    Mesh Bed Leveling does not work (Core XY with 2 z-axis motors)
    1.7k
    • rjenkinsgbundefined
      rjenkinsgb
      You have the leadscrew positions defined at Y0 in config, but you probe at Y200 in bed.g
      Something is wrong between those two - the Y coordinates should match?
      I think the probe points should be dead in line with the leadscrews and as close as possible to them, for best levelling accuracy.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      buckkerundefined 1 Reply Last reply Reply Quote 0
      • buckkerundefined
        buckker @rjenkinsgb
        @rjenkinsgb
        Yes, you're right. of course the values should match. I changed it to Y200 in the config.g. Thanks!
        • JoergS5undefined
          JoergS5 @buckker
          @buckker said in Mesh Bed Leveling does not work (Core XY with 2 z-axis motors):
          G28 ; home M401 ; deploy Z probe (omit if using bltouch) G30 P0 X10 Y200 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X390 Y200 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors M402 ; retract probe (omit if using bltouch)
          there is a comment in bed.g to remove M401 and M402 lines if you use the BLTouch and according to config.g you're using BLTouch, so I would remove the lines. BLTouch deploys and retracts himself by running deployprobe.g and retractprobe.g (please check them).
          If you don't have retractprobe.g and deployprobe.g, the content is described in https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch (one M280 line each).
          • buckkerundefined
            buckker @JoergS5
            @joergs5
            I removed the unnecessary commands. But it don't make any difference.
            The probing works normal. I can also see the height map. But the printer does not use the height map during the print...
            • JoergS5undefined
              JoergS5 @buckker
              @joergs5
              while probing/mesh compensation printing after probing, and you make M122, it is reported whether mesh compensation is active:
              Did you make your M122 while you probed and if not, can you please check it?
              I would call a T0 to select the tool, then G29. => you're right @rjenkinsgb G29 S0 (although G29 withoug mesh.g runs G29 S0 automatically)
                rjenkinsgb
                Try changing G29 in your start code to either G29 S0 (create new heightmap) or G29 S2 (load existing heightmap)
                I must admit, the mesh levelling is the one problem I'm still trying to work through in my dual Z drive CoreXY toolchanging machine - though that's a probe problem to do with creating it accurately rather than it working or not.
                Robert J.
                • buckkerundefined
                  buckker @rjenkinsgb
                  @rjenkinsgb
                  I tried this several minutes ago, but It doesn't help:
                  ; generated by PrusaSlicer 2.4.0-beta1+win64 on 2021-12-22 at 12:54:39 UTC
                  ; external perimeters extrusion width = 0.45mm
                  ; perimeters extrusion width = 0.45mm
                  ; infill extrusion width = 0.45mm
                  ; solid infill extrusion width = 0.45mm
                  ; top infill extrusion width = 0.40mm
                  ; first layer extrusion width = 0.45mm
                  M107
                  ;TYPE:Custom
                  G29 S2;
                  M140 S55; set bed temp
                  M190 S55; wait for bed temp
                  G32
                  M104 S220; set extruder temp
                  G29 S0;
                  G1 Z30 F5000;
                  G1 X10 Y0 F30000;
                  M109 S220; wait for extruder temp
                  G29 S1;
                  G92 E0 ; reset extrusion distance
                  G1 Z10 F1000;
                  G1 X50 Z1 F1000;
                  G1 X100 Z0.4 F1000 E15;
                  G1 X200 F1000 E22;
                  G21 ; set units to millimeters
                  G90 ; use absolute coordinates
                  M82 ; use absolute distances for extrusion
                  G92 E0
                  M572 D0 S0.05;
                  M107
                  ;LAYER_CHANGE
                  ;Z:0.2
                  ;HEIGHT:0.2
                  G1 E-1.2 F3600
                  G92 E0
                  G1 Z.2 F30000
                  G1 Z.4
                  G1 X10.225 Y10.225
                  G1 Z.2
                  G1 E1.2 F3600
                  ;TYPE:External perimeter
                  ;WIDTH:0.45
                  G1 F2100
                  G1 X389.775 Y10.225 E13.53342
                  G1 X389.775 Y389.775 E25.86685
                  G1 X10.225 Y389.775 E38.20027
                  G1 X10.225 Y10.285 E50.53174
                  G1 X10.975 Y10.975 F30000
                  G1 F2100
                  G1 X389.025 Y10.975 E62.81642
                  Clear height map a the begin, probing and at the loading it..
                  • JoergS5undefined
                    JoergS5 @buckker
                    @buckker you have nowhere selected the tool and the slicer doesn't select it too, I would add T0 to the end of config.g
                    I would then try a simple G29 S0 after rebooting and homing, then checking mesh probing status by making M122 while probing.
                    • buckkerundefined
                      buckker @JoergS5
                      @joergs5
                      I checked the following things:
                      M122 during probing:
                      DMs created 83, maxWait 9ms, bed compensation in use: none, comp offset 0.000
                      M122 during printing:
                      DMs created 83, maxWait 18ms, bed compensation in use: mesh, comp offset 0.000
                      this is the tool section from the config..g:
                      M563 P0 S"Dragon Hotend" D0 H1 F0                      ; define tool 0
                      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                      I add a T0 to my g-code file:
                      M107
                      ;TYPE:Custom
                      T0;
                      G32
                      G29 S0;
                      G1 Z30 F5000;
                      G1 X10 Y0 F30000;
                      G1 Z10 F1000;
                      G1 X50 Z1 F1000;
                      G1 X200 F1000 E22;
                      G92 E0
                      M572 D0 S0.05;
                      I will modify the gcode to your ideas.
                      Actually I can't see any z-axis compensating during the print....
                      • JoergS5undefined
                        JoergS5 @buckker
                        @buckker so M122 says that mesh compensation is active.
                        I can think of the following possibilites
                        • the bed is plain enough so you don't see compensation
                        • the probe-nozzle offset is wrong, so the compensation is at the wrong place
                        • printing outside mesh probing M557 X50:350 Y50:350 S50
                        The offset is set at G31 X, Y, Z values. Your values are X0 Y35 Z1.85, which means the BLTouch should be at the same X position and 35 mm behind the nozzle, when you look at the printer and X plus is to the right and Y plus is to the back.
                        For the plain bed, please check the heightmap.csv, it is viewable in the DWC (Duet web control browser application).
                        The mesh was measured starting at (50,50), you may look at the wrong points,
                        • buckkerundefined
                          buckker @JoergS5
                          @joergs5
                          My conclusion after a few tests....:
                          • the printer compensates now some z-axis deviation. I put a dial gauge on the heat bed. I could see, that the z-axis moves during the printing. But the nozzle touches the bed at one corner. At the other corner the first layer is somewhere in the air... It seems that It compensates in the wrong direction... How is this possible? G32 works fine, it compensates in the correct direction.
                          The BL Touch is placed behind the nozzle, only y-axis offset:
                          some other pictures:
                          Heightmap:
                          @joergs5 said in Mesh Bed Leveling does not work (Core XY with 2 z-axis motors):
                          Whats actually happens if I print outside the probing area?
                          JoergS5undefined 4 Replies Last reply Reply Quote 0
                          • JoergS5undefined
                            JoergS5 @buckker
                            @buckker plaese see my last comment from previous post, I added the possibility that the mesh measurement starts at 50,50, so you may have not measured the whole area. Please try to measure the whole M208 area (please be careful, the BLTouch/extruder needs some room...).
                            I cannot remember, whether M557 coordinates refer to the M208 or to the BLTouch positions.
                            • JoergS5undefined
                              JoergS5 @buckker
                              @buckker BTW congratulations using good measurement equipment!
                              • JoergS5undefined
                                JoergS5 @buckker
                                I looked into the source Grid.cpp function GetInterpolatedHeightError(): my understanding is, the last mesh point in this direction is used as reference height. E.g. if (50,50) to (350,350) have mesh points, than for (0,200) the point (50,200) is taken as height.
                                • JoergS5undefined
                                  JoergS5 @buckker
                                  @buckker one more aspect I can think of is if your Z axis is driven by something like a worm drive, that direction changes have some play (backlash). This would cause unexpected movements.
                                  You can check whether there is compensation directly by checking the Z motor position: M114 has a Count value, the third one is the motor position of Z. The counter is set at homing and depends on motor position and M92 value. So you know the firmware's value and not depend on the reality Z position.
                                  • buckkerundefined
                                    buckker @JoergS5
                                    @joergs5
                                    Yes, Tesa really produces very high quality measurement equipment 🙂
                                    I modified the probing area with more points. But it also doesn't help. I also print some smaller test parts (cubic with 280mm x 280mm). With this dimensions the part is 100% in the probed area. Same result...
                                    I also checked with the dial gauge the travel of the z-axis. Both motors compensate some deviation. The direction should be also fine. But it was not able to compare the z-axis absolute travel measured by the dial gauge with the height map. It seems that the printer compensate some deviation, but no enough..
                                    I use a belt driven gearbox for the z-axis (4:1). I will check the backlash of the axis.
                                    actual printing result:
                                    height map for this part:
                                    One thing confused me: at the left front corner, the layer should stick very good (+0.2mm offset), the nozzle should have nearly zero gap without mesh bed compensating (if I print at 0.2mm layer height). But actually the layer is too far away from the build plate... I don't understand this...
                                    I will run a print with disabling mesh bed compensation
                                    • JoergS5undefined
                                      JoergS5 @buckker
                                      is this the reality (bed uneven) or is it a measurement error? A good lineal, best would be a hair lineal, could give you the answer. Or a measuring plate together with your gauge. Or maybe you have an additional linear guide, mounting the gauge, parallel to the bed, allows measuring the bed.
                                      I suspect the two linear guides of Y are not in one plane, too. (left is higher in front, right one is higher in the back). I use feeler gauge for fine tuning. You don't have a reference, however. I would try between 0.1 and 0.2 mm and then decide by bed measuring (mesh probing or gauge).
                                      An additonal topic you can check is whether the bed is sliding smooth enough. I. e. the distance of the two opposite linear guides need to have a little play. Otherwise a direction change of Z stepper will produce a little gap, depending how high the belt tension is. The bed should not be fixed with screws, because bed expansion by temperature will change the distance between the linear guides.
                                      • buckkerundefined
                                        buckker @JoergS5
                                        @joergs5
                                        It's not a measurement error. The aluminium bed is flat (EN AW-5093 precision cast plate, also checked with a lineal). But it's possible to bend the plate with the 4 adjusting screws. For my opinion 0.2mm error for a 400x400mm plate is not that bad.
                                        I have a second printer with a 350x350mm bed and only one z-axis stepper motor (also Duet Wifi equipped, same firmeware version). I tested the bed leveling with the same test part. On this machine the bed leveling works normal and the first layer is perfect over the hole area. The flatness of the bed is around 0.2mm..
                                        After that I compared the start g code from my prusa slicer. I could notice some differences. But for today it's enough tested😵 😵 Maybe I have more luck tomorrow...
                                        • JoergS5undefined
                                          JoergS5 @buckker
                                          Beside firmware, the hardware could produce strange results. One possibility is a stuck bed, if the two opposite linear guides get stuck. This is the only idea I have in addition.
                                          Good luck tomorrow proceeding investigating!
                                            In cases like this where the mesh doesn't appear to be compensating correctly at certain points usually means there is some variance in probe offset between different XY points due to some form of skew. Possibly tilt or sag of the gantry, or skew in the rails from not being perfectly aligned, etc.
                                            One way to check for this is to do a G30 S-1 test at various points on the bed and see how the trigger height results change.
