Toolbaord accelerometer not present
on my toolbard it does not recognize the accelerometer. I have also tried the latest beta firmware without success.
M122 B21 Diagnostics for board 21: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 3040, free system stack 2762 words Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,115) CanAsync(notifyWait,0.0%,57) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,2.9%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0% Last reset 00:06:23 ago, cause: software Last software reset data not available Driver 0: position 0, 400.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 24, reads 60773, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/5, peak Rx sync delay 218, resyncs 0/0, no step interrupt scheduled VIN: 26.1V MCU temperature: min 33.3C, current 36.8C, max 36.8C Ticks since heat task active 247, ADC conversions started 382218, completed 382217, timed out 0, errs 0 Last sensors broadcast 0x00000004 found 1 2 ticks ago, loop time 0 CAN messages queued 4844, send timeouts 0, received 3478, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer detected: no I2C bus errors 0, naks 3, other errors 0 === Filament sensors === Interrupt 4 to 8us, poll 8 to 714us Driver 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
M955 P21.0 Error: M955: Accelerometer 21.0 not present
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6J1D2-3SD6J-9BBYT Used output buffers: 3 of 40 (23 max) === RTOS === Static ram: 150904 Dynamic ram: 92676 of which 320 recycled Never used RAM 107436, free system stack 152 words Tasks: NETWORK(ready,30.4%,206) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.7%,59) MAIN(running,61.6%,924) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:09:54 ago, cause: software Last software reset at 2022-01-26 10:05, reason: User, GCodes spinning, available RAM 110644, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 137 MCU temperature: min 32.6, current 37.6, max 37.8 Supply voltage: min 25.8, current 25.9, max 26.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/16/16, gc cycles 0 Driver 0: position 0, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/181 Driver 1: position 0, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/236 Driver 2: position 60000, standstill, reads 16974, writes 19 timeouts 0, SG min/max 0/206 Driver 3: position 119680, standstill, reads 16975, writes 19 timeouts 0, SG min/max 0/238 Driver 4: position 0, standstill, reads 16971, writes 23 timeouts 0, SG min/max 0/910 Driver 5: position 0, standstill, reads 16980, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2022-01-26 10:15:50 Slowest loop: 132.34ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.2ms, write time 39.8ms, max retries 0 === Move === DMs created 125, maxWait 71427ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 21, completed moves 21, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.9 Heater 2 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 1: no data received === CAN === Messages queued 5381, received 7494, lost 0, longest wait 4ms for reply type 6024, peak Tx sync delay 325, free buffers 49 (min 48), ts 2971/2970/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 185.17ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 2 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
@fladdie you'll need to use a beta i believe.
Can you update and then post the output of M122 B21 again so we can see the revision of your board -
i already had on release 3.4.0 beta 7 with the same problem. I had of course also upgraded the toolboard to the current firmware.
I have downgraded again to 3.3 due to other reconfiguration efforts.The board is a PCB version toolboard v1.2
@fladdie have you tried all other features of the toolboard etc during a print?
Could be a CAN communication issue -
@jay_s_uk
I have already spent several hours printing with the toolboard.Connected to the Toolboard are:
Extruder motor
Axis Endstop
Heater Cartridge
PT1000 sensor
Duet3D Filament Monitor: Rotating Magnet VersionEverything works fine except the accelerometer.
@jay_s_uk
I ordered the toolboards from Filafarm on 10.01.22
https://www.filafarm.de/products/duet-3-toolboard-1lcThe link refers to PCB version 1.1, but I received version 1.2 from Filafarm.
@fladdie thanks, please email warranty@duet3d.com with a link to this thread.
