    Circuit, PCB analysis tools
    1.7k
    • rjenkinsgbundefined
      rjenkinsgb @JoergS5
      @joergs5 said in Circuit, PCB analysis tools:
      Now having a few days for learning something new, I would be interested in analysing circuits and learning electronics. Maybe buying a reflow oven and experimenting.
      the last hour I'm thinking about how
      to place the paste onto the PCB with the robot arm
      fix the PCB on the heating plate
      control the quality of paste and SMB elements with camera and OpenCV
      I would very seriously suggest you get past the basics of designing and building / programming conventional circuits, using prototyping boards or stripboard etc., before even considering anything to do with surface mount assembly!
      Surface mount is great for mass production, once designs are proven - but it is definitely not a good way of learning basic electronics or prototyping general circuits.
      Even commercial designs that will eventually be surface mount construction often have the first prototypes built with conventional components - it's far easier to change parts or modify things, than on a fixed-layout surface mount PCB.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      • JoergS5undefined
        JoergS5 @rjenkinsgb
        @rjenkinsgb said in Circuit, PCB analysis tools:
        Sorry if you got a wrong impression of my knowledge. I learned electronic basics 43 years ago, when I made my ham radio exam. I have gaps in my knowledge like IGBT and which software to use, but I have electronic knowledge. And I love soldering. Currently I use breadboards for trying out new ideas, but they are unstable for normal usage.
        rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
          rjenkinsgb @JoergS5
          I learned electronic basics 40 years ago, when I made my ham radio exam.
          OK, sorry for the misunderstanding; I got the impression from your initial post that you were a complete beginner.
          [Also a radio ham for 40+ years - G8TBF / G0WTK]
          Robert J.
          • JoergS5undefined
            JoergS5 @rjenkinsgb
            I am DF3TP
            • zaptaundefined
              zapta @JoergS5
              You may want to look also at prior art in the area of makers' SMD assembly techniques and tools. There are all kind of attempt to make the process less painful and more efficient.
              For example, this for automated pick and place https://openpnp.org or this for reflow temperature stabilization using vapor phase https://www.youtube.com/watch?v=czwRntpEzgg . DIY SMD technology can be an interesting hobby on its own. 😉
                dc42 administrators @JoergS5
                @joergs5 I doubt that you will be able to achieve accurate solder paste placement for fine pitch components using a robot arm. When I was building SMD prototypes, I used to buy a cheap Mylar solder stencil. Hobbytronics does them in the UK, and Pololu in the US. JLCPCB now sells inexpensive stainless steel ones too.
                • JoergS5undefined
                  JoergS5 @dc42
                  Thanks @zapta , I'll check the links.
                  @dc42 it's just a test whether I am able to build a precise SMD picker. It's not high priority, just to know whether it's possible.
                  • JoergS5undefined
                    JoergS5 @zapta
                    @zapta the OpenPnP is very interesting!
                    For Colophonium application I thought, a peristaltic pump may be a possible solution.
                    I ordered the 946C plate now, I am looking forward to experiment.
                    • zaptaundefined
                      zapta @JoergS5
                      @joergs5, les us know how it works for you.
                      If you plan to get into paste dispensing, you can find ideas on youtube https://www.youtube.com/results?search_query=solder+paste+dispenser and aliexpress https://www.aliexpress.com/af/solder-paste-dispensing.html
                      One approach that may be promising, which I never tried, is compressed air based dispensing like this one https://www.aliexpress.com/item/4000785130294.html
                      JoergS5undefined 2 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @zapta
                        @zapta said in Circuit, PCB analysis tools:
                        https://www.youtube.com/watch?v=AC5BB0ae2Hg shows the internals...
                        Thanks for all you hints. The idea to combine SMD mounting with robot arm is a low priority project, however. Main topic is to finish the 6 axis robot.
                        • JoergS5undefined
                          JoergS5 @zapta
                          This post is deleted!
