    Hints for accelerometer placeing
    19
    1.6k
    • gloomyandyundefined
      gloomyandy @A Former User
      @thedragonlord No idea if the flat ethernet cable will work or not, you probably just have to try it. If it doesn't then several folks (including myself) have been successful using USB3 cable and wiring in the way described here: https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released/68?_=1624809172098
        A Former User @gloomyandy
        @gloomyandy said in Hints for accelerometer placeing:
        excellent, thanks
        • amjm22undefined
          amjm22
          I have a Delta printer using a Duet smart effector, I'm using a Duet3d 6hc3 sys board.
          Where would you mount an accelerometer to the smart effector?
          Wiring is not the issue, it is the physical location.
            dc42 administrators @amjm22
            @amjm22 I mounted mine on top of the effector, using a single screw to attach it to one of the 3 mounting holes in the effector, with a couple of nuts as spacers.
            ignacmcundefined amjm22undefined 2 Replies Last reply Reply Quote 1
            • ignacmcundefined
              ignacmc @dc42
              @dc42 Any rigid location on top of the effector could suffice?
              I am thinking of using double side tape, or printing a small base to be glued on top
              Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
              • amjm22undefined
                amjm22 @dc42
                @dc42 Much appreciated! I will give it a shot when the accelerometer arrives! i post the results.
                  dc42 administrators @ignacmc
                  @ignacmc said in Hints for accelerometer placeing:
                  Yes. Here is a photo of the way I mounted mine.
                  janjohundefined 1 Reply Last reply Reply Quote 1
                  • janjohundefined
                    janjoh @dc42
                    @dc42 That photo made me smile. I came here looking for advice on accelerometer placement, and invisioned all sorts of fancy printed mounts. Then I find this. Quick. Cheap. Efficient. Moving on.
                    Thank you. 🙂
                    tommybundefined 1 Reply Last reply Reply Quote 0
                    • tommybundefined
                      tommyb @janjoh
                      @janjoh I would guess the corner mount like will have it's own artifacts. It may or may not matter, but looks like a spring board and will certainly have a dominant frequency related to the mounting alone. Simply test on a nice solid block of Al or something by mounting in the same fashion and give it a few taps in x, y, z directions and see what you get.
                        dc42 administrators @tommyb
                        @tommyb if the screws are tight then I am sure that the resonant frequencies of the mounting mechanism will be much higher than those of the arms + effector mass that I am interested in.
