeDm: 122, MinFreeDm 120, MaxWait: 246857ms, Underruns: 0, 0
                  WiFi signal strength -38dBm
                  Reconnections 0
                  HTTP sessions: 1 of 8
                    That all looks good, assuming you only ran M122 once so that the MaxReps value was from the whole of the print so far. Did the Ajax error message box give the error reason as Timeout? Were you able to reconnect the web interface?
                    • KeeganBundefined
                      KeeganB
                      Well, I just had the printer on and connected for about 6+ hours, 4 of which were printing. I didn't have a single disconnect from DWC on my computer and was able to connect to it multiple times from my iPhone. That is a night and day difference from when I made this post, where I was getting disconnected every few minutes. I was also plugged into USB the whole time.
                      The only changes I made were changing the channels on my router (the old channels were not auto, and were not defaults though) and fixing my error in my config file for the printer's name and password.
                      My next "test" will be to do similar tomorrow, but with the USB unplugged.
                      Artemis
                      Rostock Max v2
                      Orion
                      • mhackneyundefined
                        mhackney
                        David, here's more information and things are not improving…
                        Shortly after my last post about the printer staying connected for 90 minutes, it disconnected - completely on idle. RSSI was about -81. So I installed the new wifi extender and connected Duet to it. RSSI is now -34 and stable. Every device in my office near the extender has significantly better signal. This was about 9pm yesterday.
                        This morning I checked and the DWC showed still connected. I homed to verify and the printer homed. Then I immediately got a disconnect. I am completely unable to connect after an hour. In Pronterface I ran M122 and it seemed to have stopped responding after partially sending the results. Here's what I got:
                        M221
                        SENDING:M221
                        Extrusion factor override for extruder 0: 100.0%
                        M122
                        SENDING:M122
                        Used output buffers: 32 of 32 (32 max)
                        RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
                        Board ID: 08DAM-999TL-MQ4S8-6J9F6-3SJ6L-T4BBW
                        Static ram used: 21176
                        Dynamic ram used: 96168
                        Recycled dynamic r
                        However, the Home button still functions butafter homing and running M122 again, I get the exact same truncated results shown above. I'm going to reboot and keep an eye on it.
                        • mhackneyundefined
                          mhackney
                          Here's the M122 after the reboot:
                          M122
                          Used output buffers: 3 of 32 (10 max)
                          Dynamic ram used: 96104
                          Recycled dynamic ram: 1504
                          Stack ram used: 1304 current, 5116 maximum
                          Never used ram: 7172
                          Last reset 00:00:22 ago, cause: software
                          Last software reset reason: User, spinning module GCodes, available RAM 6932 bytes (slot 4)
                          Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                          Error status: 0
                          Free file entries: 10
                          SD card longest block write time: 0.0ms
                          MCU temperature: min 28.7, current 30.0, max 30.1
                          Supply voltage: min 24.5, current 24.6, max 24.9, under voltage events: 0, over voltage events: 0
                          Driver 0: stalled standstill
                          Driver 1: stalled standstill
                          Driver 2: stalled standstill
                          Driver 3: standstill
                          Driver 4: standstill
                          Date/time: 2017-09-15 09:36:48
                          Slowest main loop (seconds): 0.007894; fastest: 0.000034
                          MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                          Bed compensation in use: none
                          Bed heater = 0, chamber heater = -1
                          Heater 1 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is idle in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          Network state is running
                          WiFi firmware version 1.19.2
                          WiFi MAC address 5c:cf:7f:2b:e6:eb
                          WiFi Vcc 3.10, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 38904
                          WiFi IP address 192.168.1.190
                          WiFi signal strength -50dBm
                          Reconnections 0
                          Socket states: 2 0 0 0 0 0 0 0
                          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                          • Jareryundefined
                            Jarery
                            @dc42:
                            The print was a short one, only 5 min i think, the disconnect happened at about the 2:00 min mark, I ran the M122 command via pronterface at about 2:30 mark.
                            • I do not recall the Ajax error for that one, I believe it always states the same message. I'll record it next time.
                            • Unable to reconnect via browser connect button, maybe 20 tries, then reconnected after a wireless module off/ on command (run via paneldue as a macro)
                            Edit: microsteps are at 16 with interpolation.
                            • mhackneyundefined
                              mhackney
                              After rebooting Duet I started a print. It remained connected and is still connected now after about an hour. Here is the MaxReps after the print completed:
                              MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 10979ms, Underruns: 0, 0
                              This is after turning down microsteps from 64 to 32 as you recommended yesterday.
                              • KeeganBundefined
                                KeeganB
                                Well, I spoke too soon.
                                Yesterday's print was done via DWC over about 3-4 hours with the USB cord plugged in the whole time.
                                Today I disconnected the USB, connected to DWC, and started a print. before the hot end even finished preheating it has disconnnected and I was unable to reconnect.
                                M122
                                SENDING:M122
                                Used output buffers: 3 of 32 (9 max)
                                Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
                                Recycled dynamic ram: 1440
                                Stack ram used: 4048 current, 9068 maximum
                                Never used ram: 3220
                                Last reset 01:43:44 ago, cause: power up
                                Last software reset reason: User, spinning module GCodes, available RAM 4348 bytes (slot 0)
                                Error status: 0
                                [ERROR] Error status: 0
                                Free file entries: 9
                                SD card longest block write time: 75.2ms
                                MCU temperature: min 30.2, current 33.1, max 33.8
                                Supply voltage: min 11.6, current 11.8, max 12.3, under voltage events: 0, over voltage events: 0
                                Driver 0: stalled
                                Driver 1: stalled
                                Driver 2: stalled
                                Driver 3: stalled
                                Date/time: 2017-09-15 19:05:18
                                Slowest main loop (seconds): 0.104980; fastest: 0.000000
                                MaxReps: 4, StepErrors: 0, FreeDm: 164, MinFreeDm 144, MaxWait: 962417ms, Underruns: 4, 0
                                Scheduled moves: 422, completed moves: 403
                                Bed probe heights: 0.021 -0.103 0.041 0.235 0.119
                                Heater 0 is on, I-accum = 0.3
                                Heater 1 is on, I-accum = 0.6
                                Segments left: 1
                                Movement lock held by file
                                file is doing "G1 X7.961 Y8.640 E11.0987" in state(s) 0
                                serial is ready with "M122" in state(s) 0
                                WiFi MAC address 5c:cf:7f:ef:51:6f
                                WiFi flash size 4194304, free heap 39712
                                WiFi IP address 10.0.1.38
                                WiFi signal strength -44dBm
                                Reconnections 0
                                HTTP sessions: 2 of 8
                                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                Artemis
                                Rostock Max v2
                                Orion
                                • KeeganBundefined
                                  KeeganB
                                  I just came back to my computer and the Safari window that had DWC in it was up, and it had apparently reconnected itself?
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                    T3P3Tony administrators
                                    Keegan is there a correlation between USB cable plugged in and stability of the connection?
                                    • KeeganBundefined
                                      KeeganB
                                      @T3P3Tony:
                                      I really have no idea. It was a theory I was testing. After a couple days of disconnects I noticed my first successful 4hr print with 6hr connection time was when I was also plugged in to USB. Then the next day I tried it without the USB and got nearly an immediate disconnect. Then about an hour later the same DWC window in Safari had reconnected on its own?! It's been working and connected since then for nearly 10 hours. (No usb)
                                      Artemis
                                      Rostock Max v2
                                      Orion
                                      • KeeganBundefined
                                        KeeganB
                                        The last two failures both happened within minutes of starting a print. I didn't get the diags for the first failure, but interestingly enough it came back online by itself and worked fine until a few seconds after starting the second print. Here is the M122 after the second print and subsequent AJAX failure. I suspect this will come back online again too, sometime in the middle of the print.
                                        M122
                                        SENDING:M122
                                        Used output buffers: 5 of 32 (13 max)
                                        Dynamic ram used: 96280
                                        Recycled dynamic ram: 1328
                                        Stack ram used: 4048 current, 9104 maximum
                                        Never used ram: 3184
                                        Last reset 04:50:44 ago, cause: power up
                                        Error status: 8
                                        [ERROR] Error status: 8
                                        MCU temperature: min 35.7, current 35.9, max 36.2
                                        Supply voltage: min 11.7, current 11.8, max 12.1, under voltage events: 0, over voltage events: 0
                                        Driver 0: stalled
                                        Driver 1: stalled
                                        Driver 2: stalled
                                        Driver 3: stalled
                                        Date/time: 2017-09-16 20:04:42
                                        Slowest main loop (seconds): 0.003906; fastest: 0.000000
                                        MaxReps: 4, StepErrors: 0, FreeDm: 221, MinFreeDm 189, MaxWait: 2ms, Underruns: 0, 0
                                        Scheduled moves: 2311, completed moves: 2306
                                        Bed probe heights: -0.019 -0.083 -0.078 0.096 -0.127
                                        Heater 1 is on, I-accum = 0.4
                                        Segments left: 1
                                        file is doing "G1 X25.168 Y2.626 E93.1502" in state(s) 0
                                        WiFi Vcc 3.11, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 39392
                                        WiFi signal strength -46dBm
                                        Reconnections 1
                                        Artemis
                                        Rostock Max v2
                                        Orion
                                          Thanks. I can't see anything wrong in the M122 report. it's interesting that you have a a reconnection count of 1 indicating that the WiFi module became disconnected from the router and successfully connected again, even though you have a very high signal strength.
                                          • KeeganBundefined
                                            KeeganB
                                            David,
                                            I think I have established a bit of a pattern in my situation. It seems that right at the beginning of every new print, it disconnects. Then sometime after that (I estimate between 15-30mins) it just reconnects itself and is fine from then until I start the next print.
                                            Artemis
                                            Rostock Max v2
                                            Orion
