Mesh bed leveling problem
1.0k
    JoergS5 @Petr K
    This post is deleted!
      fcwilt @Petr K
      @petr-k said in Mesh bed leveling problem:
      @fcwilt Hello two speeds are where in firmware please?
      From the docs:
      From RRF 3.3 you can provide two F parameters instead of one, where the second is lower than the first, for example F1000:500. When doing a plain G30 command, an additional probe will be done using the first speed to establish the approximate bed position, before one or more additional probes are done using the second speed. The first speed will not be used when probing at a defined point or when mesh bed probing.
      undefined 1 Reply Last reply 14 Dec 2021, 16:03 Reply Quote 0
        Petr K @fcwilt
        @fcwilt In M558 doesn't work
        undefined 1 Reply Last reply 14 Dec 2021, 17:07 Reply Quote 0
          fcwilt @Petr K
          Could you elaborate a bit on that?
          undefined 2 Replies Last reply 15 Dec 2021, 10:29 Reply Quote 0
            Phaedrux Moderator @Petr K
            @phaedrux Any simple gcode for leveling? I edit G28 gcode too.
            Do you mean to level the bed, or to create the mesh for the surface?
            Maybe this helps to explain
            https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
            undefined 2 Replies Last reply 15 Dec 2021, 18:09 Reply Quote 0
              Petr K @fcwilt
              @fcwilt G32 works fine, but G29 has problem, so mesh.g
                Petr K @fcwilt
                  Petr K @Phaedrux
                  @phaedrux Level the bed, I mean G29 settings
                    Petr K @Phaedrux
                      That looks pretty good. Are you still getting the error about the offset?
                      Have you done a test print with it active to see if it's working as expected?
                      bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                      undefined 1 Reply Last reply 16 Dec 2021, 11:07 Reply Quote 0
                        Petr K @Phaedrux
                        @phaedrux Looks good, but what about the four points in corners? I started printing yesterday and first layer looks good. Object was in the center of bed and has diameter 150 mm.
                        undefined 1 Reply Last reply 16 Dec 2021, 12:30 Reply Quote 0
                          fcwilt @Petr K
                          A 5 by 5 mesh grid can give a false impression of the bed surface.
                          I use a 20 by 20 mesh grid.
                          Perhaps create a new height map using more points.
                            Petr K
                            Thanks guys, I fix it.
