    FAN 0 & FAN 1 allways ON
    1.4k
    • Gixxerfastundefined
      Gixxerfast @Phaedrux
      @phaedrux It's from here as far as I can see: https://duet3d.dozuki.com/Wiki/M106
      But can you really refer to it via number >=100 in the H parameter ?
      I see nothing that implies that.
      OK, so with RRF V3 you cannot use +100 to refer to the MCU or other sensor (virtual heater) as I initally wrote far above here somewhere.
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      • fcwiltundefined
        fcwilt @Phaedrux
        @phaedrux said in FAN 0 & FAN 1 allways ON:
        Is that text from the cooling the board page?
        It was from the M106 documentation page:
        M106
        It mentions v3 firmware and references M308 which is where there are references to virtual heater names.
        The H parameter relates to the sensor number(s) created by M308, not the temperature sensor pin number on the board.
        Perhaps that could be expanded a little to provide a bit more info as to the connection between M308 and virtual heaters, etc.
          Maybe just a link to this?
          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp
          In RRF2 the virtual heater number would go directly into the M106 command. But in RRF3 it's a bit more abstracted with M308 creating the sensor first. The entire example is almost out of scope for the normal usage of M106, especially in RRF3.
          • fcwiltundefined
            fcwilt @Phaedrux
            That looks fine.
            It took me to a site that I was not aware of. Is that the current site for documentation?
            Is the "Gcode dictionary" site obsolete?
              Phaedrux Moderator @fcwilt
              @fcwilt said in FAN 0 & FAN 1 allways ON:
              It's back like it was before!
              https://docs.duet3d.com/en/User_manual/Reference/Gcodes
              The new documentation site went is live now.
              The old dozuki site will be archived and retired at some point I believe.
              • fcwiltundefined
                fcwilt @Phaedrux
                I didn't even know it was planned.
                  droftarts administrators @fcwilt
                  @fcwilt it hasn’t been announced formally as we’re still tinkering with it, and there’s still a few pages to add, but it’s live and what we are generally using now. We’ll be formally announcing it and posting messages on the Dozuki pages to redirect people to the new site in the next couple of days. It’s taken quite a few months to migrate and update it! That’s why I haven't been around on the forum as much.
                  fcwiltundefined 1 Reply Last reply Reply Quote 2
                  • fcwiltundefined
                    fcwilt @droftarts
                    @droftarts said in FAN 0 & FAN 1 allways ON:
                    @fcwilt it hasn’t been announced formally as we’re still tinkering with it, and there’s still a few pages to add, but it’s live and what we are generally using now. We’ll be formally announcing it and posting messages on the Dozuki pages to redirect people to the new site in the next couple of days. It’s taken quite a few months to migrate and update it! That’s why I have been around on the forum as much.
                    At first glance it looks grand.
                    Thanks much for your efforts.
                    CozyPundefined 1 Reply Last reply Reply Quote 0
                    • CozyPundefined
                      CozyP @fcwilt
                      @fcwilt
                      hELLO
                      I updated fan 2.
                      However I haven't managed to make fan 1, which is the extruder cooler fan stop and turn on when the heater turns on.
                      M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor
                      M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor
                      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                      M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 H10:11 T40:70 ; set fan 2 value
                      • fcwiltundefined
                        fcwilt @CozyP
                        @cozyp
                        If configure that fan to non-thermostatic control can you then set it's speed using it's DWC fan speed slider?
                          Or send M106 P1 S1 H-1 That should turn it on full blast.
                          • CozyPundefined
                            CozyP @fcwilt
                            @fcwilt I have connected this fan in the non PWM fan output
                            • CozyPundefined
                              CozyP @Phaedrux
                              @phaedrux That's the problem. The extruder fan, NOT the part cooling fan is running full blast. Allways. Usually these fans turn on after T45celcius automatically
                                Sorry, can you clarify which fan is connected where?
                                What happens when you send M106 P1 S1 H-1 ?
                                • fcwiltundefined
                                  fcwilt @CozyP
                                  @cozyp said in FAN 0 & FAN 1 allways ON:
                                  Sorry but I don't understand what you mean by that.
                                  I was wanting you to verify that whatever output you were using was still working.
                                  • CozyPundefined
                                    CozyP @Phaedrux
                                    @phaedrux @fcwilt
                                    Ok. First things first.
                                    Phaedrux, I sent M106 on config file. Nothing changed. Fan stays ON no matter what. FAN 1 was added as option on DWC screen, but it cannot be controlled, which is correct, as the fan is connected in a non PWM output.
                                    dcwilt, the extruder heater fan and the motherboard fan are connected in a NON PWM output, but they allways stay ON, full blast no matter what....
                                    I wanted to turn them on via thermostat, as they should work. Am I missing something???
                                    M106 M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned on
                                    CozyPundefined Phaedruxundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                                    • CozyPundefined
                                      CozyP @CozyP
                                      M106 M106 P1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                                      G10 P0 X-15 Y-15 Z0 ; set tool 0 axis offsets
                                        Phaedrux Moderator @CozyP
                                        Yes, M106 P1 S1 H-1 will disable thermostatic control and turn the fan on. Send M106 P1 S0 to turn it off again.
                                        Fan1 port is indeed PWM controllable.
                                        Fan0, Fan1, Fan2 are controllable. Plus two more always on fan ports.
                                        Which are you actually plugged into?
                                        Fan0 1 2 can be used as thermostatically controlled or by the slicer to set speed for part cooling.
                                        The always on ports are... always on.
                                        If you send M106 P1 S0 and the fan won't turn off, then either it's plugged into a different port than you are expecting, or the fan mosfet has been damaged and failed in the on position.
                                        • fcwiltundefined
                                          fcwilt @CozyP
                                          It sounds like you are referring to the "always on" fan outputs - they are not controllable.
                                          • CozyPundefined
                                            CozyP
                                            I have plugged those two fans on the allways ON ports.
                                            So, after reading your comments, I assume that they cannot be thermostatically controlled???
