Weird problem with magnetic arms and tool fan
My Duet controlled machine
delta effector fan speed magnet
558
    skayred
    Hello, I have a Delta printer with magnetic arms.
    Some time ago, i started having a weird problem - when I move effector in X-Y plane, fan RPM varies depending on the position - for example, in 0/+40 it nearly stop, while in the center it has about the normal RPM and works pretty loud. I have replaced the fan with the new and quiet one, after some time I have the same problem again. When I unscrewed the fan, I have found out, that the fan behaves so when it is located close to magnets, it seems that magnetic field makes the bearing loose, until the friction goes to high - that explains the noise.
    My effector looks so:
    Did someone have the same problem? Is there any workaround without changing the effector design?
    undefined undefined 2 Replies Last reply 20 Jan 2022, 19:04 Reply Quote 0
      alankilian @skayred
      @skayred
      You could try shielding but it might be expensive:
      https://www.youtube.com/watch?v=oxg_hCvXSrw
      Or you could try rotating the fan into different orientations and see if it's less sensitive in some orientations.
      undefined 1 Reply Last reply 20 Jan 2022, 19:09 Reply Quote 0
        jay_s_uk @skayred
        @skayred make sure you alternate the arms. There should be one with a north magnet, then South then north and so on.
        If you have Haydn rods, he puts a stick at the end with a north magnet so just alternate where the sticker end is
        undefined 1 Reply Last reply 20 Jan 2022, 19:11 Reply Quote 0
          skayred @alankilian
          @alankilian hello, did i understand correctly, that i should try rotate the fan let's say 90 degrees counterclockwise keeping the effector position?
          I was also wondering, should I give a try to the remote fan (connected with PVC hose), would that be sufficient for the hotend cooling? My effector is pretty small, so there are no other places where I can mount the fan
            skayred @jay_s_uk
            @jay_s_uk yeah, I have Haydn's arms, so the result position should be like S-n-s-n-s-n around?
            undefined 1 Reply Last reply 20 Jan 2022, 19:12 Reply Quote 0
              alankilian @skayred
              @skayred said in Weird problem with magnetic arms and tool fan:
              Yes that's what I mean, but I think @jay_s_uk also has a good suggestion.
                jay_s_uk @skayred
                @skayred yes. It's a known thing with magball arms. If you have them all the same way the magnetic field affects the hotend fan
                undefined 1 Reply Last reply 20 Jan 2022, 19:31 Reply Quote 1
                  skayred @jay_s_uk
                  @jay_s_uk @alankilian I have done both - it worked, thanks! Life is a magic if I don't know physics well enough 😄
                  undefined 1 Reply Last reply 20 Jan 2022, 19:35 Reply Quote 2
                    alankilian @skayred
                    @skayred
                    GREAT news.
                    Send some images of good prints when you're done.
                    It's always nice to see success.
                      skayred
                      It actually started working way better with PLA as a side effect
                      • undefined dc42 marked this topic as a question 22 Jan 2022, 17:12
                      • undefined dc42 has marked this topic as solved 22 Jan 2022, 17:12
                      6 out of 10
