    PINDA leveling sensor
    2.8k
      A Former User @oliof
      @oliof said in PINDA leveling sensor:
      https://vonwange.com/product/inductive-probe-aka-vinda/
      got it! thanks
      • FrankVundefined
        FrankV @A Former User
        @thedragonlord I would suggest buying the superPinda. It needs no temperature compensation. For the Pinda V2 the Z-offset needs to be compensated for temperature if you print higher temp.
        Don't forget your metal sheet when doing home. The probe needs metal to stop. Your hotend will push itself on to the bed.
        You can read some here https://forum.duet3d.com/topic/26298/hidden-z-offset-duet3?_=1639652131487
        • oliofundefined
          oliof @FrankV
          @frankv the SuperPINDA and the VINDA are the same OEM part (-:
          FrankVundefined 1 Reply Last reply Reply Quote 0
          • FrankVundefined
            FrankV @oliof
            @oliof You got the pindaV2 and superPinda. In China they sell the V2 and you can get confused. If you order the pinda from Prusa you get the superPinda correct.
            • oliofundefined
              oliof @FrankV
              @frankv Vonwange is not a random Chinese shop and I am not talking about the v2. Stop claiming nonsense about what I said.
              • FrankVundefined
                FrankV @oliof
                @oliof I was speaking in general not in relation to your remark VINDA. So I didn't try to correct you. I was just mention my recent experience with Pinda V2. Have a great day.
                • oliofundefined
                  oliof @FrankV
                  @frankv Alright, sorry for the misunderstanding -- have a good one (-:
                    A Former User
                    Thanks to everybody. I've ordered the VINDA!
                    Thanks!
                      I've bought it but now I don't understand a thing..the VINDA works with 5V but the Duet2WiFi seems to have only 3,3V for the sensor....do I need a stepup?
                      martin7404undefined 1 Reply Last reply Reply Quote 0
                      • martin7404undefined
                        martin7404 @A Former User
                        @thedragonlord You just wire 5V from let's say EXP on duet board. And wire GND and signal to the end stop or probe conectors on duet
                        Muldex IDEX Duet2+Duex5
                        Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                        Sapphire Pro with Duet2, with closed-loop motors
                        custom high temp E3D tool changer with Duet2+Duex
                          A Former User @martin7404
                          @martin7404 said in PINDA leveling sensor:
                          stupid me, it's obvious....thanks!
                          • oliofundefined
                            oliof @A Former User
                            @thedragonlord If you're not using the paneldue, the paneldue header is right next to the probe header and offers 5V:
                            • Gixxerfastundefined
                              Gixxerfast
                              Speaking of SuperPinda and Vinda. This is an alternative. Check the data sheet 🙂
                              https://caribou3d.com/en/sensors/762-9796-caribou-superpinda-probe-sensor-for-3d-printers.html#/220-superpindacable-1m_duet_connector
                              Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                              Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                              Ender 3 Pro with BTT SKR-2 + RRF
                                I use panel due
                                  A Former User @Gixxerfast
                                  @gixxerfast said in PINDA leveling sensor:
                                  https://caribou3d.com/en/sensors/762-9795-caribou-superpinda-probe-sensor-for-3d-printers.html#/219-superpindacable-1m_4_pin_molex_connector
                                  Are the dimensions the same than the Vinda's?
                                  Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                                    Gixxerfast @A Former User
                                    @thedragonlord The Caribou seems shorter. I have a Vinda here somewhere. I'll measure it. Un momento ...
                                    Nope, they are the same lenghth 35 mm. Same manufacturer Pepperl+Fuchs-Gruppe
                                      excellent thanks I just need the lenght of the "cylinder"
                                        @thedragonlord See above. Same length 35 mm
                                        Gixxerfastundefined A Former User? 2 Replies Last reply Reply Quote 0
                                          Gixxerfast @Gixxerfast
                                          @gixxerfast Also I may warn that some report that they don't work reliably when enclosed in about 50C ambient near bed and hotend (Voron) but that's maybe a special use case IDK 🙂
                                            thanks
