    No tools are showing in DWC - noob
    Duet Web Control
    1.5k
    • Nvigr8undefined
      Nvigr8 @Phaedrux
      @phaedrux As soon as I get home from work I will do that. Thank you.
      Modified Multoo MT1.5, Modified Creality CR6SE, Modified Monoprice Mini Delta, Modified Wanhao Di3, Phrozen Shuffle
      • Nvigr8undefined
        Nvigr8 @Stephen6309
        @stephen6309 I sent M119 and it says the x and y endstops are tripped but nothing is physically touching and activating the switches.
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
        • Nvigr8undefined
          Nvigr8 @Phaedrux
          @phaedrux This is what M122 shows.
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N85S4-7JKD4-3SJ6R-TA9HR
          Used output buffers: 3 of 24 (15 max)
          Static ram: 23876
          Dynamic ram: 74788 of which 84 recycled
          Never used RAM 15668, free system stack 184 words
          Tasks: NETWORK(ready,13.6%,237) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,340) MAIN(running,86.0%,403) IDLE(ready,0.4%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:04:25 ago, cause: power up
          Last software reset at 2022-01-02 22:37, reason: User, GCodes spinning, available RAM 12704, slot 2
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 17.2, current 25.4, max 25.9
          Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 3: position 0, standstill, SG min/max not available
          Driver 4: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-01-04 17:41:18
          Slowest loop: 5.83ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.85ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address f4:cf:a2:6e:86:ef
            WiFi Vcc 3.43, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 22208
            WiFi IP address 192.168.2.158
            WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          • Nvigr8undefined
            Nvigr8 @Phaedrux
            @phaedrux This is what M98 said
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: in file macro line 131 column 38: M563: expected number after 'F'
            Error: Tool 0 not found
            Error: in file macro line 137 column 40: M563: expected number after 'F'
            Error: Tool 1 not found
            Warning: Macro file config-override.g not found
              M563 P0 S"extruder 0 (model)" D0 H0 F-1 ; define tool 0
              M563 P1 S"extruder 1 (support)" D1 H1 F-1 ; define tool 1
              Can you try mofifying your tool definition to look like
              M563 P0 S"extruder0" D0 H0 ; define tool 0
              M563 P1 S"extruder1" D1 H1 ; define tool 1
              Can you also check the settings tab in DWC and verify the version matches 3.3
              Nvigr8undefined 3 Replies Last reply Reply Quote 0
              • Nvigr8undefined
                Nvigr8 @Phaedrux
                @phaedrux I didn't see a settings tab but these are from elsewhere in DWC:
                • Nvigr8undefined
                  Nvigr8 @Phaedrux
                  @phaedrux Ok made the changes to the tool section and now they are showing up in DWC and on the PanelDue. Thank you very much!
                  However when I touch the heater 1 icon I get : Error Temperature reading fault on heater 1: sensor open circuit
                  I double checked the wiring and the thermistors are connected to E0 temp and E1 temp.
                  One thing to note and I'm not certain this is an issue, I have a breakout board on the extruder body for all the wiring so that I can just plug one 25pin plug into it to swap out extruders. I've double checked the wiring to make sure everything is going where it should.
                  Thanks again for your help on this!
                  • Nvigr8undefined
                    Nvigr8 @Phaedrux
                    @phaedrux Odd, its now showing two extruders in tool 1 with two heaters and a third heater in tool 2.
                      Phaedrux Moderator @Nvigr8
                      @nvigr8 said in No tools are showing in DWC - noob:
                      Do you have a wiring diagram for this board?
                      I would suggest testing the wiring direct to remove the breakout board from the equation. It may be sharing a negative ground connection that the duet uses to switch the heater.
                      Nvigr8undefined 2 Replies Last reply Reply Quote 0
                      • Nvigr8undefined
                        Nvigr8 @Phaedrux
                        @phaedrux To what do I set the active and standby temps? Would you please explain them?
                        I wired in an extra thermistor directly to the board and did not get the error this time. It reads a normal temp on DWC but on the PanelDue it still reads a crazy number. Also even though I don't have a heated bed in the configuration, it shows one on the Panel Due.
                        I'll have to draw a diagram for you tonight or tomorrow. I would really like to be able to use this breakout board setup. I have three different extruder assemblies that I will be switching between and it will make the switch so much easier.
                        Thanks for your help.
                          You probably need to update your paneldue firmware
                          https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                          Normally they would be set by your slicer.
                          Nvigr8undefined 1 Reply Last reply Reply Quote 0
                          • Nvigr8undefined
                            Nvigr8 @Phaedrux
                            @phaedrux This is the breakout board that I'm using:
                            link text
                            Here is a diagram:
                            Note: This assembly does not thave E1 and accessories. Connections are there for another two extruder assembly.
                            Here is the corresponding plug pins:
                            Pic of the whole assembly:
                            One thing that just occured to me, does soldering thermistor wires cause problems?
                            • Nvigr8undefined
                              Nvigr8 @Phaedrux
                              @phaedrux Do you know what the SH terminal on that breakout board is for?
                              Also, after doing some reading, it looks like I should have checked the resistance on the wires I used to connect the thermistors... Maybe that is part of the issue. Tonight I'll replace those cables with thermistor cables and crimp them onto the plug pin instead of soldering.
                              • Stephen6309undefined
                                Stephen6309 @Nvigr8
                                @nvigr8 Change the S1 to S0 in your M574.
                                • Nvigr8undefined
                                  Nvigr8 @Stephen6309
                                  @stephen6309 Thank you for the input. Last night I finally got the X and Y endstops and movement working properly.
                                  However, now the Z endstop shows as being on even though the BLtouch has not been triggered. Not sure what I changed to make this happen.
                                    Stephen6309 @Nvigr8
                                    @nvigr8 Add a ! to the pin that should fix it. For example: M558 P9 C"!^zprobe.in" H5 F120 T6000
                                    • Nvigr8undefined
                                      Nvigr8 @Stephen6309
                                      @stephen6309 Which .g file would that be in? Thanks.
                                      • Nvigr8undefined
                                        Nvigr8 @Stephen6309
                                        @stephen6309 NM, I found it. Thanks! I'll try it out at lunch.
                                          Stephen6309 @Nvigr8
                                          @nvigr8 config.g You just need to edit the one in there already.
                                          • Nvigr8undefined
                                            Nvigr8 @Stephen6309
                                            @stephen6309 What does that ! do there to make it work?
