Toolbaord accelerometer not present
252
    Fladdie
    on my toolbard it does not recognize the accelerometer. I have also tried the latest beta firmware without success.
    M122 B21
    Diagnostics for board 21:
    Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
    Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
    Never used RAM 3040, free system stack 2762 words
    Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,115) CanAsync(notifyWait,0.0%,57) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,2.9%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
    Last reset 00:06:23 ago, cause: software
    Last software reset data not available
    Driver 0: position 0, 400.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 24, reads 60773, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0
    Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
    Peak sync jitter 0/5, peak Rx sync delay 218, resyncs 0/0, no step interrupt scheduled
    VIN: 26.1V
    MCU temperature: min 33.3C, current 36.8C, max 36.8C
    Ticks since heat task active 247, ADC conversions started 382218, completed 382217, timed out 0, errs 0
    Last sensors broadcast 0x00000004 found 1 2 ticks ago, loop time 0
    CAN messages queued 4844, send timeouts 0, received 3478, lost 0, free buffers 37, min 37, error reg 110000
    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
    Accelerometer detected: no
    I2C bus errors 0, naks 3, other errors 0
    === Filament sensors ===
    Interrupt 4 to 8us, poll 8 to 714us
    Driver 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
    M955 P21.0
    Error: M955: Accelerometer 21.0 not present
    M122
    RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
    Board ID: 08DJM-956BA-NA3TN-6J1D2-3SD6J-9BBYT
    Used output buffers: 3 of 40 (23 max)
    Static ram: 150904
    Dynamic ram: 92676 of which 320 recycled
    Never used RAM 107436, free system stack 152 words
    Tasks: NETWORK(ready,30.4%,206) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.7%,59) MAIN(running,61.6%,924) IDLE(ready,0.1%,29), total 100.0%
    Owned mutexes:
    Last reset 00:09:54 ago, cause: software
    Last software reset at 2022-01-26 10:05, reason: User, GCodes spinning, available RAM 110644, slot 1
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
    Error status: 0x00
    Step timer max interval 137
    MCU temperature: min 32.6, current 37.6, max 37.8
    Supply voltage: min 25.8, current 25.9, max 26.3, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/16/16, gc cycles 0
    Driver 0: position 0, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/181
    Driver 1: position 0, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/236
    Driver 2: position 60000, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/206
    Driver 3: position 119680, standstill, reads 16975, writes 19 timeouts 0, SG min/max 0/238
    Driver 4: position 0, standstill, reads 16971, writes 23 timeouts 0, SG min/max 0/910
    Driver 5: position 0, standstill, reads 16980, writes 14 timeouts 0, SG min/max 0/0
    Date/time: 2022-01-26 10:15:50
    Slowest loop: 132.34ms; fastest: 0.05ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 2.2ms, write time 39.8ms, max retries 0
    DMs created 125, maxWait 71427ms, bed compensation in use: none, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 21, completed moves 21, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
    === AuxDDARing ===
    Heater 0 is on, I-accum = 0.9
    Heater 2 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty.
    Extruder 1: no data received
    === CAN ===
    Messages queued 5381, received 7494, lost 0, longest wait 4ms for reply type 6024, peak Tx sync delay 325, free buffers 49 (min 48), ts 2971/2970/0
    Tx timeouts 0,0,0,0,0,0
    === Network ===
    Slowest loop: 185.17ms; fastest: 0.02ms
    HTTP sessions: 2 of 8
    - Ethernet -
    State: active
    Error counts: 0 0 1 0 0
    undefined 1 Reply Last reply 26 Jan 2022, 09:25 Reply Quote 0
      jay_s_uk @Fladdie
      @fladdie you'll need to use a beta i believe.
      Can you update and then post the output of M122 B21 again so we can see the revision of your board
      undefined 1 Reply Last reply 26 Jan 2022, 10:14 Reply Quote 0
        Fladdie @jay_s_uk
        @jay_s_uk
        i already had on release 3.4.0 beta 7 with the same problem. I had of course also upgraded the toolboard to the current firmware.
        I have downgraded again to 3.3 due to other reconfiguration efforts.
        The board is a PCB version toolboard v1.2
        undefined 1 Reply Last reply 26 Jan 2022, 10:49 Reply Quote 0
          jay_s_uk @Fladdie
          @fladdie have you tried all other features of the toolboard etc during a print?
          Could be a CAN communication issue
          undefined 1 Reply Last reply 26 Jan 2022, 11:40 Reply Quote 0
            Fladdie @jay_s_uk
            @jay_s_uk
            I have already spent several hours printing with the toolboard.
            Connected to the Toolboard are:
            Extruder motor
            Axis Endstop
            Heater Cartridge
            PT1000 sensor
            Duet3D Filament Monitor: Rotating Magnet Version
            Everything works fine except the accelerometer.
            undefined 1 Reply Last reply 26 Jan 2022, 12:28 Reply Quote 1
              jay_s_uk @Fladdie
              @fladdie the next question would be when and where did you purchase the toolboard. Then i'll hand you over to @Phaedrux
              undefined 1 Reply Last reply 26 Jan 2022, 13:01 Reply Quote 0
                Fladdie @jay_s_uk
                @jay_s_uk
                I ordered the toolboards from Filafarm on 10.01.22
                https://www.filafarm.de/products/duet-3-toolboard-1lc
                The link refers to PCB version 1.1, but I received version 1.2 from Filafarm.
                undefined 1 Reply Last reply 26 Jan 2022, 13:33 Reply Quote 0
                  dc42 administrators @Fladdie
                  @fladdie thanks, please email warranty@duet3d.com with a link to this thread.
                  1 out of 8
