    Error Short to Ground reported by driver(s)
    57
    3.8k
    • davidewenundefined
      davidewen @Phaedrux
      @phaedrux said in Error Short to Ground reported by driver(s):
      The status light flashing indicates the firmware has been wiped.
      With the previous board I think you had gotten it to show up on the Mac with bootcamp? I suppose that isn't working this time?
      That is correct. Sorry, I said the MB Pro was via Parallels, it's actually BootCamp.
      I have attempted to "reset" the board multiple times. It eventually worked the first go-around, but it's not working this time.
      • Falkiaundefined
        Falkia @Phaedrux
        @phaedrux just one thought, could the communication be interfered by ground loop?
        Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
          Phaedrux Moderator @Falkia
          @falkia only in some cases https://duet3d.dozuki.com/Wiki/USB_ground_loops
            Phaedrux Moderator @davidewen
            @davidewen as last time...
            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
            Sorry for the inconvenience.
            For the new board it would be a good idea to test the usb terminal connection right away to establish that it works reliably with one of your computers.
            davidewenundefined 1 Reply Last reply Reply Quote 0
              davidewen @Phaedrux
              Got board #3.
              Opened box, attached Wi-Fi antennae, attached supplied USB cable, powered up.
              Not recognized by macOS.
              Status of LEDs.
              STATUS = slow flashing red
              5v = solid red
              3.3v = solid green
              ESP = solid green
              Powered on & off multiple times. None of the attempts resulted in recognition by macOS.
              Moved from mac mini M1 computer to Mac Book Pro w/Intel.
              Same results as mac mini.
              Connected via Boot Camp
              Same results
              If I understand correctly, the slow flashing STATUS LED indicates no firmware?
              So, I attempted a 2x fast click of the RESET button.
              STATUS LED quickly flashes. ESP LED goes off.
              After 10 minutes, nothing happened so I 1x clicked the RESET button and board returned to status above.
                Just to confirm, you're following this? https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
                The Duet 3 Mini 5+ supports an easy mechanism for updating the firmware directly.
                Connect the Duet to a PC (Windows, Mac or Linux) using a USB cable
                Press the Reset button twice quickly in succession. The Status LED should cycle slowly between dim and bright. This indicates that the bootloader is active.
                A new Mass Storage device should appear on the PC. Identify its drive letter (Windows) or mount path (Linux).
                A directory listing of this mass storage device should show three virtual files. File CURRENT.UF2 is the existing firmware on the Duet.
                Copy the new Duet3Firmware-Mini5plus.uf2 file to the mass storage device
                The Status LED will flicker as the firmware is being written, then the Duet will reboot using the new firmware. The mass storage device will disappear from your PC and the Duet 3 COM port will appear.
                Also, the boards ship with firmware already applied and are tested before going out to vendors. There should be no need to wipe or reflash firmware out of the box.
                davidewenundefined 2 Replies Last reply Reply Quote 0
                  davidewen @Phaedrux
                  I've attempted to follow the FW instructions, but the board just isn't recognized, even with BOSSA and 2x quick press of the RESET button.
                  I even wrote the DuetWiFiServer.bin file to a blank SD card to see if that would work.
                  These are the computers I've attempted to connect this board to.
                  None recognize the board in system/device manager or as a storage device.
                  Mac mini (M1, 2020)
                  Mac mini (M1, 2020) via Parallels with Windows 11 ARM
                  MacBook Pro (13-inch, 2017)
                  MacBook Pro (13-inch, 2017) via BootCamp with Windows 10
                  Mac Pro 2013
                  Mac Pro 2013 with Windows 10 Pro via BootCamp
                  MacBook Pro (13-inch, Mid 2009)
                  MacBook Pro (13-inch, Mid 2009) with Windows 10 Pro via BootCamp
                  Raspberry pi 3B+
                    davidewen @Phaedrux
                    I did not purposefully or accidentally wipe or reflash the FW. (initially) Once the board was not detected after multiple on/offs, I did 2x click the RESET button to attempt connection that way.
                    This is the 2nd board I have received with this problem.
                    Out of the box = no connectivity.
                    Out of the box, connect to USB, STATUS LED slowly flashes red, 5v LED on, 3.3v LED on, Wi-Fi LED on.
                    I would be happy to:
                    Do a screen share to work together to solve the problem
                    Send you this board so you can test it.
                    I don't know what else I can do on my end.
                      @davidewen said in Error Short to Ground reported by driver(s):
                      Bossa doesn't work with the mini5+. The 2x quick presses of the reset button are required to make the board show up as a USB storage device in finder. Then you copy the firmware file onto that drive to write it.
                      Can you confirm that's where you're looking?
                        davidewen @Phaedrux
                        Yes, 2x press of the RESET button causes the STATUS LED to quickly flash, but Bossa does not recognize the board.
                        It does not show up in Device Manager or as a USB device.
                        I will however double check when I get home this afternoon.
                          You cannot use bossa with the Mini5+ to flash the firmware. That just won't work.
                          When the reset button has been pushed twice the board turns into a USB thumb drive that shows up in windows explorer or finder etc as a usb storage device. You can then copy the firmware there.
                            davidewen @Phaedrux
                            Using Bossa and 2x the RESET button does not show the USB in Windows Exp.
                            NOTE: The Kryptonite drive is a Crypto currency miner, not the Duet board.
                            STATUS LED is flashing fast.
                            Wi-FI LED is off.
                            5v LED is on.
                            3.3v LED is on.
                              dc42 administrators @davidewen
                              What should happen when you press he Reset button twice in quick succession on the Duet 3 Mini is that the red STATUS LED cycles between bright and dim. When that happens, the USB drive should appear on your PC. Make sure that the USB cable you use is not a power-only cable for charging smartphones etc.
                              If the STATUS LED blinks slowly (once per second) then it is running firmware.
                              If it blinks quickly then it should blink a number of times, stop, and repeat. In that case the number of blinks is an error code.
