    Tool change issues after firmware update 1.19.2
    7.0k
    • MrTundefined
      MrT
      Dear good night
      Had a chance to look at my issue ?
      Thanks
      Best regards
      Manuel Topiol
        T3P3Tony administrators
        Hi, I have tested tool changes using an IDEX machine with the following setup:
        Firmware Version: 1.19.2 (2017-09-01)
        WiFi Server Version: 1.19.2
        Web Interface Version: 1.19
        Using your Tpre,Tfree files, modified only slightly so they do not crash the heads on my IDEX, i can't reproduce the problem.
        Starting with T0 selected, I enter T1, the movements associated with Tfree0 occur, then the ones in Tpre1. With T1 selected I enter T0, the movements associated with Tfree1 occure, the Tpre0.
        The selected hotend (as shown in DWC) changes as commanded.
        Things I am doing differently from you:
        1. Using an Idex printer so X mapping is different from T0 and T1
        2. Homing in my Tpre/TFree files to protect the two heads from crashing.
        • MrTundefined
          MrT
          Thanks for the reply
          So from where could this problem come from ?
          I am out of idea , and I can't understand why with 1.18.2 it's working and not with 1.19.2 ,I changed nothing to my setup 😞
          Best regards
          Manuel
            Please post your config.g file, and confirm that you have no tpost0.g or tpost1.g file.
            • MrTundefined
              MrT
              The problem is not associated with movements generated by the tpost tpre and three, the problem is with the tool active and standby
              Let's say when I start the printer I home x y and z then I click on tool0 it goes and collects tool0 no problem there ,the tool is loaded and active
              When I click again on tool0 it goes to unload and parks the tool0 and put the tool in standby
              Now when I go and click on tool1 it goes as expected loading tool1 but after it has collected tool1 it puts tool1 in standby and tool0 as active but the tool1 is still loaded
              The result is the same for the 3 test I have made , 1 just by clicking on the web use interface, 2 by sending gcode to the printer , or 3 adding gcode in the slicer to deal with the tool changed , there is no scenario where I can keep my tool1 active
              it is definitively something to do with the firmware
              I really need some help on this issue
              Thanks for your understanding
              Best regards
              Manuel
                As David says please post your config.g and your T post files (if you have any)
                • MrTundefined
                  MrT
                  Dear Sorry was on my mobile did not see David's Post
                  please find her under the config file
                  M111 S0
                  G21
                  G90
                  M83
                  M555 P2
                  M208 X0 Y0 Z-1 S1
                  M208 X200 Y200 Z306 S0
                  M574 X1 Z2 S0
                  M574 Y1 S0
                  M558 P1 X0 Y0 Z1 H3 F200 T6000
                  G31 P500 X0 Y0 Z0.3
                  M557 X10:140 Y10:140 S20
                  M569 P0 S0
                  M569 P1 S0
                  M569 P2 S1
                  M569 P3 S1
                  M569 P4 S1
                  M350 X16 Y16 E16:16 I1
                  M350 Z16 I0
                  M92 X160 Y160 Z400 E837:837
                  M566 X400 Y400 Z15 E100:100
                  M203 X10000 Y10000 Z2400 E1500:1500
                  M201 X1200 Y1200 Z200 E3000:3000
                  M906 X1400 Y1400 Z1300 E1400:1400
                  M84 S0
                  M143 H0 S110
                  M143 H1 S335
                  M143 H2 S265
                  M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30
                  M305 P2 T100000 B4138 C0 R4700 X201
                  M305 P1 T100000 B4138 C0 R4700 X200
                  M305 P0 T100000 B4725 C7.060000e-8 R3750 X1
                  M563 P0 D0 H1
                  G10 P0 X-19.92 Y-0.20 Z0.0
                  G10 P0 R0 S0
                  M563 P1 D1 H2
                  G10 P1 X19.8 Y0 Z-0.09
                  G10 P1 R0 S0
                  M550 PMy printer
                  M552 S1 ;
                  M587########################
                  M586 P0 S1
                  M586 P1 S0
                  M586 P2 S0
                  M106 P2 S0.3 I0 F12 H-1
                  M106 P1 S1 I0 F100 H-1
                  M106 P0 S1 I0 F10 H-1
                  tfree0:
                  G90
                  M83
                  G91
                  G1 Z5 F6000
                  G90
                  G1 X-15 F6000
                  G1 Y180 F6000
                  G1 X30 F6000
                  G1 X70 F6000
                  tfree1
                  G90
                  M83
                  G91
                  G1 Z5 F6000
                  G90
                  G1 X195 Y50 F6000
                  G1 Y180 F6000
                  G1 X50 F6000
                  G1 Y50 F6000
                  tpre0
                  G90
                  M83
                  G0 X50 F6000
                  G1 Y180 F6000
                  G1 X5 F6000
                  G1 Y50 F6000
                  tpre1
                  G90
                  M83
                  G0 X50 F6000
                  G1 Y180 F6000
                  G1 X175 F6000
                  G1 Y50 F6000
                  thanks
                  Manuel Topiol
                  • MrTundefined
                    MrT
                    Friendly bump
                    Best regards
                    Manuel
                    • MrTundefined
                      MrT
                      Dear dc42 & t3p3tony
                      Did u have any chance to check on my issue , I am still Struggling with it , I can confirme that the issue is not related with the tfree tpre and tpost , if I disabled them and do the tool change movements via the slicer I get the same result the wrong tool is active when I switch to tool1
                      In the hope of hearing from you
                      Best regards
                      Manuel Topiol
                      • MrTundefined
                        MrT
                        Gentle bump bump
                        Regards
                        Manuel
                          We're going to be busy with the TCT show for the next week, so feel free to remind us after that.
                          Also please check whether this is a Duet Web Control bug, or whether the same bug occurs if you send the appropriate T commands directly. One of my machines exhibits an inability to select or deselect a tool using the Tool link in DWC 1.19, but it works fine if I send the appropriate T commands from the GCode Console.
                          • MrTundefined
                            MrT
                            Dear thanks for your reply
                            with the t command I get the same result I have been trying every possible combinations with no success, I am supprized that no more people are experiencing the same problems , or maybe less people are using a tool change
                            Ok i will recontacter you after your show , hope it goes well , good luck !!!
                            Best regards
                            Manuel Topiol
                            • number40fanundefined
                              number40fan
                              There were directions to roll back to 1.18 if you wanted to do that, just to confirm it is an update issue.
                              • MrTundefined
                                MrT
                                Good day
                                Yes I did roll back the issue was gone , then I did the update again the issue was back , since then I am doing try and error to pin point where the issue is comming from.
                                The steps I undertook where :
                                1 ) tool change with a very basic gcode file just switchings from t0 to t1 to t0 to t1 with the tfree tpost tpre active
                                2 )deactivated the tfree tpost tpre and did the tool change from within the slicer
                                3 )tripel checked my config file and cabeling
                                Issue stays the same what ever I do .the active tool remains t0 after loading t1
                                Every test I did tend to let me think it's an update issue or some mistake on my part but it's not very likely I have my config info in a previous post maybe you could help me have a double check
                                Best regards
                                Manuel
                                  Are you certain that Tool 0 stays active after you select Tool 1, and it isn't that DWC is mis-reporting it? If you send G10 P0 S0 then this should cool down tool 0 if it really is active, but do nothing if it isn't.
                                  You can remove the M587 command from config.g, it only needs to run once to save your access point details on the WiFi module.
                                  • MrTundefined
                                    MrT
                                    Dear ,
                                    yes I am sure that it is not a reporting error from the web interface cause when I try to park t1 back the tool it's crashing with tool0 trying to park back tool0 with isn't loaded tool1 is
                                    Thanks
                                    Best regard
                                    Manuel
                                    • MrTundefined
                                      MrT
                                      dear DC42
                                      Hope you had a successful trade show saw some videos on YouTube 🙂 next year I will try to come , if time permits
                                      I was overseas for some time, just came back .
                                      So nothing changed to my situation , so I am coming back to you 🙂
                                      Best Regards
                                      Manuel Topiol
                                        Thanks for the reminder.
                                        Please try firmware 1.20beta2. It probably won't change anything, but I need to know that the fault is still present.
                                        Pending your report, I have this on my list to look at tomorrow.
                                        • MrTundefined
                                          MrT
                                          Good evening
                                          Thanks for the quick responds
                                          I will update the firmware to 1.20beta 2 1st thing in the morning and revert with result
                                          Best Regards
                                          Manuel
                                          • MrTundefined
                                            MrT
                                            Dear I have done the update of the firmware per your request
                                            Situation is the same with a slight difference
                                            now when I select tool 0 from a fresh machine boot , it doesn't complete the full tool change, the gcode file is not fully processed,
                                            as opposed to before I could just type T0 and it will collect the tool without problem .
                                            after I put the T0 back in standby and do an other T0 I will get it correctly ,
                                            then I do a T1 command and it will fetch tool1 but after the selection is complete T0 is set to active.
                                            , I feel strange, for sure I am not the only guy owning a duet wifi with a tool change, but no one else is complaining about this problem
                                            Best Regards
                                            Manuel Topiol
