    Mesh bed leveling problem
    1.0k
    • fcwiltundefined
      fcwilt @Petr K
      @petr-k said in Mesh bed leveling problem:
      @fcwilt In M558 doesn't work
      Could you elaborate a bit on that?
      Petr Kundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Petr K
        @phaedrux Any simple gcode for leveling? I edit G28 gcode too.
        Do you mean to level the bed, or to create the mesh for the surface?
        Maybe this helps to explain
        https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
        • Petr Kundefined
          Petr K @fcwilt
          @fcwilt G32 works fine, but G29 has problem, so mesh.g
          • Petr Kundefined
            Petr K @fcwilt
            This post is deleted!
            • Petr Kundefined
              Petr K @Phaedrux
              @phaedrux Level the bed, I mean G29 settings
              • Petr Kundefined
                Petr K @Phaedrux
                  That looks pretty good. Are you still getting the error about the offset?
                  Have you done a test print with it active to see if it's working as expected?
                  bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                  Petr Kundefined 1 Reply Last reply Reply Quote 0
                  • Petr Kundefined
                    Petr K @Phaedrux
                    @phaedrux Looks good, but what about the four points in corners? I started printing yesterday and first layer looks good. Object was in the center of bed and has diameter 150 mm.
                    • fcwiltundefined
                      fcwilt @Petr K
                      A 5 by 5 mesh grid can give a false impression of the bed surface.
                      I use a 20 by 20 mesh grid.
                      Perhaps create a new height map using more points.
                      • Petr Kundefined
                        Petr K
                        Thanks guys, I fix it.
