    firmware 3.4 Rc1 Heater Fault
    713
      T3P3Tony administrators @massimilianoconti
      @massimilianoconti said in firmware 3.4 Rc1 Heater Fault:
      M303 T1 S270 Y3
      how does the tuning look when you run it?
      massimilianocontiundefined 1 Reply Last reply Reply Quote 0
      • massimilianocontiundefined
        massimilianoconti @T3P3Tony
        when I start tuning takes too long something in the algorithm must be changed. if I put 3 as hysteresis comes to completion for example. something needs to be changed in the tuning procedure. my hotend is geometrically excellent, it is designed to perform every temperature and material
        T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          @massimilianoconti do me a favour and run the tuning and post the results here.
            10/2/2022, 13:29:16 Warning: heater behaviour was not consistent during tuning
            Auto tuning heater 1 completed after 3 idle and 50 tuning cycles in 2520 seconds. This heater needs the following M307 command:
            M307 H1 R2.558 K0.275:0.103 D6.31 E1.35 S1.00 B0 V23.9
            Send M500 to save this command in config-override.g
            10/2/2022, 13:05:33 Warning: heater behaviour was not consistent during tuning
            Auto tune starting phase 4, measuring with fan on
              Phaedrux Moderator @massimilianoconti
              Can you give us some details about it?
                massimilianoconti
                my hot end is Phaetus dragonfly bmsBMSÕ«×Õ+⵿íÕ×ï.stl BMS Wireframes (7).pdf
                  That's a lovely hotend. What power is the heater? Are you using the sock? Do you have a part cooling fan and duct? Can you share an image of the temperature graph from the tuning?
                  massimilianocontiundefined 2 Replies Last reply Reply Quote 0
                  • amjm22undefined
                    amjm22
                    Have you tried bumping up the "deadtime" D6.31? I bumped mine up to D8.31 and the heat faults have gone away.
                      massimilianoconti @amjm22
                      I try thanks
                        massimilianoconti @Phaedrux
                        you have the silicone socks I'm reviewing everything as soon as I perform a new test I attach it
                        amjm22undefined 1 Reply Last reply Reply Quote 0
                          hello as soon as I have the data I attach them. I wanted to know what compiler you need to open the source code to change the firmware... from the asset I downloaded in zip the purge code but you need a compiler ...
                          • amjm22undefined
                            amjm22 @massimilianoconti
                            @massimilianoconti yes
