duet 2 wifi heaters e0 + e1
@engikeneer The problem is that I have the heaters at 24 volts and not at 12 because I thought it was possible to use them at 24 volts through a jumper.
@paolozampini1973 so you have a 12V PSU?
@engikeneer 24v
@paolozampini1973 so you have a 24v power supply and 24V heaters? That should be fine
@engikeneer basically i want to use 24 volt 70 watt heaters clearly with a power supply of 24 volts
@örjane Thanks but that wasn't the configuration question it was about wiring to 24 times the heaters
@paolozampini1973 that should work no problem the heater channels output at the same level as the supply voltage
@engikeneer my duet wifi working 24v out heaters E0 + E1 MY TESTER OUT READER 12V heaters E0 + E1 12V POSSIBLE CONVESION VOLTAGE heaters E0 + E1 24V ?
@paolozampini1973 said in duet 2 wifi heaters e0 + e1:
Can you rephrase this? I have no idea what you're trying to ask.
There is a jumper on the Duex to use 12v FANS even when the PSU is 24v. NOT heaters though.
https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#power-jumpers
@phaedrux so the heaters can work only and only at 12 volts there is no way to make them work at 24 volts
No that is not what I am saying.
If your power supply is 24v, your heaters will get 24v as well. No matter what.
For FANS on the Duex you have the OPTION for 12v or 24v with a selection jumper.
@phaedrux however, measuring 12 volts with the tester but the power supply is 24 volts
Where are you measuring 12v?
@phaedrux at the exit of the heaters E0 E1
Are you sure the power supply is 24v?
What do you measure at the output of the power supply?
@phaedrux YES 100%
@paolozampini1973 the output is PWM controlled, so may be that that you are measuring.
The outputs are switches on the -ve side, so measure between the +ve heater terminal and the -ve supply terminal -
@engikeneer I made the measurement with the tester and I have 25 times Only problem is that it gives me this kind of error I would like to configure the heaters correctly if you can help me Thanks
@paolozampini1973 you need to tune your heaters so it can control them better:
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning
