    PanelDue White screen after firmware update
    PanelDue
    509
    • Nurgelrotundefined
      Nurgelrot @Kris75
      @kris75 When mine did this it was because I flashed it with the wrong firmware file. In my case I confused the 7i with the 7 v3. Erasing and reflashing corrected it.
      Kris75undefined 1 Reply Last reply Reply Quote 0
      • Kris75undefined
        Kris75 @Nurgelrot
        @nurgelrot said in PanelDue White screen after firmware update:
        I was uploading all files from different versions available on github, all on a white screen.
          I believe this should be the correct file
          https://github.com/Duet3D/PanelDueFirmware/releases/download/3.4.0/PanelDueFirmware-3.4.0-5.0i.bin
          The screen doesn't look white though in your photo, it looks like there are stripes as if the LCD is failing.
          Was the Paneldue working previously?
          • Kris75undefined
            Kris75
            @phaedrux said in PanelDue White screen after firmware update:
            yes, it worked before. The bars appear when I load the PanelDue-5.0i-7.0i.bin file, e.g. since version 1.24
            • Kris75undefined
              Kris75 @Phaedrux
              Unfortunately, PanelDueFirmware-3.4.0-5.0i.bin is not working.
              after the reset there is a white screen, the screen makes a sound when I touch in places where the screen calibration points should be, after clicking on the last point the screen displays gray stripes, it reacts with a sound when you touch random places on the screen.
                Phaedrux Moderator @Kris75
                @kris75 said in PanelDue White screen after firmware update:
                Are you saying firmware before 1.24 still work correctly?
                • Kris75undefined
                  Kris75 @Phaedrux
                  No. Now no software works.
                  I was uploading versions from 1.17 to 3.4 - it does not work
                    Can you show a screen shot of your Bossa window so we can verify the settings?
                    • Kris75undefined
                      Kris75 @Phaedrux
                      ok. This is a sample file from version 1.24
                      • Kris75undefined
                        Kris75
                        Can anyone help? Is the paneldue to be thrown into the garbage?
                          Can you post a better photo of the screen? It looks more like the screen is damaged than a firmware problem.
