Easier way to test if homed?
Gcode meta commands
8
29
1.6k
    dc42 administrators @OwenD
    @owend the M584 command allows you to make the first P axes visible and hide all higher numbered axes.
    undefined 1 Reply Last reply 21 Feb 2022, 10:00 Reply Quote 0
      theolodian @dc42
      @dc42 said in Easier way to test if homed?:
      The inference being that if you have hidden axes then you probably don't care to home them, say extruders, etc.? Thanks.
      undefined undefined 2 Replies Last reply 21 Feb 2022, 16:02 Reply Quote 0
        zapta @theolodian
        @theolodian said in Easier way to test if homed?:
        When I open the object model in DWC, it shows in the move section only x,y,z. Is E is also there in the move section of the object model but is hidden by DWC?
        undefined 1 Reply Last reply 21 Feb 2022, 16:23 Reply Quote 0
          dc42 administrators @zapta
          @zapta the axes are described in move.axes and the extruders in move.extruders.
            OwenD @theolodian
            Well not extruders, but you may have defined axes to allow you to perform certain tasks at startup which are then hidden during normal running.
            My question was just whether those hidden axes numbers could fall in the middle of a range.
            Since it doesn't appear that this is possible, it is safe to cease testing axes for their homed state once a hidden axes is found in the array.
              theolodian @OwenD
              @owend Ugh, different problem. Homing always comes back as failed when using these lower case letters for axes. 🙄
              It does work fine if everything is already homed.
              ; If the bed hasn't been homed, home it
              ; Iterative loop across all defined move axes
              while iterations < #move.axes
              if !move.axes[iterations].homed
              G28
              if result != 0
              abort "Homing failed"
              break
              undefined 1 Reply Last reply 23 Feb 2022, 19:05 Reply Quote 0
                OwenD @theolodian
                @theolodian
                I don't know why the axis letters would matter.
                Are any axes hidden?
                May be a question for @dc42
                undefined 1 Reply Last reply 24 Feb 2022, 06:53 Reply Quote 0
                  theolodian @OwenD
                  @owend It has never worked correctly, there are still a variety of issues with using lower case letters for axes. Thanks.
                  undefined 1 Reply Last reply 24 Feb 2022, 08:18 Reply Quote 0
                    If you don't tell us what these issues are, we can't fix them.
                    undefined 1 Reply Last reply 24 Feb 2022, 10:24 Reply Quote 0
                      zapta @theolodian
                      @theolodian, are you referring to the various scripts here that test for homing? The all seem to use axis indexes rather than axis letters.
                      undefined 1 Reply Last reply 24 Feb 2022, 08:56 Reply Quote 0
                        theolodian @zapta
                        @zapta said in Easier way to test if homed?:
                        No, I am using lower case axis letters and homing always returns errors even though it works.
                          theolodian @dc42
                          @dc42 Are lower case axis letters supposed to work in SBC mode now? Should I try it again? We have just been using standalone mode.
                          undefined 1 Reply Last reply 24 Feb 2022, 10:49 Reply Quote 0
                            chrishamm administrators @theolodian
                            @theolodian Lowercase letters are supported in the latest RC.
                            Duet software engineer
                            undefined 1 Reply Last reply 24 Feb 2022, 20:44 Reply Quote 0
                              theolodian @chrishamm
                              @chrishamm I was going to say no, but I rebooted everything one more time to be sure - and yes RC2 seems to work in SBC mode! 😮 👍
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 05:53
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:01
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:03
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:04
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:10
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:14
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:28
                              • undefined JoergS5 referenced this topic 23 Jun 2022, 06:29
                              25 out of 29
