    Duet2Wifi Using 3 Heaters for a extruder
    589
    • mikep91undefined
      mikep91
      Hello there.
      We recently got a hot-end with 3 heaters. Dyze Pulsar to be specific. Before we used a marlin board with 3 pinouts for the temperature sensors.
      Now we upgraded to a Duet2Wifi with PT100 Daughterboards attached.
      I connected the sensors to the PT100 daughtersboards but how would I go about connecting the heaters? They're connected through solid state relays to switch them on & off.
      Should i use the small expansion pin (8, heater 3) or is it possible to use the Bed Heater as the 3rd one since we haven't got a heated bed?
      M140 H-1 ; disable heated bed
      M305 P1 X200 ; configure PT100 for heater 1
      M143 H1 S500 ; set temperature limit for heater 1 to 500C
      M305 P2 X201 ; configure PT100 for heater 2
      M143 H2 S500 ; set temperature limit for heater 2 to 500C
      M305 P3 X202 ; configure PT100 for heater 3
      M143 H3 S500 ; set temperature limit for heater 3 to 500C
      M570 H1 P30 T100 ; 100C overshoot for 30 sec permitted heater 1
      M570 H2 P30 T100 ; 100C overshoot for 30 sec permitted heater 2
      M570 H3 P30 T100 ; 100C overshoot for 30 sec permitted heater 3
      M563 P0 H1 F0 ; define tool 0
      M563 P1 H2 F0 ; define tool 1
      M563 P2 H3 F0 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      I understand that i could connect these in series but we would like to be able to control different temperatures in different areas of the hot-end. Therefor we would prefer to have them connected seperately from eachother.
      All help appreciated!
        dc42 administrators @mikep91
        @mikep91 you can use M563 to define a single tool that uses 3 heaters. You will need to use M568 or G10 (not M104 or M109) to set the temperatures if you want them to be different.
        • mikep91undefined
          mikep91
          Not that familiar with g-code unfortunately. How would that look?
          We set the temperature on the Duet Paneldue and not using G/M-codes
          How would I go about wiring the 3rd heater to the Duet2Wifi board?
          Only have two pinouts for E0 and E1, do I have to use the small pins on the expansion board? I think it's Pin8 thats stated as Heater3
          Thanks!
          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @mikep91
            @mikep91 said in Duet2Wifi Using 3 Heaters for a extruder:
            Yes.
            https://docs.duet3d.com/duet_boards/duet_2_wifi_ethernet_maestro/duet2ndgen_connections_v1.0-1.5_d2.1.png
            mikep91undefined 1 Reply Last reply Reply Quote 0
            • mikep91undefined
              mikep91 @Phaedrux
              @phaedrux
              So i hook up my the one connector to 5v (Pin1)
              And the 2nd to HEATER3 (Pin8)?
              Thanks!
              kr15_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                Yes, and then use a mosfet or SSR to control the heater from that pin, because those pins can only provide a small amount of current and only at 3.3V. DO NOT connect a heater directly to expansion pin 8.
                • kr15_ukundefined
                  kr15_uk @mikep91
                  @mikep91 I’d personally suggest to go with Duex5 expansion board in your case.
                  mikep91undefined 1 Reply Last reply Reply Quote 1
                    deckingman @mikep91
                    @mikep91 In another thread, a user with. Dyze hot end had great difficulty in tuning the PID parameters for the individual heaters because of the thermal transfer interaction between heaters. That is to say, there were no thermal breaks between the heat zones so effectively it had a single heat zone. The only way to tune the PID parameters was to wire the heaters in parallel to single heater output and use a single sensor. I.e treat it a single heater with a single sensor (they all read the same temperature within a degree in any case).
                    • mikep91undefined
                      mikep91 @kr15_uk
                      @kr15_uk
                      I suppose I would need to configure new software? or does Duex and DUET2Wifi run the same?
                      Just checked out the board and it looks like what I need indeed
                      kr15_ukundefined 1 Reply Last reply Reply Quote 0
                      • mikep91undefined
                        mikep91 @dc42
                        @dc42 said in Duet2Wifi Using 3 Heaters for a extruder:
                        Thanks for the help so far.
                        I've connected my two wires to Pin8 and Ground
                        They're all 3 connected to solid state relays
                        It seems 3rd heater is faulty somehow. When i set the temperature to 200 on all heaters, the 3rd one just keeps heating.
                        OBS; Without im activating the heater on on the Duet Touch Panel,
                        Could it be that i switched some wiring, or do I have to look in the config perhaps?
                        • kr15_ukundefined
                          kr15_uk @mikep91
                          @mikep91 If you are using web config toot (https://configtool.reprapfirmware.org) then under I/O Mapping tab there are two buttons "Add Duex2" and "Add Duex5" which then adds expansion ports as an option to chose from the drop down menus.
                          • mikep91undefined
                            mikep91 @kr15_uk
                            @kr15_uk
                            I am not creating a new software unfortunately im using the Config. file on my current board
                            • kr15_ukundefined
                              kr15_uk @mikep91
                              @mikep91 You can load existing profile and amend it there.
                              • mikep91undefined
                                mikep91 @kr15_uk
                                @kr15_uk
                                Ah nice. I'll take a look at it.
                                I don't have an IDEX Board though and if possible i would just like to connect it using the Duet2Wifi.
                                It seems im lacking something to make it work properly though, maybe a 3rd heater config in my code...
                                • kr15_ukundefined
                                  kr15_uk @mikep91
                                  @mikep91 if you suspect external circuitry to be at fault here you could simply uncomment bed and use bed mosfet to drive 3rd heater
                                  • mikep91undefined
                                    mikep91 @kr15_uk
                                    @kr15_uk
                                    Nice thats actually what i did for a start.
                                    I figured out how to use the expansion pins though and it works like a charm!
                                    Thanks for the help and support!
                                    Will def go for a IDEX board next time we're upgrading
