    PINDA leveling sensor
    2.7k
    • oliofundefined
      oliof
      Both PINDA and SuperPINDA (and it's various look-a-likes sold under various names) are supported. Wiring is simpler because you don't need the servo. https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe claims that an inductive probe is about as precise as a BLTouch.
      With a PEI sheet you need to make sure to choose a probe with 4mm sensing distance so it can accomodate for the thickness of the PEI and still have clearance to the top of the print.
      PS: If you buy a cheap unbranded inductive probe, all bets are off. I got locky with a 6EUR probe that runs well on 5v, but not all do.
      PPS: Since Prusa doesn't sell the SuperPINDA except as a replacement part for verified Prusa Owners, look for vonwanges VINDA which is the same OEM part (-:
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @oliof
        @oliof said in PINDA leveling sensor:
        excellent thanks
          I can't find the vonwanges VINDA you mentioned... have you got a link where I can buy it?
          • oliofundefined
            oliof
            https://vonwange.com/product/inductive-probe-aka-vinda/
              got it! thanks
              • FrankVundefined
                FrankV @A Former User
                @thedragonlord I would suggest buying the superPinda. It needs no temperature compensation. For the Pinda V2 the Z-offset needs to be compensated for temperature if you print higher temp.
                Don't forget your metal sheet when doing home. The probe needs metal to stop. Your hotend will push itself on to the bed.
                You can read some here https://forum.duet3d.com/topic/26298/hidden-z-offset-duet3?_=1639652131487
                • oliofundefined
                  oliof @FrankV
                  @frankv the SuperPINDA and the VINDA are the same OEM part (-:
                  FrankVundefined 1 Reply Last reply Reply Quote 0
                  • FrankVundefined
                    FrankV @oliof
                    @oliof You got the pindaV2 and superPinda. In China they sell the V2 and you can get confused. If you order the pinda from Prusa you get the superPinda correct.
                    • oliofundefined
                      oliof @FrankV
                      @frankv Vonwange is not a random Chinese shop and I am not talking about the v2. Stop claiming nonsense about what I said.
                      • FrankVundefined
                        FrankV @oliof
                        @oliof I was speaking in general not in relation to your remark VINDA. So I didn't try to correct you. I was just mention my recent experience with Pinda V2. Have a great day.
                        • oliofundefined
                          oliof @FrankV
                          @frankv Alright, sorry for the misunderstanding -- have a good one (-:
                            A Former User
                            Thanks to everybody. I've ordered the VINDA!
                            Thanks!
                              I've bought it but now I don't understand a thing..the VINDA works with 5V but the Duet2WiFi seems to have only 3,3V for the sensor....do I need a stepup?
                              martin7404undefined 1 Reply Last reply Reply Quote 0
                              • martin7404undefined
                                martin7404 @A Former User
                                @thedragonlord You just wire 5V from let's say EXP on duet board. And wire GND and signal to the end stop or probe conectors on duet
                                Muldex IDEX Duet2+Duex5
                                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                Sapphire Pro with Duet2, with closed-loop motors
                                custom high temp E3D tool changer with Duet2+Duex
                                  A Former User @martin7404
                                  @martin7404 said in PINDA leveling sensor:
                                  stupid me, it's obvious....thanks!
                                  • oliofundefined
                                    oliof @A Former User
                                    @thedragonlord If you're not using the paneldue, the paneldue header is right next to the probe header and offers 5V:
                                    • Gixxerfastundefined
                                      Gixxerfast
                                      Speaking of SuperPinda and Vinda. This is an alternative. Check the data sheet 🙂
                                      https://caribou3d.com/en/sensors/762-9796-caribou-superpinda-probe-sensor-for-3d-printers.html#/220-superpindacable-1m_duet_connector
                                      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                                      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                                      Ender 3 Pro with BTT SKR-2 + RRF
                                        I use panel due
                                          A Former User @Gixxerfast
                                          @gixxerfast said in PINDA leveling sensor:
                                          https://caribou3d.com/en/sensors/762-9795-caribou-superpinda-probe-sensor-for-3d-printers.html#/219-superpindacable-1m_4_pin_molex_connector
                                          Are the dimensions the same than the Vinda's?
                                          Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                                            Gixxerfast @A Former User
                                            @thedragonlord The Caribou seems shorter. I have a Vinda here somewhere. I'll measure it. Un momento ...
                                            Nope, they are the same lenghth 35 mm. Same manufacturer Pepperl+Fuchs-Gruppe
