    Hints for accelerometer placeing
    19
    1.5k
      A Former User @T3P3Tony
      @t3p3tony said in Hints for accelerometer placeing:
      @thedragonlord the accelerometer is used for collecting data that allows you to select an appropriate input shaping frequency and shaping type to reduce ringing. after that has been determined the accelerometer does not need to remain fitted to the printer.
      Ok, I've read again the documentation at https://duet3d.dozuki.com/Wiki/Accelerometers as well a the GCODE dictionary for M593 and I've realized that I haven't understood a...thing...The accelerometer is used to gather data wich can be viewed in the graph using the DWC plugin. The M593 has to be configured to "neutralize" a single frequency, right? So the question is how can i "translate" the data gathered by the accelerometer to a single frequency for the M593 I mean how can I get the "guilty" frequency from the graph? In the graph there are the samples on X and acceleration on Y how is the frequency "calculated" from this data?
      I apologize if this question is stupid but I'm trying to learn and sometimes it's a little hard without help...unfortunately (for my wallet) curiosity and will to experiment new thing are my Acchilles heel...
      Thanks
        T3P3Tony administrators @A Former User
        @thedragonlord the input shaping plugin will show the detected frequencies see this thread for the latest development of the plugin:
        https://forum.duet3d.com/topic/24859/inputshaping-plugin-0-1-0-rc7-released-repacked/15
        A Former User? 2 Replies Last reply Reply Quote 0
          excellent, thanks
            this is the accelerometer I've bought: https://www.ebay.it/itm/273191600064 (of course I'll upgrade the FW to 3.4 beta 2) in your opinion a normal non shielded flat ethernet cable like this https://www.amazon.it/gp/product/B00UPHN938/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (wich I already own) could be fine? (Of course following the hint to keep the CS cable as far as possible from other signal cables). In case not what cable would be best?
            Thanks
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @A Former User
              @thedragonlord No idea if the flat ethernet cable will work or not, you probably just have to try it. If it doesn't then several folks (including myself) have been successful using USB3 cable and wiring in the way described here: https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released/68?_=1624809172098
                A Former User @gloomyandy
                @gloomyandy said in Hints for accelerometer placeing:
                excellent, thanks
                • amjm22undefined
                  amjm22
                  I have a Delta printer using a Duet smart effector, I'm using a Duet3d 6hc3 sys board.
                  Where would you mount an accelerometer to the smart effector?
                  Wiring is not the issue, it is the physical location.
                    dc42 administrators @amjm22
                    @amjm22 I mounted mine on top of the effector, using a single screw to attach it to one of the 3 mounting holes in the effector, with a couple of nuts as spacers.
                    ignacmcundefined amjm22undefined 2 Replies Last reply Reply Quote 1
                    • ignacmcundefined
                      ignacmc @dc42
                      @dc42 Any rigid location on top of the effector could suffice?
                      I am thinking of using double side tape, or printing a small base to be glued on top
                      Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
                      • amjm22undefined
                        amjm22 @dc42
                        @dc42 Much appreciated! I will give it a shot when the accelerometer arrives! i post the results.
                          dc42 administrators @ignacmc
                          @ignacmc said in Hints for accelerometer placeing:
                          Yes. Here is a photo of the way I mounted mine.
                          janjohundefined 1 Reply Last reply Reply Quote 1
                          • janjohundefined
                            janjoh @dc42
                            @dc42 That photo made me smile. I came here looking for advice on accelerometer placement, and invisioned all sorts of fancy printed mounts. Then I find this. Quick. Cheap. Efficient. Moving on.
                            Thank you. 🙂
                            tommybundefined 1 Reply Last reply Reply Quote 0
                            • tommybundefined
                              tommyb @janjoh
                              @janjoh I would guess the corner mount like will have it's own artifacts. It may or may not matter, but looks like a spring board and will certainly have a dominant frequency related to the mounting alone. Simply test on a nice solid block of Al or something by mounting in the same fashion and give it a few taps in x, y, z directions and see what you get.
                                dc42 administrators @tommyb
                                @tommyb if the screws are tight then I am sure that the resonant frequencies of the mounting mechanism will be much higher than those of the arms + effector mass that I am interested in.
