    Duet Maestro BL-Touch Not working
    638
    • simplesimsonundefined
      simplesimson
      I would like to try wiring the BLTouch to the Z-Endstops and the servo part of the BL-Touch to a different PWM port. Any suggestions how to proceed?
      After about 12h of fiddeling around and setting up the hole printer up from scretch I cant find any other solution than that my Ports on the board must be fried.
        Phaedrux Moderator @simplesimson
        @simplesimson said in Duet Maestro BL-Touch Not working:
        Is it correct that the BLtouch does the retracting move twice on boot up? Knowing this alone would mean much to me.
        Yes it does.
        In all M280 commands, use P64 instead of P3, and leave out the I1
        Sounds correct for meastro. Can you share what you actually have?
        ;Z-Probe setup for BLtouch M558 P9 H5 F100 T2000 G31 X0 Y55 Z0 P25
        Looks ok.
        Make sure you change it to use +3.3V instead of +5V before you connect it or you risk damaging your board!
        You won't need to worry about this.
        How do you actually have it wired up?
        It should look like this.
          simplesimson
          @Phaedrux thanks for your help!
          @phaedrux said in Duet Maestro BL-Touch Not working:
          Yes it does.
          Looks ok.
          my debug steps yesterday evening:
          that is how i did wire it up. I connected both grounds near the bltouch and. I have tested the leads from the connector all the way to the bltouch - with good result.
          tryed to test the probes integrity:
          The power on Self test by the probe always seems to work.
          If i disconnect the yellow wire i also can provoke the blue light to shine. Indicating the yellow wire error.
          The Probe stays retracted after it selftest, the light on the probe´s red LED is on. if i pull the pin out - so deploy it manually - the red light turns off. The value of the Z-Probe in DWC always reports 0 (retraced deployed no difference).
          If it reports 0 and not 1000 means that something returns a valid value?
          1. antclaps says that S60 should turn of alarm and deploy - also s160 should turn of alarm and deploy read here: https://www.antclabs.com/bltouch-v3 (end of first third of page)
            also tryed the 3,3 V setup
          2. tryed the 240ohms resistor between pin 1 and two of the duet, so input/ground - no difference with 5V. With 3,3 V setup it than does not complete its selftest and blinks red.
            Still returning z-probe =0
          3. complete! new firmware flash onto new SD-Card with config file directly from configtool - exaclty the same. repeated step 1 to 5 with new firmware. No changes whatsoever.
          4. very disappointed bad nights rest 😞 because i didnt get my victory beer
          Do you have any ideas what i could test?
            @nukapop92 said in Duet Maestro BL-Touch Not working:
            i got same problem, anyone here can tell me how can i solve this
            Start a new thread please.
              Pulling the pin out isn't the same as deploying it. Pulling it out would cause an error state. There is an electromagnet that actions the deployment.
              This is expected. The probe only triggers when it's been properly deployed and even then the value is only active for a very brief moment before it resets and retracts the pin. If you disconnect the white wire you may be able to see the value change to 1000.
              Not necessary for BLtouch beyond V1 or with the Maestro.
              Can you please show the contents of deployprobe.g and retractprobe.g?
              Can you send M122 and M98 P"config.g" and post the results?
              simplesimsonundefined 1 Reply Last reply Reply Quote 1
                simplesimson @Phaedrux
                okay understood. - should the probe be pulled up by the magnet when my hand releases the pin? Or is it just held in the upper position?
                Roger. changes to 1000 when i pull the white wire.
                0:/sys/deployprobe.g
                M280 P64 S10
                0:/sys/retractprobe.g
                M280 P64 S90
                config-override.g
                ; config-override.g file generated in response to M500 at 2021-03-18 13:33
                ; Heater model parameters
                M307 H0 A115.7 C497.7 D1.7 S0.50 V23.6 B0
                M307 H1 A501.6 C178.0 D4.0 S1.00 V23.7 B0
                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                G10 L2 P1 X0.00 Y0.00 Z0.00
                G10 L2 P2 X0.00 Y0.00 Z0.00
                G10 L2 P3 X0.00 Y0.00 Z0.00
                G10 L2 P4 X0.00 Y0.00 Z0.00
                G10 L2 P5 X0.00 Y0.00 Z0.00
                G10 L2 P6 X0.00 Y0.00 Z0.00
                G10 L2 P7 X0.00 Y0.00 Z0.00
                G10 L2 P8 X0.00 Y0.00 Z0.00
                G10 L2 P9 X0.00 Y0.00 Z0.00
                M122
                M122
                RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
                Board ID: 08DJM-956DU-LL3SW-6J9F2-3SJ6T-KVHGR
                Used output buffers: 3 of 24 (6 max)
                Static ram: 19804
                Dynamic ram: 91112 of which 56 recycled
                Exception stack ram used: 204
                Never used ram: 19896
                Tasks: NETWORK(ready,764) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:06:11 ago, cause: software
                Last software reset at 2021-12-15 09:25, reason: User, spinning module GCodes, available RAM 23676 bytes (slot 3)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 10
                SD card 0 detected, interface speed: 15.0MBytes/sec
                MCU temperature: min 38.4, current 38.7, max 39.0
                Supply voltage: min 0.0, current 20.2, max 20.2, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                Driver 1: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                Driver 2: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                Driver 3: standstill, read errors 0, write errors 1, ifcount 13, reads 14847, timeouts 16
                Driver 4: standstill, read errors 0, write errors 1, ifcount 13, reads 14863, timeouts 0
                Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 14869
                Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 14869
                Slowest loop: 4.83ms; fastest: 0.05ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Bed heaters = 0, chamberHeaters = -1 -1
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                lcd is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 7.25ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                Interface state 5, link 100Mbps full duplex
                M98 P"config.g"
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is enabled on port 21
                TELNET is enabled on port 23
                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 526C.
                Do you have any idea how i can test if the servo output is still working? i guess if the servo out would not work the hole probe would not show a different behavior?
                  simplesimson
                  @Phaedrux I made progress.
                  I have tryed around. Now I am able to deploy the probe. But:
                  I had to change this:
                  M558 P9 H5 F120 T6000     I1
                  so i have inverted the signal by the probe. meaning it shows 1000 when it is retracted.
                  However: when i deploy it with M401 it still reads 1000, if i touch it ever so slightly it goes to 0. Ideas?
                  New M122:
                  M122
                  Static ram: 19804
                  Tasks: NETWORK(ready,1220) HEAT(blocked,1328) MAIN(running,3896) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 00:01:33 ago, cause: software
                  Last software reset time unknown, reason: User, spinning module GCodes, available RAM 19888 bytes (slot 2)
                  Error status: 0
                  MCU temperature: min 39.3, current 39.5, max 40.0
                  Driver 0: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                  Driver 1: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                  Driver 2: standstill, read errors 0, write errors 1, ifcount 56, reads 3729, timeouts 0
                  Driver 3: standstill, read errors 0, write errors 1, ifcount 48, reads 3726, timeouts 3
                  Driver 4: standstill, read errors 0, write errors 1, ifcount 48, reads 3729, timeouts 0
                  Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3735
                  Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3735
                  Slowest loop: 2.87ms; fastest: 0.05ms
                  === DDARing ===
                  Segments left: 0
                  === Network ===
                  Slowest loop: 4.16ms; fastest: 0.02ms
                  EDIT: Idea: i could do a dirty workaround by changing the deployprobe.g with a M558 I0 so that the probe reads 0 when being deployed. As soon as it retracts the retractprobe.g needs to swap to M558 I1 to change the value to 1000 when being retracted.
                    The deploy state and trigger state of the probe are not related. You're focusing on the 0/1000 reading too much. It doesn't matter. It's only relevant during an actual probing move and even then, it will be so fast you won't be able to see it change. The fact that the reading changes to 1000 when the white wire is removed means it's getting a reading correctly. Change your M558 back to the way it was before the inversion. It should read 0 normally.
                    If you're able to deploy and retract the probe by sending M401 and M402 that's great. The next step is to test if the probe will deploy and trigger with an actual G30.
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    simplesimsonundefined 1 Reply Last reply Reply Quote 0
                      If i change it back i can not deploy. I think this is because it thinks it is already deployed? As the signal reads 0 isnt this the feedback for beeing deployed?
                      atm I am able to print - so do everything including leveling by using the I0 in my deployprobe.g. Meaning as soon as it gets deployed i turn the inversion off.
                      As soon as i retractprobe.g I again turn it back on with I1.
                      Leaving any of the inversion (I0 or I1) out results in total malfunction.
                      It is a very dirty work around but i dont know how to skip it. Do i understand you correct. The probe returns 0 when retracted? If so it only returns 1000 for the split second its triggerd somewhere in the middle of its stroke?
                        No.
                        I don't understand what this means.
                        No. As I said, you're focusing too much on the trigger state read out of 0 or 1000. Normally it should read 0. The only time it would change to 1000 is the split second when the deployed pin contacts the bed. It resets immediately to 0. You may not see it change in the DWC display at all.
                        Your config,g should have
                        M558 P9 H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                        ; deployprobe.g
                        ; called to deploy a physical Z probe
                        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:48:53 GMT-0600 (Central Standard Time)
                        M280 P64 S10 ; deploy BLTouch
                        ; retractprobe.g
                        ; called to retract a physical Z probe
                        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:49:09 GMT-0600 (Central Standard Time)
                        M280 P64 S90 ; retract BLTouch
                        And your homing file should have something like
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 16 2021 14:49:38 GMT-0600 (Central Standard Time)
                        G1 H2 Z5 F6000          ; lift Z relative to current position
                        G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X5 Y5 F6000       ; go back a few mm
                        G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                        G90                     ; absolute positioning
                        G1 X15 Y15 F6000        ; go to first bed probe point and home Z
                        G30                     ; home Z by probing the bed
                        Use the procedures shown here to test that it's all working correctly.
                        M401 and M402 should deploy and retract the pin.
                        G30 should deploy the pin and start the z axis moving.
                        Touching the pin at that point should stop movement.
