    Easier way to test if homed?
    Gcode meta commands
    8
    29
    1.6k
    • OwenDundefined
      OwenD @theolodian
      @theolodian said in Easier way to test if homed?:
      @dc42 said in Easier way to test if homed?:
      @owend the M584 command allows you to make the first P axes visible and hide all higher numbered axes.
      The inference being that if you have hidden axes then you probably don't care to home them, say extruders, etc.? Thanks.
      Well not extruders, but you may have defined axes to allow you to perform certain tasks at startup which are then hidden during normal running.
      My question was just whether those hidden axes numbers could fall in the middle of a range.
      Since it doesn't appear that this is possible, it is safe to cease testing axes for their homed state once a hidden axes is found in the array.
      • theolodianundefined
        theolodian @OwenD
        @owend Ugh, different problem. Homing always comes back as failed when using these lower case letters for axes. 🙄
        It does work fine if everything is already homed.
        ; If the bed hasn't been homed, home it
        ; Iterative loop across all defined move axes
        while iterations < #move.axes
        	if !move.axes[iterations].homed
        			G28
        			if result != 0
        				abort "Homing failed"
        			break
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @theolodian
          @theolodian
          I don't know why the axis letters would matter.
          Are any axes hidden?
          May be a question for @dc42
          theolodianundefined 1 Reply Last reply Reply Quote 0
            theolodian @OwenD
            @owend It has never worked correctly, there are still a variety of issues with using lower case letters for axes. Thanks.
              If you don't tell us what these issues are, we can't fix them.
              • zaptaundefined
                zapta @theolodian
                @theolodian, are you referring to the various scripts here that test for homing? The all seem to use axis indexes rather than axis letters.
                  theolodian @zapta
                  @zapta said in Easier way to test if homed?:
                  No, I am using lower case axis letters and homing always returns errors even though it works.
                    theolodian @dc42
                    @dc42 Are lower case axis letters supposed to work in SBC mode now? Should I try it again? We have just been using standalone mode.
                    • chrishammundefined
                      chrishamm administrators @theolodian
                      @theolodian Lowercase letters are supported in the latest RC.
                      Duet software engineer
                        theolodian @chrishamm
                        @chrishamm I was going to say no, but I rebooted everything one more time to be sure - and yes RC2 seems to work in SBC mode! 😮 👍
                        • JoergS5undefined JoergS5 referenced this topic
