    print slows down mid print
    Beta Firmware
    987
    • TimTomundefined
      TimTom @dc42
      Sorry for "spaming", just adding input. It seems the printer gets slower and slower.
      As the layers are all exactly the same, it's pretty weired.
      I'd exclude temperature issues, as I started the new print with electronics fans at full speed (keeping the board at ~32°C).
      Next I'm going to try a downgrade to older stable firmware.
      • TimTomundefined
        TimTom @dc42
        Ok I did a downgrade to 3.3 Firmware, same behavior.
        The print massively slows down at layer ~30.
        Very weired, will test with other prints next days.
          Can you also test with this updated beta 7?
          https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0
          TimTomundefined 2 Replies Last reply Reply Quote 0
          • TimTomundefined
            TimTom @Phaedrux
            @phaedrux
            Just installed the provided build.
            It seems to be still there. Layertime seems to double (from 1 min 12 secs to 2 min 25 secs). - but the new version shows the behavior a couple of layers later (not sure if it's only white noise)
            This is the STL I'm using, just put 12 of these on the print bed, for an estimated print time of less than 3 hours it's a comparably large G-Code file
            https://www.thingiverse.com/thing:2110134
            I'm a technical product manager in tech industry, so let me know if I could further support with troubleshooting.
            I could connect via Telnet to read out additional values but as it's only console top won't work? Is there additional logging/debugging options?
            • TimTomundefined
              TimTom @Phaedrux
              @phaedrux
              Just to annotate, the files are comparably large (one file is 12x the clip, the other 9x clip - both are affected):
              So affected file ~10 MB/h ~ 166 kb/min
              Other printjobs ~2-5 MB/h
              (Print times match pretty good if full speed is maintained)
              Could that be an "overload" of some kind (memory/CPU)?
              Slicing the files with PrusaSlicer for an MK3s results in 5-8hours print time (in dependance of infill) - just as a comparison, file size is similar).
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @TimTom
                @timtom said in print slows down mid print:
                Scheduled moves 349773, completed 349773, hiccups 0, stepErrors 0, LaErrors 0, Underruns [6961, 13, 6362], CDDA state -1
                The high number of underruns may be part of the problem, the question then though is what is causing the underruns? The read times from the SD card look to be fine, but it may be worth trying a different card if you have one, just to be sure.
                TimTomundefined 1 Reply Last reply Reply Quote 0
                • TimTomundefined
                  TimTom @gloomyandy
                  @gloomyandy
                  Thanks for the reply, still learning Duet troubleshooting.
                  Very weired, 10 MB
                  For everyone else running in this issue, @gloomyandy s report is documented here:
                  https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
                  Following documentation, I ran an SD card speed test in Duet:
                  Wow thats slow! It's the stock card, will replace these days (need to find such a small capacity card) . . .
                    jay_s_uk @TimTom
                    @timtom why do you want a small SD card? I tend to use 16gb and 32gb cards
                    • TimTomundefined
                      TimTom @jay_s_uk
                      @jay_s_uk
                      THAT IS SMALL!
                      I usually buy 128 or 256 GB in special offers, also mostly sandisk Ultra or extreme, so I can use them in Cameras, etc. as well. Small cards are comparably expensive (in price per GB).
                        jay_s_uk @TimTom
                        @timtom ah, fair enough. FAT32 doesn't like large cards so not much bigger is supported
                          Phaedrux Moderator @TimTom
                          Free file entries: 8
                          SD card longest read time 4.5ms, write time 2.9ms, max retries 0
                          that looks about right for a Duet3.
                          Trying a new card is worth a try.
                          • TimTomundefined
                            TimTom
                            @jay_s_uk
                            Sorry didn't want to be rude, I tend to pay a Euro more per card to avoid such kind of issues, currently the Sandisk 32 GB cards are only 2 Euros more than the "cheaper noname" cards. Filament cost and the time invest is worth much more than these 2 Euros so far.
                            @Phaedrux
                            Let's hope this solves the issue, cards should arrive today. Nevertheless, the card currently in use, is the stock card coming with the Duet board.
                            Will keep you updated.
                            • TimTomundefined
                              TimTom @Phaedrux
                              @phaedrux @dc42 @gloomyandy
                              I believe I found the Issue - small volume size lead to massive fragementation resulting in horrible SD-card performance.
                              In preparation for the "new cards" I took out the stock card and found out that the 8 GB card only has a 256 MB partition (so only 256 MB were usable).
                              Being curious I reformatted the card to it's full capacity and ran the Speed tests M122 P104 again, surprise, surprise speed tests dramatically improved:
                              with 256 MB partition (mostlikely massivly fragmented):
                              with 8GB partition:
                              Read speed nearly trippled!
                              Trying it again and BAM issue solved! - With the very same SD-Card!!!!
                              My assumptions and maybe what might cause this:
                              • with 256 MB the "volume" is pretty full as my gcode+firmware files already occupied ~200 MB so not a lot of "free space"
                              • doing a several firmware updates and lots of configuration changes, deleting and uploading always performs writes to the SD-card
                              • FAT32 tends to fragment much more than other more modern filesystems
                              • SD-card interface of Duet is not comparable with a high-tech PCIe SSD.
                              Bottom line the small volume got highly fragmented (explanation see below), resulting in super bad performance.
                              Unfortunatly I did not check the SD-card for fragmentation prior deleting, so I have no "proof".
                              Suggestion for Duet
                              I assume the small volume size of 256 GB is a result of historic artifact, because that allows to use any size of SD-card (down to 256 MB) in the production process. My humble suggestion would be
                              • to change the manufacturing process to either start with lager volumes (e.g. 4 GB or 8 GB) or to make this a dynamic process, automatically sizing the partition/volume to the maximum available space (maybe add a cap at 32 GB to take FAT32 limit into account).
                              • for existing customers and new customers receiving such cards, I'd put a clear Note about this topic in the documentation (something like "Consider reformating your SD-card to maximum capacity).
                              *Fragmentation explained by Roland (music instruments) -
                              When an SD card recorder stores new files, it squeezes them into any bits of space it can find. As a result, the data winds up scattered all over the hard drive. When the data from one song file, for example, is stored in many locations within the card memory, the card is said to be fragmented. When the recorder plays back a file from a fragmented card, it has to grab a little piece from here, another piece from there and so on. This is much harder than playing one continuous chunk of data from a single card location. This can slow things down unacceptably and lead to errors during playback, recording and/or any other function in the recorder.
                              Fragmentation is a naturally occurring process for a card used with any computer or recording device. SD cards that record audio are especially prone to fragmentation due to the start-and-stop nature of recording.
                              We recommend backing up all of your data and then initializing the SD card to clear out this normal fragmentation. To avoid receiving errors and/or problems, initialize the card a couple of times a year.. The following steps will guide you through the Card Backup, Card Initialize and Card Recover procedures:*
                              gloomyandyundefined 1 Reply Last reply Reply Quote 1
                                gloomyandy @TimTom
                                @timtom The card supplied with the Duet3 has two partitions on the SD card. The first is a 256Mb FAT volume the second a Linux volume. The Linux volume contains the Duet RPI SBC image. This allows the SD card to be used either with a standalone system (using the FAT partition) or an SBC based system (with the SD card in the RPi). So the small size of the FAT partition is deliberate. As to if this is a good idea, I'll let others decide.
                                  After some investigation we've solved the issue of the too small partitions going forward. There were likely only a very small number of early Duet 3 boards that have the problem.
                                  • TimTomundefined
                                    TimTom @Phaedrux
                                    @phaedrux
                                    Well the board I had was not too old (I received it 1-2 months ago), it already had the current stable version on the SD-card.
                                    As I'm a product manager myself (also for snom phones in the past = embedded devices), I'm very curious on what the solution is. Having invested some time and money (filament and new SD-cards), I'd love to hear what your conclusions are. Feel free to reach out on separate channel 🙂
                                      The board you got may have been produced much earlier than when you bought it.
                                      The solution was just to change the amount of space allocated to the pi partition and the standalone partition so that the standalone isn't limited to such a small space.
                                      • TimTomundefined
                                        TimTom @Phaedrux
                                        @phaedrux
                                        Ahh ok, so you already adjusted the partition scheme, great to hear 🙂
                                        According to serial my board was 2021-06.
                                        Nevertheless I'd add a note to Setup/install guide, I'd written something but can't find my docu credentials at the moment.
