    PINDA leveling sensor
    2.8k
    • oliofundefined
      oliof @FrankV
      @frankv Vonwange is not a random Chinese shop and I am not talking about the v2. Stop claiming nonsense about what I said.
      FrankVundefined 1 Reply Last reply Reply Quote 0
      • FrankVundefined
        FrankV @oliof
        @oliof I was speaking in general not in relation to your remark VINDA. So I didn't try to correct you. I was just mention my recent experience with Pinda V2. Have a great day.
        • oliofundefined
          oliof @FrankV
          @frankv Alright, sorry for the misunderstanding -- have a good one (-:
            A Former User
            Thanks to everybody. I've ordered the VINDA!
            Thanks!
              A Former User @oliof
              @oliof said in PINDA leveling sensor:
              https://vonwange.com/product/inductive-probe-aka-vinda/
              I've bought it but now I don't understand a thing..the VINDA works with 5V but the Duet2WiFi seems to have only 3,3V for the sensor....do I need a stepup?
              martin7404undefined 1 Reply Last reply Reply Quote 0
              • martin7404undefined
                martin7404 @A Former User
                @thedragonlord You just wire 5V from let's say EXP on duet board. And wire GND and signal to the end stop or probe conectors on duet
                Muldex IDEX Duet2+Duex5
                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                Sapphire Pro with Duet2, with closed-loop motors
                custom high temp E3D tool changer with Duet2+Duex
                  A Former User @martin7404
                  @martin7404 said in PINDA leveling sensor:
                  stupid me, it's obvious....thanks!
                  • oliofundefined
                    oliof @A Former User
                    @thedragonlord If you're not using the paneldue, the paneldue header is right next to the probe header and offers 5V:
                    • Gixxerfastundefined
                      Gixxerfast
                      Speaking of SuperPinda and Vinda. This is an alternative. Check the data sheet 🙂
                      https://caribou3d.com/en/sensors/762-9796-caribou-superpinda-probe-sensor-for-3d-printers.html#/220-superpindacable-1m_duet_connector
                      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                      Ender 3 Pro with BTT SKR-2 + RRF
                        I use panel due
                          A Former User @Gixxerfast
                          @gixxerfast said in PINDA leveling sensor:
                          https://caribou3d.com/en/sensors/762-9795-caribou-superpinda-probe-sensor-for-3d-printers.html#/219-superpindacable-1m_4_pin_molex_connector
                          Are the dimensions the same than the Vinda's?
                          Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                            Gixxerfast @A Former User
                            @thedragonlord The Caribou seems shorter. I have a Vinda here somewhere. I'll measure it. Un momento ...
                            Nope, they are the same lenghth 35 mm. Same manufacturer Pepperl+Fuchs-Gruppe
                              excellent thanks I just need the lenght of the "cylinder"
                                @thedragonlord See above. Same length 35 mm
                                Gixxerfastundefined A Former User? 2 Replies Last reply Reply Quote 0
                                  Gixxerfast @Gixxerfast
                                  @gixxerfast Also I may warn that some report that they don't work reliably when enclosed in about 50C ambient near bed and hotend (Voron) but that's maybe a special use case IDK 🙂
                                    thanks
                                      uh... I'm designing the support to be as close as possibile to the Volcano heatblock... could be an issue? The printer isn't boxed and I usually print PETG so 240 nozzle and 75 the bed...
                                        @thedragonlord said in PINDA leveling sensor:
                                        Let's see if we can ping one opinion at least 🙂 @oc_geek What's your thought of the Vinda close to the hotend, OK?
                                        oc_geekundefined 1 Reply Last reply Reply Quote 0
                                        • oc_geekundefined
                                          oc_geek @Gixxerfast
                                          From my short experience with that probe it needs a quite thermal environment for returning reliable reads (temp ~ constant) and i think it struggles above a certain temp too. In all honesty i stepped away from such a probe... and rather quickly
                                          However i have Voron printer which has a closed / heated chamber and so on... so it might be different in your case.
                                          Personally i do not like it and do not like the very short range of action either. I found alternatives based on microswitch (we call Klicky in Voron context) to be infinitely better...
