    newbie with MFM
    Filament Monitor
    756
    • apakundefined
      apak
      Just about to start my mfm config.
      First question, what is this number writen on the board means?photo_2022-02-03_09-44-06.jpg
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @apak
        @apak i think, this could be a serial number
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • apakundefined
          apak
          Well, I got this msg,
          Duet3D rotating magnet filament monitor v1 on pin 121.io1.in, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 10.0mm, no data received
          config
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jan 23 2022 08:20:22 GMT+0100 (hora estándar de Europa central)
          M575 P1 S1 B57600                                         ; enable support for PanelDue
          G90                                                       ; send absolute coordinates...
          M83                                                       ; ...but relative extruder moves
          M550 P"URmaker"                                           ; set printer name
          ;M918 P1 E4 F2000000                                       ; configure direct-connect display LCD
          ; Wait a moment for the CAN expansion boards to start
          G4 S2
          M552 S1                                                   ; enable network
          M586 P0 S1                                                ; enable HTTP
          M586 P1 S0                                                ; disable FTP
          M586 P2 S0                                                ; disable Telnet
          M569 P0.0 S0                                              ; physical drive 0.0 goes backwards X
          M569 P0.1 S1                                              ; physical drive 0.1 goes forwards Y
          M569 P0.2 S1                                              ; physical drive 0.2 goes forwards Z1
          M569 P0.3 S1                                              ; physical drive 0.2 goes forwards Z2
          M569 P121.0 S1                                            ; physical drive 121.0 goes forwards E
          M584 X0.0 Y0.1 Z0.2:0.3 E121.0                                ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z640.00 E415.00                         ; set steps per mm
          M566 X600.00 Y600.00 Z30.00 E120.00                       ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z600.00 E3000.00                 ; set maximum speeds (mm/min)
          M201 X900.00 Y900.00 Z200.00 E600.00                       ; set accelerations (mm/s^2)
          M906 X1400 Y1400 Z1400 E1400 I30                          ; set motor currents (mA) and motor idle factor in per cent
          M84 S120                                                  ; Set idle timeout
          M208 X0 Y-10 Z-1 S1                                      ; set axis minima
          M208 X550 Y360 Z300 S0                                    ; set axis maxima
          ; Leadscrews Definition for Z_Tilt
          M671 X-178:732 Y148:148 S8								; OJO revisar y medir la posicion de los husillos
          M574 X2 S1 P"!io5.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in
          M574 Y2 S1 P"!io6.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
          M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
          ;M574 Z1 S1 P"!io3.in+!io2.in"								; configure switch-type 2 endstop independent
          ; Filament Sensor
          ;M98 P"0:/sys/00-Functions/FilamentsensorStatus"
          M591 D0 P3 C"121.io1.in" S1 R70:130 L24.8 E10.0
          M558 P8 C"!121.io0.in" H10 F300:150 T6000 R0.5        			  ; set Z probe type to unmodulated and the dive height + speeds
          G31 P1000 X-25 Y45 Z6.29 ;Z6.37                                    ; set Z probe trigger value, offset and trigger height
          M556 S50 X0 Y0 Z0                                         ; set orthogonal axis compensation parameters
          M557 X10:520 Y35:365 P5:4                                 ; define mesh grid
          ; Heaters BED
          M308 S0 P"temp0" Y"thermistor" T100000 B4092 A"Heated Bed"             ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                   ; map heated bed to heater 0
          M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
          M143 H0 P0 S120 A2										; disable temporarily H0 if temp exceeds 120C
          M143 H0 P0 S130 A0										; heater fault H0 if temp exceeds 130C
          M570 H0 P60 T15 S0 										; heater fault for 15 seg of 60C excursion
          ; Heaters HOTEND
          M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
          M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
          M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
          M143 H1 S275 A2											; disable temporarily H1 if temp exceeds 275C
          M143 H1 S285 A0											; heater fault H1 if temp exceeds 280C
          M570 H1 P10 T30 S0										; heater fault for 10 seg of 30C excursion
          ; Fan0 = Part Coooling
          M950 F0 C"121.out1" Q500                                  ; create fan 0 on pin 121.out1 and set its frequency
          M106 P0 S0 H-1                                            ; set fan 0 value. Thermostatic control is turned off
          ; Fan1 = Hotend
          M950 F1 C"121.out2" Q500                                  ; create fan 1 on pin 121.out2 and set its frequency
          M106 P1 S1 H1 T45                                         ; set fan 1 value. Thermostatic control is turned on
          ; Fan2 = Case Fan
          M950 F2 C"out5" Q500                                      ; create fan 2 on pin out5 and set its frequency
          M106 P2 S1 H1 T45                                         ; set fan 2 value. Thermostatic control is turned on
          ; PID Backup
          M307 H0 R0.505 C362.346:362.346 D9.17 S1.00 V23.8 B0 I0
          M307 H1 R4.689 C199.474:103.181 D7.28 S1.00 V22.7 B0 I0
          M563 P0 S"T0" D0 H1 F0                                   ; define tool 0
          G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
          G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
          M302 S180 R180                                         ; allow extrusion starting from 180°C and retractions already from 180°C
          ; Firmware Retraction
          M404 N1.75										; Define filament diameter for print monitor
          M207 S0.95 R0 F2400 Z0							; Firmware retraction
          ; LCD
          M501                                                      ; load saved parameters from non-volatile memory
          M703														; Load Preloaded filamento config
          M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
          T0                                                        ; select first tool
          Checked wiring and seams OK...
          MFM Toolboard
          3.3v 3.3v
          gnd gnd
          out io1.in
          • apakundefined
            apak
            red led flashes 7 times, it´s a v1 magnet, so how can I fix this issue?
            apakundefined 1 Reply Last reply Reply Quote 0
            • apakundefined
              apak @apak
              @apak sanded top part and now it´s flashing red/green, will try now
              apakundefined alankilianundefined 2 Replies Last reply Reply Quote 0
              • apakundefined
                apak @apak
                @apak
                M591 D0
                Duet3D rotating magnet filament monitor v3 on pin 121.io1.in, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 10.0mm, version 3, mag 125 agc 128, no calibration data
                NEED more sanding I presume
                • infiniteloopundefined
                  infiniteloop
                  Does the axis of the hobbed assembly rotate when you push filament through the sensor? If you are not sure, have a look at this thread.
                  • alankilianundefined
                    alankilian @apak
                    @apak It won't get "real" data until you print something.
                    I'm not sure if hitting the "Extrude" button on DWC will be enough or if you actually have to start a print and wait a little bit.
                    • apakundefined
                      apak @alankilian
                      @alankilian it works fine, I adjust the value, but once pause and resume, the values where doubled and kept on pausing
                        alankilian @apak
                        @apak Post the results of M591 D0 before and during the pause.
                        Also, your AGC value of 128 is too high.
                        THIS page says what to do about it:
                        Values for 'agc' of 50 to 105 are considered normal.
                        If the value is higher, up to 128, the distance between the magnet and the sensor is
                        likely to be too large (target is 0.25mm).
                        Check that the screws holding the PCB down are not loose (caution: they are
                        screwed into the plastic, so don't over-tighten them). If they are already tight, you
                        could remove the 2 long screws to separate the two plastic parts and very slightly
                        sand down the bottom surface of the top one (the one with the PCB attached) to
                        move the sensor closer to the magnet.
                        apakundefined 1 Reply Last reply Reply Quote 1
                        • apakundefined
                          apak @alankilian
                          5/3/2022, 16:10:17	M591 D0
                          Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 113 agc 128, error 7
                          5/3/2022, 16:10:16	M591 D0
                          Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 116 agc 128, measured sensitivity 28.06mm/rev, min 36% max 106% over 45.6mm
                          getting ERROR 7 every now and then, so I am not able to use MFM
                          right now it´s disable so I can monitor what happens as it keeps logging data even disabled
                          • apakundefined apak referenced this topic
                          • apakundefined
                            apak @apak
                            @apak
                            M122
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                            Board ID: 0JD0M-9P6M2-NW4SD-6J1DL-3SN6K-1TQ7K
                            Used output buffers: 10 of 24 (21 max)
                            Static ram: 23876
                            Dynamic ram: 76888 of which 176 recycled
                            Never used RAM 10620, free system stack 110 words
                            Tasks: NETWORK(ready,14.2%,244) HEAT(delaying,0.0%,330) Move(notifyWait,0.2%,309) MAIN(running,85.4%,445) IDLE(ready,0.2%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:36:12 ago, cause: power up
                            Last software reset at 2022-02-18 00:31, reason: User, GCodes spinning, available RAM 11004, slot 2
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 26.4, current 41.1, max 45.8
                            Supply voltage: min 23.5, current 24.2, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/20, heap memory allocated/used/recyclable 2048/930/728, gc cycles 8
                            Driver 0: position 19172, ok, SG min/max 0/302
                            Driver 1: position 301, ok, SG min/max 0/304
                            Driver 2: position 249, ok, SG min/max 0/1023
                            Driver 3: position 0, standstill, SG min/max 0/1023
                            Driver 4: position 0, ok, SG min/max 0/295
                            Driver 5: position 0
                            Driver 6: position 0
                            Driver 7: position 0
                            Driver 8: position 0
                            Driver 9: position 0
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2022-03-12 10:09:46
                            Slowest loop: 136.97ms; fastest: 0.11ms
                            === Storage ===
                            Free file entries: 8
                            SD card longest read time 4.5ms, write time 159.6ms, max retries 0
                            DMs created 83, maxWait 622074ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 13127, completed moves 13119, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.4
                            Heater 1 is on, I-accum = 0.2
                            Segments left: 1
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is doing "G1 X140.482 Y140.933" in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is doing "G4 S2 " in state(s) 0 0, running macro
                            Code queue is empty.
                            === Filament sensors ===
                            Extruder 0: pos 63.28, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                            === Network ===
                            Slowest loop: 162.91ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            - WiFi -
                            Network state is active
                            WiFi firmware version 1.26
                            WiFi MAC address bc:ff:4d:45:5d:1f
                            WiFi Vcc 3.31, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 20008
                            WiFi IP address 192.168.0.51
                            WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            • apakundefined
                              apak @apak
                              @apak ```
                              12/3/2022, 10:08:48 M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.37mm/rev, min 10% max 116% over 710.7mm
                              Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, error 7
                              12/3/2022, 10:08:47 M591 D0
                              12/3/2022, 10:08:46 M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 112 agc 128, error 7
                              12/3/2022, 10:08:45 M591 D0
                              12/3/2022, 10:08:44 M591 D0
                              12/3/2022, 10:08:43 M591 D0
                              12/3/2022, 10:08:42 M591 D0
                              12/3/2022, 10:08:41 M591 D0
                              12/3/2022, 10:08:39 M591 D0
                              12/3/2022, 10:07:58 M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.14mm/rev, min 10% max 115% over 690.7mm
                              12/3/2022, 10:07:57 M591 D0
                              12/3/2022, 10:07:56 M591 D0
                              12/3/2022, 10:07:55 M591 D0
                              12/3/2022, 10:07:53 M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.17mm/rev, min 10% max 115% over 680.7mm
                              12/3/2022, 10:07:52 M591 D0
                              12/3/2022, 10:07:51 M591 D0
                              12/3/2022, 10:07:49 M591 D0
                              12/3/2022, 10:07:48 M591 D0
                              12/3/2022, 10:07:47 M591 D0
                              12/3/2022, 10:07:46 M591 D0
                              12/3/2022, 10:07:44 M591 D0
                              12/3/2022, 10:07:43 M591 D0
                              12/3/2022, 10:07:42 M591 D0
                              12/3/2022, 10:07:40 M591 D0
                              12/3/2022, 10:07:35 M591 D0
