    Duet Maestro BL-Touch Not working
    638
    • simplesimsonundefined
      simplesimson
      i have changed from using the IR-Probe to BL-Touch. Did not buy the clone.
      I cant get it to be working.
      Running version 2.05
      Situation: I turn on the 3d printer and the probe delpoys and retracts itself two times.
      Than it stays retracted. Reading in DWC of z probe shows value of 0. Also if i pull on the probe it does not change.
      I can not deploy the probe nor can i retract it.
      I have created the deployprobe.g and retractprobe.g and copy pasted the gcode in.
      did read an follow this:
      The M307 line is not required
      In all M280 commands, use P64 instead of P3, and leave out the I1. This applies to the following section too.
      Thoughts: Is my m558 set right?
      Here is my config.g file:
      ; Configuration file for Duet Maestro (firmware version 2.03)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"CoreXY"                                     ; set printer name
      M667 S1                                            ; select CoreXY mode
      M918 P1 E4 F2000000                                ; configure direct-connect display
      M552 S1  P192.168.1.29                                 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      M569 P0 S0                                         ; physical drive 0 goes forwards
      M569 P1 S0                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      ;steps
      M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
      M92 X160 Y160 Z400.00 E415                     ;E409.54                ; set steps per mm
      ;speeds
      M566 X600.00 Y600.00 Z24.00 E120.00                 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z300.00 E12000.00            ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E1500.00                ; set accelerations (mm/s^2)
      ;motorcurrent
      M906 X900 Y900 Z400 E900 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X-10 Y0 Z0 S1                                  ; set axis minima
      M208 X300 Y300 Z340 S0                             ; set axis maxima
      M574 X1 Y2 S1                                      ; set active high endstops
      M574 Z1 S2                                         ; set endstops controlled by probe
      ; Z-Probe - old for IR PRobe was working 12-12-21
      ;M558 P1 R0.5 F150 T9000 H3 A1                              ; set Z probe type to unmodulated and the dive height + speeds
      ;G31 P500 X-2 Y-20 Z1.67                       ; set Z probe trigger value, offset and trigger height - Z wert bestimmt den wert, den die Z achse nach auslösen des sensors ;mit der Nozzle näher an tisch fährt. -> wert größer ist näher dran
      ;M557 X15:280 Y20:270 P9:9                          ; define mesh grid
      ;Z-Probe setup for BLtouch
      M558 P9 H5 F100 T2000
      G31 X0 Y55 Z0 P25
      ;heaters
      ;BED
      M305 P0 T98801 B4185 R2200              		; set thermistor for bend
      M143 H0 S120  						; max temp
      ;E0
      M305 P1 B4725 C7.060000e-8	                    	; Set thermistor
      M143 H1 S280                                      	 ; Set temperature limit for heater 1 to 260C
      M106 P0 S0 I0 F500
      M106 P2 S1 I0 F500 H1 T45
      M563 P0 D0 H1 F0                                   ; define tool 0 P0 tool number - S"1" tool "name" - D"0" Extruder Drive "0" - H1 heater 							;number 1 - Fan number 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M501                                               ; load saved parameters from non-volatile memory see configoverride.g
        simplesimson
        @simplesimson said in Duet Maestro BL-Touch Not working:
        Wrong category sorry - cant find the edit for this .
        simplesimsonundefined 1 Reply Last reply Reply Quote 0
          simplesimson @simplesimson
          when I set up a new config with the config tool to create a new config from scretch the configtool tells me:
          Make sure you change it to use +3.3V instead of +5V before you connect it or you risk damaging your board!
          Contrary to https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch where the 5V is connected.
          Still the rest remains the same and the error unsolved. Really would apreciate help.
          Is it correct that the BLtouch does the retracting move twice on boot up? Knowing this alone would mean much to me.
            simplesimson
            I would like to try wiring the BLTouch to the Z-Endstops and the servo part of the BL-Touch to a different PWM port. Any suggestions how to proceed?
            After about 12h of fiddeling around and setting up the hole printer up from scretch I cant find any other solution than that my Ports on the board must be fried.
              Phaedrux Moderator @simplesimson
              Yes it does.
              Sounds correct for meastro. Can you share what you actually have?
              ;Z-Probe setup for BLtouch M558 P9 H5 F100 T2000 G31 X0 Y55 Z0 P25
              Looks ok.
              You won't need to worry about this.
              How do you actually have it wired up?
              It should look like this.
                simplesimson
                @Phaedrux thanks for your help!
                @phaedrux said in Duet Maestro BL-Touch Not working:
                Yes it does.
                Looks ok.
                my debug steps yesterday evening:
                that is how i did wire it up. I connected both grounds near the bltouch and. I have tested the leads from the connector all the way to the bltouch - with good result.
                tryed to test the probes integrity:
                The power on Self test by the probe always seems to work.
                If i disconnect the yellow wire i also can provoke the blue light to shine. Indicating the yellow wire error.
                The Probe stays retracted after it selftest, the light on the probe´s red LED is on. if i pull the pin out - so deploy it manually - the red light turns off. The value of the Z-Probe in DWC always reports 0 (retraced deployed no difference).
                If it reports 0 and not 1000 means that something returns a valid value?
                1. antclaps says that S60 should turn of alarm and deploy - also s160 should turn of alarm and deploy read here: https://www.antclabs.com/bltouch-v3 (end of first third of page)
                  also tryed the 3,3 V setup
                2. tryed the 240ohms resistor between pin 1 and two of the duet, so input/ground - no difference with 5V. With 3,3 V setup it than does not complete its selftest and blinks red.
                  Still returning z-probe =0
                3. complete! new firmware flash onto new SD-Card with config file directly from configtool - exaclty the same. repeated step 1 to 5 with new firmware. No changes whatsoever.
                4. very disappointed bad nights rest 😞 because i didnt get my victory beer
                Do you have any ideas what i could test?
                  @nukapop92 said in Duet Maestro BL-Touch Not working:
                  i got same problem, anyone here can tell me how can i solve this
                  Start a new thread please.
                    Pulling the pin out isn't the same as deploying it. Pulling it out would cause an error state. There is an electromagnet that actions the deployment.
                    This is expected. The probe only triggers when it's been properly deployed and even then the value is only active for a very brief moment before it resets and retracts the pin. If you disconnect the white wire you may be able to see the value change to 1000.
                    Not necessary for BLtouch beyond V1 or with the Maestro.
                    Can you please show the contents of deployprobe.g and retractprobe.g?
                    Can you send M122 and M98 P"config.g" and post the results?
                    simplesimsonundefined 1 Reply Last reply Reply Quote 1
                      simplesimson @Phaedrux
                      okay understood. - should the probe be pulled up by the magnet when my hand releases the pin? Or is it just held in the upper position?
                      Roger. changes to 1000 when i pull the white wire.
                      0:/sys/deployprobe.g
                      M280 P64 S10
                      0:/sys/retractprobe.g
                      M280 P64 S90
                      config-override.g
                      ; config-override.g file generated in response to M500 at 2021-03-18 13:33
                      ; Heater model parameters
                      M307 H0 A115.7 C497.7 D1.7 S0.50 V23.6 B0
                      M307 H1 A501.6 C178.0 D4.0 S1.00 V23.7 B0
                      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                      M122
                      M122
                      RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
                      Board ID: 08DJM-956DU-LL3SW-6J9F2-3SJ6T-KVHGR
                      Used output buffers: 3 of 24 (6 max)
                      Static ram: 19804
                      Dynamic ram: 91112 of which 56 recycled
                      Exception stack ram used: 204
                      Never used ram: 19896
                      Tasks: NETWORK(ready,764) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 00:06:11 ago, cause: software
                      Last software reset at 2021-12-15 09:25, reason: User, spinning module GCodes, available RAM 23676 bytes (slot 3)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      Error status: 0
                      Free file entries: 10
                      SD card 0 detected, interface speed: 15.0MBytes/sec
                      MCU temperature: min 38.4, current 38.7, max 39.0
                      Supply voltage: min 0.0, current 20.2, max 20.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                      Driver 1: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                      Driver 2: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                      Driver 3: standstill, read errors 0, write errors 1, ifcount 13, reads 14847, timeouts 16
                      Driver 4: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 14869
                      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 14869
                      Slowest loop: 4.83ms; fastest: 0.05ms
                      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                      === DDARing ===
                      Bed heaters = 0, chamberHeaters = -1 -1
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      lcd is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 7.25ms; fastest: 0.02ms
                      HTTP sessions: 1 of 8
                      Interface state 5, link 100Mbps full duplex
                      M98 P"config.g"
                      M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is enabled on port 21
                      TELNET is enabled on port 23
                      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 526C.
                      Do you have any idea how i can test if the servo output is still working? i guess if the servo out would not work the hole probe would not show a different behavior?
                        simplesimson
                        @Phaedrux I made progress.
                        I have tryed around. Now I am able to deploy the probe. But:
                        I had to change this:
                        M558 P9 H5 F120 T6000     I1
                        so i have inverted the signal by the probe. meaning it shows 1000 when it is retracted.
                        However: when i deploy it with M401 it still reads 1000, if i touch it ever so slightly it goes to 0. Ideas?
                        New M122:
                        M122
                        Static ram: 19804
                        Tasks: NETWORK(ready,1220) HEAT(blocked,1328) MAIN(running,3896) IDLE(ready,160)
                        Owned mutexes:
                        Last reset 00:01:33 ago, cause: software
                        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 19888 bytes (slot 2)
                        Error status: 0
                        MCU temperature: min 39.3, current 39.5, max 40.0
                        Driver 0: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                        Driver 1: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                        Driver 2: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                        Driver 3: standstill, read errors 0, write errors 1, ifcount 48, reads 3726, timeouts 3
                        Driver 4: standstill, read errors 0, write errors 1, ifcount 48, reads 3729, timeouts 0
                        Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3735
                        Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3735
                        Slowest loop: 2.87ms; fastest: 0.05ms
                        === DDARing ===
                        Segments left: 0
                        === Network ===
                        Slowest loop: 4.16ms; fastest: 0.02ms
                        EDIT: Idea: i could do a dirty workaround by changing the deployprobe.g with a M558 I0 so that the probe reads 0 when being deployed. As soon as it retracts the retractprobe.g needs to swap to M558 I1 to change the value to 1000 when being retracted.
                          The deploy state and trigger state of the probe are not related. You're focusing on the 0/1000 reading too much. It doesn't matter. It's only relevant during an actual probing move and even then, it will be so fast you won't be able to see it change. The fact that the reading changes to 1000 when the white wire is removed means it's getting a reading correctly. Change your M558 back to the way it was before the inversion. It should read 0 normally.
                          If you're able to deploy and retract the probe by sending M401 and M402 that's great. The next step is to test if the probe will deploy and trigger with an actual G30.
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                            If i change it back i can not deploy. I think this is because it thinks it is already deployed? As the signal reads 0 isnt this the feedback for beeing deployed?
                            atm I am able to print - so do everything including leveling by using the I0 in my deployprobe.g. Meaning as soon as it gets deployed i turn the inversion off.
                            As soon as i retractprobe.g I again turn it back on with I1.
                            Leaving any of the inversion (I0 or I1) out results in total malfunction.
                            It is a very dirty work around but i dont know how to skip it. Do i understand you correct. The probe returns 0 when retracted? If so it only returns 1000 for the split second its triggerd somewhere in the middle of its stroke?
                              No.
                              I don't understand what this means.
                              No. As I said, you're focusing too much on the trigger state read out of 0 or 1000. Normally it should read 0. The only time it would change to 1000 is the split second when the deployed pin contacts the bed. It resets immediately to 0. You may not see it change in the DWC display at all.
                              Your config,g should have
                              M558 P9 H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                              ; deployprobe.g
                              ; called to deploy a physical Z probe
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:48:53 GMT-0600 (Central Standard Time)
                              M280 P64 S10 ; deploy BLTouch
                              ; retractprobe.g
                              ; called to retract a physical Z probe
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:49:09 GMT-0600 (Central Standard Time)
                              M280 P64 S90 ; retract BLTouch
                              And your homing file should have something like
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:49:38 GMT-0600 (Central Standard Time)
                              G1 H2 Z5 F6000          ; lift Z relative to current position
                              G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 H2 X5 Y5 F6000       ; go back a few mm
                              G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                              G90                     ; absolute positioning
                              G1 X15 Y15 F6000        ; go to first bed probe point and home Z
                              G30                     ; home Z by probing the bed
                              Use the procedures shown here to test that it's all working correctly.
                              M401 and M402 should deploy and retract the pin.
                              G30 should deploy the pin and start the z axis moving.
                              Touching the pin at that point should stop movement.
