Eccentric Probe on a Delta Printer
711
    ignacmc
    Hello to all.
    I am thinking about resurrecting my Anycubic Kossel Linear Plus with a Duet board. But I would prefer to reuse a Superpinda sensor that I have at hand as a probe. Obviously this can only be mounted eccentrically (around 30mm X Offset and 20mm Y Offset). I have tried before using Marlin and Klipper but despite all the Delta Calibration and Z offset calibration routines being completed successfully, the first layer is rubbish, being too thin at one side and too thick at the opposite. Of course I have correctly accounted for the X and Y offset in the configuration files.
    My question is: Is an eccentric probe a VIABLE OPTION for a Delta? Can I do Delta Calibration automatically with the SuperPinda or doing it manually with a paper grab test is my only option?
    I know a eccentric probe causes problems with effector tilting, but I had hoped it could be compensated by the software.
    Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
    undefined undefined undefined 3 Replies Last reply 2 Feb 2022, 09:32 Reply Quote 0
      jay_s_uk @ignacmc
      @ignacmc an offset probe doesn't cause effector tilt but is affected by it. The issue you'll have is you don't know how much the effector is tilting at each point so my advice would be use a removeable probe that sits below the hotend on X0 Y0.
      undefined 1 Reply Last reply 2 Feb 2022, 09:47 Reply Quote 0
        ignacmc @jay_s_uk
        @jay_s_uk A removable probe that sits below the nozzle came from factory with the printer....but after getting used to inductive sensors with my Prusa Mini, I would like to replicate it on a Delta...definitively it cannot be done? I believe that Tevo Little Monster and others (FLSun?) use eccentric probes (BLTouch). And i suppose it works for them.
        undefined 1 Reply Last reply 2 Feb 2022, 09:49 Reply Quote 0
          jay_s_uk @ignacmc
          @ignacmc as i say, i wouldn't advise it. you're just entering a world of pain for no gain. i wouldn't touch any delta that installs an offset bltouch
          undefined 1 Reply Last reply 2 Feb 2022, 09:52 Reply Quote 0
            ignacmc @jay_s_uk
            @jay_s_uk Noted! šŸ˜‰ I would like to know the experience of a BLTouch Delta Printer owner just for curiosity....
            ? 1 Reply Last reply 2 Feb 2022, 10:28 Reply Quote 1
              A Former User @ignacmc
              This post is deleted!
              undefined 1 Reply Last reply 2 Feb 2022, 11:08 Reply Quote 1
                Barracuda72 @ignacmc
                @ignacmc Honestly..i started with a Anycubic Kossel too many years ago..if you want to invest a duet board into that printer...do it right and take also the Smart effector. beside the fact that you are mostly bound to the V6 hotends its still the hottest sh** for a Delta Printer...no offset in probing...and no thinking about Z-Offset after a nozzle change
                undefined 1 Reply Last reply 2 Feb 2022, 11:25 Reply Quote 0
                  ignacmc @A Former User
                  @arnold_r_clark Thanks Arnold...your very clear explanation adds to jay's one...I think is time for getting another SmartEffector. Or doing fully manual calibration with the nozzle tip ignoring the inductive sensor...
                    ignacmc @Barracuda72
                    @barracuda72 I already have a Predator set up that way (Duet3 Mini 5+ with Smarteffector) and perfect so far!
                      CabalSoul @ignacmc
                      @ignacmc I’m using a Super Pinda on an Anycubic predator. I use it solely for z datum.
                      When I’m calibrating I’m using a fsr nozzle probe. It works great that way.
                      Due to the offset and effector tilt I would strongly advise against using it as the only z probe.
                      Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
                      undefined 1 Reply Last reply 2 Feb 2022, 13:49 Reply Quote 0
                        ignacmc @CabalSoul
                        Thanks to everybody for your time and suggestions. You have made this issue crystal clear to me šŸ˜‰
                        Wonder why some manufacturers still ship deltas with bltouch....
                        7 out of 11
