    CONSTANT AJAX disconnect errors
    307
    55.1k
    • KeeganBundefined
      KeeganB
      Well, I spoke too soon.
      Yesterday's print was done via DWC over about 3-4 hours with the USB cord plugged in the whole time.
      Today I disconnected the USB, connected to DWC, and started a print. before the hot end even finished preheating it has disconnnected and I was unable to reconnect.
      M122
      SENDING:M122
      Used output buffers: 3 of 32 (9 max)
      RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
      Static ram used: 21176
      Dynamic ram used: 96168
      Recycled dynamic ram: 1440
      Stack ram used: 4048 current, 9068 maximum
      Never used ram: 3220
      Last reset 01:43:44 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 4348 bytes (slot 0)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      [ERROR] Error status: 0
      Free file entries: 9
      SD card longest block write time: 75.2ms
      MCU temperature: min 30.2, current 33.1, max 33.8
      Supply voltage: min 11.6, current 11.8, max 12.3, under voltage events: 0, over voltage events: 0
      Driver 0: stalled
      Driver 1: stalled
      Driver 2: stalled
      Driver 3: stalled
      Driver 4: standstill
      Date/time: 2017-09-15 19:05:18
      Slowest main loop (seconds): 0.104980; fastest: 0.000000
      MaxReps: 4, StepErrors: 0, FreeDm: 164, MinFreeDm 144, MaxWait: 962417ms, Underruns: 4, 0
      Scheduled moves: 422, completed moves: 403
      Bed compensation in use: none
      Bed probe heights: 0.021 -0.103 0.041 0.235 0.119
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.6
      Segments left: 1
      Movement lock held by file
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X7.961 Y8.640 E11.0987" in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19.2
      WiFi MAC address 5c:cf:7f:ef:51:6f
      WiFi Vcc 3.10, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 39712
      WiFi IP address 10.0.1.38
      WiFi signal strength -44dBm
      Reconnections 0
      HTTP sessions: 2 of 8
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      Artemis
      Rostock Max v2
      Orion
      • KeeganBundefined
        KeeganB
        I just came back to my computer and the Safari window that had DWC in it was up, and it had apparently reconnected itself?
        Artemis
        Rostock Max v2
        Orion
          T3P3Tony administrators
          Keegan is there a correlation between USB cable plugged in and stability of the connection?
          • KeeganBundefined
            KeeganB
            @T3P3Tony:
            I really have no idea. It was a theory I was testing. After a couple days of disconnects I noticed my first successful 4hr print with 6hr connection time was when I was also plugged in to USB. Then the next day I tried it without the USB and got nearly an immediate disconnect. Then about an hour later the same DWC window in Safari had reconnected on its own?! It's been working and connected since then for nearly 10 hours. (No usb)
            Artemis
            Rostock Max v2
            Orion
            • KeeganBundefined
              KeeganB
              The last two failures both happened within minutes of starting a print. I didn't get the diags for the first failure, but interestingly enough it came back online by itself and worked fine until a few seconds after starting the second print. Here is the M122 after the second print and subsequent AJAX failure. I suspect this will come back online again too, sometime in the middle of the print.
              M122
              SENDING:M122
              Used output buffers: 5 of 32 (13 max)
              Dynamic ram used: 96280
              Recycled dynamic ram: 1328
              Stack ram used: 4048 current, 9104 maximum
              Never used ram: 3184
              Last reset 04:50:44 ago, cause: power up
              Error status: 8
              [ERROR] Error status: 8
              SD card longest block write time: 0.0ms
              MCU temperature: min 35.7, current 35.9, max 36.2
              Supply voltage: min 11.7, current 11.8, max 12.1, under voltage events: 0, over voltage events: 0
              Driver 0: stalled
              Driver 1: stalled
              Driver 2: stalled
              Driver 3: stalled
              Date/time: 2017-09-16 20:04:42
              Slowest main loop (seconds): 0.003906; fastest: 0.000000
              MaxReps: 4, StepErrors: 0, FreeDm: 221, MinFreeDm 189, MaxWait: 2ms, Underruns: 0, 0
              Scheduled moves: 2311, completed moves: 2306
              Bed probe heights: -0.019 -0.083 -0.078 0.096 -0.127
              Heater 1 is on, I-accum = 0.4
              Segments left: 1
              file is doing "G1 X25.168 Y2.626 E93.1502" in state(s) 0
              WiFi Vcc 3.11, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 39392
              WiFi signal strength -46dBm
              Reconnections 1
              Artemis
              Rostock Max v2
              Orion
                Thanks. I can't see anything wrong in the M122 report. it's interesting that you have a a reconnection count of 1 indicating that the WiFi module became disconnected from the router and successfully connected again, even though you have a very high signal strength.
                • KeeganBundefined
                  KeeganB
                  David,
                  I think I have established a bit of a pattern in my situation. It seems that right at the beginning of every new print, it disconnects. Then sometime after that (I estimate between 15-30mins) it just reconnects itself and is fine from then until I start the next print.
                  Artemis
                  Rostock Max v2
                  Orion
                    I did a little investigation this morning, and I found that for homing moves (i.e. G1 S1 moves), the maximum step rate possible is many times lower than for ordinary moves. So a high microstepping value can cause MaxReps to get very high during a homing move even if the combination of M350 microstepping and M203 maximum speeds is OK for normal moves. So if your print files have a G28 homing command at the start, that could be why you get a disconnection at the start of a print. The workaround for this particular issue is to use slower homing moves.
                    • KeeganBundefined
                      KeeganB
                      I will try slower homing moves. I don't have a separate G28 at the start of my prints, but there is on inside of beg.g that runs (as G32) at the start of all prints.
                      My micro stepping is 16x
                      I should add though, that it doesn't necessarily disconnect during the homing move, sometimes it can be a few minutes into the print.
                      Artemis
                      Rostock Max v2
                      Orion
                        I would not expect you to have this problem with only x16 microstepping.
                        • Jareryundefined
                          Jarery
                          Similar to KeeganB, my board is set to 16x micro stepping (with interpolation).
                          I also do not have a G28 homing in any of my Gcode but as KeeganB states in my Bed command is a G28 at the start. After that the Gcode has no homing until finished.
                          My disconnects happen early in a print but unlike KeeganB, mine has never reconnected on its own that I'm aware of.
                          I have never seen the reconnect count above 0.
                          Edit: mine don't always happen only near start of a print, just that they are a high chance at start. Mine also disconnects just sitting idle sometime.
                          I'm about a week away from commissioning a second delta with another duet wifi, based on dc42's large Kossel build. So in a week or so I'll be able to tell if both boards exhibit the same behaviour in my wifi network or if its specific to the one board.
                          • lolorcundefined
                            lolorc
                            Hi there.
                            I also have the constant disconnections.
                            the disconnections also happen when the printer is idle…
                            I also have a tons of issue uploading g-code files through wifi. (when usb is plugged)
                            • BlackTomundefined
                              BlackTom
                              I have had the same kind of issue with 1.19.2, 1.19 is correct.
                              I had issues when I was running my bed compensation routine and I had it too when I was printing,
                              I always finish by being disconnected of the web interface when I print and I cannot reconnect to it.
                              The print continue without issue until it's done so it doesn't affect it
                              The only way to get back access to the web interface is by powering off / on the board,
                              • lolorcundefined
                                lolorc
                                @bloood3d:
                                same here.
                                • botundefined
                                  bot
                                  What about when you do a "hard refresh" of the web page through the web browser? On chrome this is done by holding the CTRL key while clicking refresh. In the past, this has helped me get back into a web interface session.
                                  *not actually a robot
                                  • KeeganBundefined
                                    KeeganB
                                    bot,
                                    That hasn't worked for me. I have also tried loading the page on difference devices.
                                    Artemis
                                    Rostock Max v2
                                    Orion
                                    • RGN01undefined
                                      RGN01
                                      I'm commissioning my new Duet WiFi and have the same issue. I've tried it in two locations (both no more than 10 feet from the WiFi router) and with three clients (desktop PC, Android tablet and Android mobile phone all running Chrome). The desktop PC is best but it still drops the connection frequently - perhaps every 15 minutes - despite the printer not even being fully commissioned (the most it has done is home the towers and heatbed auto set up) and the PC is being used for browsing and email.
                                      I hope that this is resolved as it is a bit concerning to someone new to the Duet (which I think is absolutely great!)
                                        Have you tried increasing the number of retries in the DWC settings?
                                        • RGN01undefined
                                          RGN01
                                          Thanks, David.
                                          I increased it to 5 earlier this evening and it seems to be OK so far on the desktop PC (about 90 minutes) - but the printer and PC are effectively idle.
                                          It was set to one initially, is there a recommended larger setting, or is it trial and error?
                                          I'll monitor this as I start adding and testing functionality to the printer - and report back.
                                            1 is rather low, I think 3 would be a better default.
