Solved Motors doesn't work on drives from Duex 5
@fcwilt
24,2V if I remember correctly, same as at the Duet and PSU.Edit
24,19V -
@eken said in Motors doesn't work on drives from Duex 5:
@fcwilt
24,19VAll I can suggest at this point is to disconnect everything but power and the ribbon cable then run M122.
Of course turn off power first.
And there is no need to perform a reset?
Necessary positioning of jumper?
No nothing to get the drive outputs active more than assigning them in config?Noticed that if I disconnect all stepper motors the end6 LED turns off.
If I connect a motor on any of the drive outputs the end6 LED turns on. -
@fcwilt
Ok, tried that as well. -
@fcwilt
Ok, tried that as well.With nothing still connected run M98 P"config.g" and see if any errors are reported.
@fcwilt
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Heater 7 not found -
@fcwilt
M98 P"config.g"
FTP is disabled
TELNET is disabled
Error: Heater 7 not foundI'm running out of ideas. Please post your complete config.g file using the </> tag.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 12 2021 00:28:54 GMT+0100 (centraleuropeisk normaltid) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"ME4080" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M569 P4 S0 ; physical drive 4 goes backwards M569 P5 S1 ; physical drive 7 goes forwards M569 P6 S1 ; physical drive 8 goes forwards M569 P9 S1 ; physical drive 9 goes forwards M584 X0 Y1 Z2:5:6 E3 ; set drive mapping M350 Z16 I0 ; configure microstepping without interpolation M350 X16 Y16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z400.00 E402.00 ; set steps per mm M566 X900.00 Y900.00 Z90.00 E3000.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z720.00 E12000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z400.00 E4000.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X270 Y270 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; Define Z to use Probe. Home to Min ; Z-Probe M558 P9 C"^zprobe.in" H10 F120 T6000 X0 Y0 Z1 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves M557 X10:200 Y10:200 S50 ; define mesh grid G31 X60 Y60 Z3.0 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment M950 S13 C"duex.pwm5" ; Which pin BLTouch is connected to ; Heaters M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board. M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 R0.724 C166.5 D3.47 S1.00 V24.2 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 100C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
Don't understand what you meen with </> tag?
Well you must have used it since the file is display correctly.
Clicking on the </> icon enters three lines of characters used for pasting code into a post. I've reached the point where I just type in the needed characters (two sets of 3 ` characters).
@fcwilt
Ok, thanks a lot for your time and effort!
The board is mounted on brass extenders for PC motherboards, extra tall so there should be enough clearance.
Hmm maybe I can find another ribbon cable just for trying something…I’ve never used the </> button, only knew about the ‘’’
Did you check to be sure there was no continuity from power in (positive or negative) to the metal plate?
@fcwilt
Yes, nothing there.
0V
0.L ohm
Have measured at multiple locations (+/- on Duet, Duex and PSU) -
Does the ribbon cable have continuity on all it's pins?
@phaedrux
Yes it has.
So I didn’t bother looking for another cable to try with. -
@phaedrux
This is a "new" Duex, ordered it 13 months ago and installed it this week.When and where was the Duex purchased?
@phaedrux
End of 11/2 2021, RepRapPro.me -
It would be out of warranty, but seeing as it hasn't been used until now, and the issue seems to be that the Duex is not being detected at all, I think we should cover it under warranty.
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux
Thanks for the reply!
I’ve sent an email now. -
@phaedrux
Recieved my new Duex yesterday and work out just great now!
Now I'm off to get use of some 3-point-independent-z-motor-super-mega-heavy-duty-auto-bed-levelingThanks for your help and thanks to Duet-team and reprappro.me for the quick handling of the warranty case!
