    (Solved) Probe reach area
    1.6k
    • rjenkinsgbundefined
      rjenkinsgb @RajaaKahel
      @rajaakahel
      Try
      M557 X30:420 Y36:360 S30 ; define mesh grid
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      • CCS86undefined
        CCS86
        Your probe cannot reach any point less than X26.8 or Y23.3, but you are commanding that it probe at X0 and Y12
          Are you sure your probe offsets are correct?
          Remember, -X should move left, +X should move right
          -Y should move to the nozzle to the front of the bed, +Y to the back.
          RajaaKahelundefined 1 Reply Last reply Reply Quote 0
          • RajaaKahelundefined
            RajaaKahel @Phaedrux
            @phaedrux said in Probe reach area:
            Yes they're correct, but I'm not sure if the X and Y offsets should be positive or negative.
            In my case, when I'm in front of the printer, X mini endstop is on my right, and the probe is on the other side of the nozzle (my left).
            And Y mini endstop is in the back right corner, +Y moves forward towards me.
            I don't really understand where my problem is.
            Here are some pictures, notice the I checked the box to flip plate on X on Simplify3D to match the printer setup.
            • fcwiltundefined
              fcwilt @RajaaKahel
              @rajaakahel
              With the extruder nozzle as your reference if the probe is closer to X min then the offset is negative, if closer to X max the offset is positive.
              You currently have the X offset as 26.8 which means to move the probe to X = 0 you have to be able to move the extruder nozzle to X = minus 26.8 which cannot be done as X min = 0.
              You currently have the Y offset as 23.3 which means to move the probe to Y = 12 you have to be able to move the extruder nozzle to Y = minus 11.3 which cannot be done as Y min = 0.
                RajaaKahel @fcwilt
                @fcwilt I understand that it should skip towards mini, but why it's skipping towards max?
                My probe is located towards max in both X and Y.
                • fcwiltundefined
                  fcwilt @RajaaKahel
                  @rajaakahel said in Probe reach area:
                  It's skipping points where X = 0 or points where Y = 12.
                  As I mentioned in my post you cannot reach those points when X min and Y min are set to zero.
                  But let's double check - your probe is behind and to the right of the extruder nozzle?
                    RajaaKahel @fcwilt
                      RajaaKahel
                      Here's where the it stops (near Y max) but there are like 5-6cm extra on Y.
                      • fcwiltundefined
                        fcwilt @RajaaKahel
                        @rajaakahel
                        It seems your movements may be wrong.
                        Facing the printer:
                        • moves toward X min should be to the left
                        • moves toward X max should be to the right
                        • moves toward Y min should be to the front
                        • moves toward Y max should be to the back
                        Is that true of your printer?
                          RajaaKahel @fcwilt
                          @fcwilt The picture I attached shows the movements of my printer. I don't really understand the point of right and left. The firmware should determine the directions based on X min and Y min. The probe is towards X max and Y max. It shouldn't matter right or left as long as the offset is in correct value ( + or -).
                          In my case X max is on the left in the picture.
                          Y max is on the front in the picture.
                          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @RajaaKahel
                            Regards the probe:
                            If the probe is towards X max and Y max then the offsets are positive which is what you have.
                            And the reason it cannot probe at X = 0 or Y = 12 is as I stated.
                            Regards X and Y movement:
                            The standard for movement is as I stated. You are free to ignore the standard as you have. But when conversing with others it may lead to confusion.
                              RajaaKahel @fcwilt
                              @fcwilt Thanks for the input, but again my problem is why it's not reaching the end towards Y max.
                              • fcwiltundefined
                                fcwilt @RajaaKahel
                                Why do you think that is the case?
                                Every error I see listed is at X=0 or Y=12?
                                Where is the error you are speaking of?
                                  Phaedrux Moderator @RajaaKahel
                                  No, this is not correct and is the source of your problem.
                                  This is a fact of the cartesian coordinate system used by the printer, and the CAD and slicer software we use with it. This is important in order to have printed parts that match the source model and not be reversed.
                                  See these image examples of a right hand coordinate system.
                                  Bed Area.png left_right_hand.gif dbot axis.png Cartesian-coordinate-system.png
                                  If the X endstop is on the right side, the printer must move to the right in the positive direction in the homing files. The endstop must be configured as M574 X2 to be on the high end of travel. If the probe is on the left of the nozzle it's offset is negative.
                                  If the Y endstop is at the back, it is on the high end and must be M574 Y2. Y+ moves should move to the back. Homing moves must be in the positive direction.
                                  Before you can determine the probe offset you need to get your coordinate system in order.
                                  For me to provide further guidance please post your config.g and homing files.
                                  RajaaKahelundefined 1 Reply Last reply Reply Quote 1
                                    @phaedrux
                                    Thanks for the input, I'll modify the firmware so that it uses my endstops as max instead of min. And will change the X&Y offsets to negative. Then I'll test the probing reach.
                                    However I never got a reversed printed part with my current setup (I printed my owen designs and STLs from the internet).
                                    All texts and images are printed correctly.
                                    I'll get back with my configurations and homing files.
                                      This is likely because both axis are flipped, which has the effect of rotating the coordinate system 180 degrees.
                                        @phaedrux
                                        Thank you again! now it's doing better after changing the direction of the coordinate to as you mentioned.
                                        Strange that I have never seen a topic explaining the importance of this issue.
                                          Well it is mentioned in various places
                                          https://docs.duet3d.com/en/User_manual/Tuning/Bed_origin
                                          https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_coreXY
                                            @phaedrux Thanks for the link. Never seen this documentation website before.
