    FAN 0 & FAN 1 allways ON
    1.4k
    • CozyPundefined
      CozyP
      FAN 0 and FAN 1, which are the extruder cooler and case cooler fans, are allways on. No matter how I change the gcode, they allways are engaged. Kinda annoying.
      Can someone take a look???
      generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Feb 21 2022 20:39:43 GMT+0200 (Eastern European Standard Time)
      M550 P"Print Machine" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
      M84 S30 ; Set idle timeout
      M208 X245 Y245 Z240 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-47 Y-15 Z3.35 ; set Z probe trigger value, offset and trigger height
      M106 P1 S1 H1 T50 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S0 H102 T45 ; set fan 1 value. Thermostatic control is turned on
      G10 P0 X40 Y30 Z0 ; set tool 0 axis offsets
      m501
      Gixxerfastundefined 1 Reply Last reply Reply Quote 0
      • Gixxerfastundefined
        Gixxerfast @CozyP
        @cozyp said in FAN 0 & FAN 1 allways ON:
        May I ask what you're doing here (above)?
        Fan 0 is usually/often the part cooling fan which should be controlled by the slicer Gcode and as set in the tool def M563
        Maybe you should define it something like this? :
        M950 F0 C"fan0"                              ; create fan 0 on pin 121.out1 and set its frequency
        M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
        The second part/fan is monitoring heater 102 (if I read this correctly) Which heater do you want to monitor? I guess H1 is what you want.
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        CozyPundefined 2 Replies Last reply Reply Quote 1
        • CozyPundefined
          CozyP @Gixxerfast
          @gixxerfast
          Nothing changed.
          I have 3 fans, one PWM for printing cooling and two other fans, one for moterboard cooling and the other for extruder cooling.
          Both extruder cooling and motherboard fan cannot be turned off or thermostatically controlled.
          I miss something....
          • CozyPundefined
            CozyP @Gixxerfast
            @gixxerfast
            M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S0 H100 T45
            G10 P0 X-15 Y-15 Z0 ; set tool 0 axis offsets
            G10 P0 R0 S0 ;
              Gixxerfast @CozyP
              @cozyp Can you run m98 P"/sys/config.g" and post whatever shows in the console?
              As far as I can see right now, the last M106 is still referencing a heater that prpbably doesn't exists. H100 ?
              So just to make it clear:
              • Fan 0 is part cooling fan, which is controlled by slicer GCode commands
              • Fan 1 is the extruder fan which is controlled by the temp of heater 1 and should turn on whenever thet temp is over 45
              • Fan 2 is the controller fan which is controlled by sensor MCU temp that you have probably defined that somewhere?
              Here's mine:
              ; Define MCU sensors which will be available in DWC Extra View
              M308 S3 A"MCU" Y"mcu-temp" 				; Officially NOT supported on Mini 3 5+ however seem to work
              M308 S4 A"Duet Drivers" Y"drivers" 		; This is not really working as it is just a threshold crossing
              And I'm referring to those with:
              ; MCU fan
              M950 F2 C"!0.out4+0.out4.tach" Q25000              ; create fan 2 on pin out4 and set its frequency
              M106 P2 H3:4 L0.2 X1.0 T30:50 C"Controller fan 1"  ; controlled by Sensor 3&4 - MCU& Drivers
              • fcwiltundefined
                fcwilt @Gixxerfast
                @gixxerfast said in FAN 0 & FAN 1 allways ON:
                H100 refers to the "virtual heater" and is used to monitor the processor chip temperature. That could be used for the fan cooling the board.
                  Gixxerfast @fcwilt
                  @fcwilt Edit: No it isn't Is H100 predefined as MCU temp?
                  • fcwiltundefined
                    fcwilt @Gixxerfast
                    From the documentation:
                    The fourth example sets up an electronics cooling fan that starts to turn on when the MCU temperature (virtual heater 100) reaches 45C and reaches full speed when the MCU temperature reaches 65C or if any TMC2660 drivers (virtual heaters 101 and 102) report that they are over-temperature
                    I can only assume the documentation is correct.
                    Gixxerfastundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      Gixxerfast @fcwilt
                      @fcwilt Yes, that sound reasonable which made me try it as I set it up explicitly.
                      I changed my config to:
                      M106 P2 H100 L0.2 X1.0 T30:50 C"Controller fan 1"
                      When I run that config I get:
                      Error: Sensor number out of range
                      Also, when I look in the code I see nothing that suggests that there exists predefined sensor numbers
                      The sensor number list that s set via the H flag is checked with this:
                      if (hnum < (int)MaxSensors)
                      						sensorsMonitored.SetBit((unsigned int)hnum);
                      					else
                      						reply.copy("Sensor number out of range");
                      						error = true;
                      And as far as I can see the MaxSensors is between 32 or 56 depending on board. I am very likely reading something wrong here as it's not very quickly easy to see what MaxSensors is defined to in this case.
                        Phaedrux Moderator @fcwilt
                        @fcwilt said in FAN 0 & FAN 1 allways ON:
                        Yes it is correct in RRF2. And in RRF3 you can target the virtual heaters by name now. mcu-temp
                        Is that text from the cooling the board page?
                        Yes. And it does show both RRF2 and RRF3 options.
                        https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Notes
                        Gixxerfastundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                          Gixxerfast @Phaedrux
                          @phaedrux It's from here as far as I can see: https://duet3d.dozuki.com/Wiki/M106
                          But can you really refer to it via number >=100 in the H parameter ?
                          I see nothing that implies that.
                          OK, so with RRF V3 you cannot use +100 to refer to the MCU or other sensor (virtual heater) as I initally wrote far above here somewhere.
                          • fcwiltundefined
                            fcwilt @Phaedrux
                            @phaedrux said in FAN 0 & FAN 1 allways ON:
                            It was from the M106 documentation page:
                            M106
                            It mentions v3 firmware and references M308 which is where there are references to virtual heater names.
                            The H parameter relates to the sensor number(s) created by M308, not the temperature sensor pin number on the board.
                            Perhaps that could be expanded a little to provide a bit more info as to the connection between M308 and virtual heaters, etc.
                              Maybe just a link to this?
                              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp
                              In RRF2 the virtual heater number would go directly into the M106 command. But in RRF3 it's a bit more abstracted with M308 creating the sensor first. The entire example is almost out of scope for the normal usage of M106, especially in RRF3.
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                That looks fine.
                                It took me to a site that I was not aware of. Is that the current site for documentation?
                                Is the "Gcode dictionary" site obsolete?
                                  It's back like it was before!
                                  https://docs.duet3d.com/en/User_manual/Reference/Gcodes
                                  The new documentation site went is live now.
                                  The old dozuki site will be archived and retired at some point I believe.
                                  • fcwiltundefined
                                    fcwilt @Phaedrux
                                    I didn't even know it was planned.
                                      droftarts administrators @fcwilt
                                      @fcwilt it hasn’t been announced formally as we’re still tinkering with it, and there’s still a few pages to add, but it’s live and what we are generally using now. We’ll be formally announcing it and posting messages on the Dozuki pages to redirect people to the new site in the next couple of days. It’s taken quite a few months to migrate and update it! That’s why I haven't been around on the forum as much.
                                      fcwiltundefined 1 Reply Last reply Reply Quote 2
                                      • fcwiltundefined
                                        fcwilt @droftarts
                                        @droftarts said in FAN 0 & FAN 1 allways ON:
                                        @fcwilt it hasn’t been announced formally as we’re still tinkering with it, and there’s still a few pages to add, but it’s live and what we are generally using now. We’ll be formally announcing it and posting messages on the Dozuki pages to redirect people to the new site in the next couple of days. It’s taken quite a few months to migrate and update it! That’s why I have been around on the forum as much.
                                        At first glance it looks grand.
                                        Thanks much for your efforts.
                                        CozyPundefined 1 Reply Last reply Reply Quote 0
                                        • CozyPundefined
                                          CozyP @fcwilt
                                          @fcwilt
                                          hELLO
                                          I updated fan 2.
                                          However I haven't managed to make fan 1, which is the extruder cooler fan stop and turn on when the heater turns on.
                                          M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor
                                          M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor
                                          M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
                                          M106 P2 H10:11 T40:70 ; set fan 2 value
                                          • fcwiltundefined
                                            fcwilt @CozyP
                                            @cozyp
                                            If configure that fan to non-thermostatic control can you then set it's speed using it's DWC fan speed slider?
