    firmware 3.4 Rc1 Heater Fault
    695
    • massimilianocontiundefined
      massimilianoconti
      duet 3 v1.01
      firmware 3.4 rc1
      M303 T1 S270 Y3
      the problem of the heater is not solved, something must be changed in the firmware must be made more stable and reliable. it is not convenient to continuously add new features but make a stable and precise firmware then slowly add other news. otherwise you will never get to a fully functional software
      oliofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @massimilianoconti
        @massimilianoconti your error description is awfully sparse to allow me to agree with your claim that the software is not stable and reliable,especially since your anecdotal claim seems to clash with the experience of others.
        To figure out whether this is a documentation issue, a firmware issue, a configuration issue, or a wiring issue, I'd need some more information from you. Please provide your config.g, and the output of M115 and M122 for starters, a photo of your wiring (connection on the board side for heater and thermistor, print head setup) is optional but may be helpful.
        massimilianocontiundefined 1 Reply Last reply Reply Quote 0
          massimilianoconti @oliof
          the wiring is fine the mechanics and thermal side are fine is an unresolved problem of the firmware, this defect was previously not there. I had pointed out copme other users the problem already in version 3.4 beta 7 the only thing maybe is the different sensor the pt1000 of e3d.
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.4.0rc1 (2022-02-09 10:28:13) running on Duet 3 MB6HC v1.01 or later (standalone mode)
          Board ID: 08DJM-9P63L-DJMSS-6J9DD-3S46N-TVFH8
          Used output buffers: 1 of 40 (22 max)
          Static ram: 150984
          Dynamic ram: 95712 of which 164 recycled
          Never used RAM 103548, free system stack 142 words
          Tasks: NETWORK(ready,26.4%,229) ETHERNET(notifyWait,0.1%,168) HEAT(notifyWait,0.0%,238) Move(notifyWait,0.0%,262) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,8.1%,58) MAIN(running,65.3%,925) IDLE(ready,0.0%,30), total 100.0%
          Owned mutexes:
          Last reset 00:14:15 ago, cause: power up
          Last software reset at 2022-02-07 21:11, reason: User, GCodes spinning, available RAM 100532, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 131
          MCU temperature: min 24.6, current 39.4, max 39.5
          Supply voltage: min 16.2, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: pos 192000, standstill, SG min 0, mspos 583, reads 54286, writes 23 timeouts 0
          Driver 1: pos 0, standstill, SG min 0, mspos 617, reads 54286, writes 23 timeouts 0
          Driver 2: pos 33603, standstill, SG min 0, mspos 649, reads 54286, writes 23 timeouts 0
          Driver 3: pos 0, standstill, SG min 0, mspos 1, reads 54295, writes 14 timeouts 0
          Driver 4: pos 0, standstill, SG min 0, mspos 1, reads 54296, writes 14 timeouts 0
          Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 54299, writes 11 timeouts 0
          Date/time: 2022-02-10 12:52:42
          Slowest loop: 5.17ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 5.6ms, write time 0.9ms, max retries 0
          DMs created 125, segments created 11, maxWait 377072ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 29, completed 29, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 7701, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 4280/0/0
          Tx timeouts 0,0,4279,0,0,3420 last cancelled message type 30 dest 127
          === Network ===
          Slowest loop: 18.71ms; fastest: 0.02ms
          HTTP sessions: 1 of 8
          • Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            10/2/2022, 12:51:58 Auto tune starting phase 3, measuring
            10/2/2022, 12:49:54 Auto tune starting phase 2, settling
            10/2/2022, 12:47:20 Auto tune starting phase 1, heating up
            10/2/2022, 12:47:15 M98 P"0:/macros/Tuning T0"
          m115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0rc1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-02-09 10:28:13
          ; Configuration file for Duet 3 (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 31 2021 12:22:58 GMT+0100 (Ora standard dell’Europa centrale)
          M550 P"Duet 300X Dual" ; set printer name
          M955 P0 C"spi.cs3+spi.cs2"
          M669 K1 ; select CoreXY mode
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.2 S0 ; physical drive 0.2 goes forwards
          M569 P0.3 S0 ; physical drive 0.3 goes forwards
          M569 P0.4 S0 ; physical drive 0.4 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
          M350 X128 Y128 Z128 E128:128 I1 ; configure microstepping with interpolation
          M92 X640.00 Y640.00 Z5171.72 E3367.10:3367.70 ; set steps per mm
          M566 X800.00 Y800.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z500.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X2000.00 Y2000.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M593 P"zvd" F70
          M208 X-18 Y-5 Z0 S1 ; set axis minima
          M208 X305 Y305 Z260 S0 ; set axis maxima
          M671 X10:295:295:10 Y280:280:5:5 P0.5
          M591 D0 P5 C"e0_stop" R40:120 E3.0 S0
          M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
          M574 Y1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
          M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
          M558 P9 C"^io7.in" H5 F500:100 T6000 A5 R0.1 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X12.5 Y-20 Z1.493 ; set Z probe trigger value, offset and trigger height
          M557 X15:295 Y15:300 S25:20 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
          M950 H0 Q10 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
          M143 H0 S130 ; set temperature limit for heater 0 to 120C
          M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as PT1000 on pin temp1
          M143 H1 S400 ; set temperature limit for heater 1 to 400C
          M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2
          M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H2 S280 ; set temperature limit for heater 2 to 280C
          M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
          M106 P0 S0 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
          M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
          M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
          M563 P0 D0 H1 F1 ; define tool 0
          M563 P1 D1 H2 F1 ; define tool 0
          G10 P1 X25 Y0 Z0 ; set tool 0 axis offsets
          T0 ; select first tool
          M150 X0 ; set LED type to NeoPixel and set SPI frequency to 3MHz
          M150 B255 P128 S65 F0
          M501
            T3P3Tony administrators @massimilianoconti
            @massimilianoconti said in firmware 3.4 Rc1 Heater Fault:
            M303 T1 S270 Y3
            how does the tuning look when you run it?
              massimilianoconti @T3P3Tony
              when I start tuning takes too long something in the algorithm must be changed. if I put 3 as hysteresis comes to completion for example. something needs to be changed in the tuning procedure. my hotend is geometrically excellent, it is designed to perform every temperature and material
              T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                @massimilianoconti do me a favour and run the tuning and post the results here.
                  10/2/2022, 13:29:16 Warning: heater behaviour was not consistent during tuning
                  Auto tuning heater 1 completed after 3 idle and 50 tuning cycles in 2520 seconds. This heater needs the following M307 command:
                  M307 H1 R2.558 K0.275:0.103 D6.31 E1.35 S1.00 B0 V23.9
                  Send M500 to save this command in config-override.g
                  10/2/2022, 13:05:33 Warning: heater behaviour was not consistent during tuning
                  Auto tune starting phase 4, measuring with fan on
                    Phaedrux Moderator @massimilianoconti
                    Can you give us some details about it?
                      massimilianoconti
                      my hot end is Phaetus dragonfly bmsBMSÕ«×Õ+⵿íÕ×ï.stl BMS Wireframes (7).pdf
                        That's a lovely hotend. What power is the heater? Are you using the sock? Do you have a part cooling fan and duct? Can you share an image of the temperature graph from the tuning?
                        massimilianocontiundefined 2 Replies Last reply Reply Quote 0
                        • amjm22undefined
                          amjm22
                          Have you tried bumping up the "deadtime" D6.31? I bumped mine up to D8.31 and the heat faults have gone away.
                            massimilianoconti @amjm22
                            I try thanks
                              massimilianoconti @Phaedrux
                              you have the silicone socks I'm reviewing everything as soon as I perform a new test I attach it
                              amjm22undefined 1 Reply Last reply Reply Quote 0
                                hello as soon as I have the data I attach them. I wanted to know what compiler you need to open the source code to change the firmware... from the asset I downloaded in zip the purge code but you need a compiler ...
                                • amjm22undefined
                                  amjm22 @massimilianoconti
                                  @massimilianoconti yes
