Connecting stepper motor encoders to closed loop drivers
@alankilian Where will I find SW6?
@alankilian Oh okay what do i want the rest of them to be set to?
@v-a-m-p-printing-snproj Set SW1-4 to how ever many pulses-per-rev you want.
What did you have your microstepping set to? 16x? with a 1.8-degree motor that would be 200 * 16 = 3200 steps-per-rev which is SE1-4 Off Off On On Or I bet you could see what your old driver was set to and copy that.
Oh HEY!!! SW5 changes the direction so you don't have to change the "S" setting in your configuration.
And SW6 should be ON to set open-loop control.
They are all described on the front of your driver.
@alankilian Okay I copied the settings from my other drivers already so ill changing the direction and see how it goes. Thanks!
Yes, I can read the switches on your old driver and it was set to 3200 steps-per-rev
Also set the rotary switch to 0 so when you start your closed-loop experiments it will be "weak". You can make it stronger once you get things working.
All the switches are described in the manual available HERE.
SW7 should be OFF to select step/direction mode.
@alankilian I got it moving in the right direction and it hits the x y limit switches but continues trying to drive through the x limit switch. What could be causing this?
Post your config.g, homex.g, homey.g homez.g homeall.g homedelta.g config-override.g and all that and we'll take a look. (You might not have all those files)
- Did you change the direction using the "S" parameter or did you change using the switch on the driver?
- Did your printer work well with the old drivers?
@alankilian I changed the direction with the switch on the driver and it printed alright, prints were sloppy. I ordered a new hot end so hopefully that helps with the sloppy prints when i get it moving right again.
Config .g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:39 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"VAMP" ; set printer name
M669 K1 ; select CoreXY mode; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M569 P5 S1 T2.5:2.5:5:5 ; physical drive 5 goes forwards
M569 P6 S1 T2.5:2.5:5:5 ; physical drive 6 goes forwards
M569 P7 S0 T2.5:2.5:5:5 ; physical drive 7 goes backwards
M569 P8 S0 T2.5:2.5:5:5 ; physical drive 8 goes backwards
M569 P9 S0 T2.5:2.5:5:5 ; physical drive 9 goes backwards
M584 X5 Y6 Z7:8:9 E3 ; set drive mapping
M92 X80.5234 Y79.6020 Z800.00 E95.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
M906 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X415 Y415 Z440 S0 ; set axis maxima; Endstops
M574 X1 Y2 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H6 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700
M305 P1 T4700000 B5140 R4700 ; set thermistor + ADC parameters for heater 1
M143 H0 S180 ; set temperature limit for heater 0 to 100C
M143 H1 S490 ; set temperature limit for heater 1 to 490C; Fans
M501 -
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:40 GMT-0400 (Eastern Daylight Time)
G91 ; relative positioning
G1 H1 X-420 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 H1 X-420 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning -
; homey.g
; called to home the Y axis
G1 H1 Y420 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y420 F360 ; move slowly to Y axis endstop once more (second pass)
; homez.g
; called to home the Z axis
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
; homeall.g
; called to home all axes
G1 H1 X-420 Y420 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-420 ; home X axis
G1 H1 Y420 ; home Y axis
G1 X-5 Y-5 F6000 ; go back a few mm
G1 H1 Y420 ; then move slowly to Y axis endstop
G1 X10 Y75 F6000 ; go to first bed probe point and home Z
; Example Homing file for RepRapFirmware on delta printerM117 Use https://configurator.reprapfirmware.org/ to set up your printer config
;G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
;G1 S1 X320 Y320 Z320 F2500 ; move all carriages up 320mm, stopping at the endstops
;G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
;G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
;G1 Z-5 F2000 ; down a few mm so that we can centre the head
;G90 ; back to absolute positioning
;G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate -
; config-override.g file generated in response to M500 at 2021-03-31 14:08
; Heater model parameters
M307 H0 A72.0 C92.5 D2.7 S1.00 V24.1 B0
M307 H1 A654.0 C177.9 D11.3 S1.00 V24.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
@v-a-m-p-printing-snproj said in Connecting stepper motor encoders to closed loop drivers:
OK, it's good to hear you've got it running.
Let us know when you have a new hot-end and have some new results.
@alankilian Oh it was printing before I put the closed loop drivers on. I got it to home the x and y fine separately, but when I home all itll home x and y and shoot off to the corner and trys to keep moving without homing the z.
Is it possible my cordinates got all screwed up? Should i reset all my homing?
