    Motors doesn't work on drives from Duex 5
    898
    • fcwiltundefined
      fcwilt @Eken
      @eken
      Well the Duex5 should be listed.
      So either something is wrong with the ribbon cable connection or the power connection.
      Can you post a picture of them?
      Ekenundefined 1 Reply Last reply Reply Quote 0
        Is this a new or existing Duex?
        • Ekenundefined
          Eken @fcwilt
          @fcwilt
          I'm not stupid, I'm just unlucky when I try figuring it out.
          • Ekenundefined
            Eken @Phaedrux
            @phaedrux
            This is a "new" Duex, ordered it 13 months ago and installed it this week.
            • Ekenundefined
              Eken
              Tried with other drives on duex and remapped in config.g but the same LEDs behaves as before. Also swapped polarity on the motors.
              It’s not that I completely missed some installation steps?
              Because all I’ve done is connected the Duex with ribbon cable and VIN +/-.
              I haven’t told the Duet there is a Duex in anyway if that’s necessary?
              • fcwiltundefined
                fcwilt @Eken
                @eken
                The Duex should be detected automaticially.
                Did you check the fuse on the Duex?
                • Ekenundefined
                  Eken @fcwilt
                  @fcwilt
                  Yea the fuse is solid.
                  So there aren’t a configuration step to let the Duet know I added a Duex?
                  That was one answer I was hoping for… 🤣
                  • fcwiltundefined
                    fcwilt @Eken
                    @eken said in Motors doesn't work on drives from Duex 5:
                    @fcwilt
                    Did you measure the voltage at the power input to the Duex board?
                    • Ekenundefined
                      Eken @fcwilt
                      @fcwilt
                      24,2V if I remember correctly, same as at the Duet and PSU.
                      Edit
                      24,19V
                      • fcwiltundefined
                        fcwilt @Eken
                        @fcwilt
                        Edit
                        24,19V
                        All I can suggest at this point is to disconnect everything but power and the ribbon cable then run M122.
                        Of course turn off power first.
                        • Ekenundefined
                          Eken
                          And there is no need to perform a reset?
                          Necessary positioning of jumper?
                          No nothing to get the drive outputs active more than assigning them in config?
                          Noticed that if I disconnect all stepper motors the end6 LED turns off.
                          If I connect a motor on any of the drive outputs the end6 LED turns on.
                          • Ekenundefined
                            Eken @fcwilt
                            @fcwilt
                            Ok, tried that as well.
                            • fcwiltundefined
                              fcwilt @Eken
                              @fcwilt
                              With nothing still connected run M98 P"config.g" and see if any errors are reported.
                              • Ekenundefined
                                Eken @fcwilt
                                @fcwilt
                                M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                Error: Heater 7 not found
                                • fcwiltundefined
                                  fcwilt @Eken
                                  @fcwilt
                                  M98 P"config.g"
                                  FTP is disabled
                                  TELNET is disabled
                                  I'm running out of ideas. Please post your complete config.g file using the </> tag.
                                  • Ekenundefined
                                    Eken @fcwilt
                                    @fcwilt
                                    ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 12 2021 00:28:54 GMT+0100 (centraleuropeisk normaltid)
                                    G90                                                	; send absolute coordinates...
                                    M83                                                	; ...but relative extruder moves
                                    M550 P"ME4080"                                     	; set printer name
                                    M669 K1                                                 ; select CoreXY mode
                                    M569 P0 S1                                         	; physical drive 0 goes forwards
                                    M569 P1 S1                                         	; physical drive 1 goes forwards
                                    M569 P2 S1                                         	; physical drive 2 goes forwards
                                    M569 P3 S0                                         	; physical drive 3 goes backwards
                                    M569 P4 S0                                         	; physical drive 4 goes backwards
                                    M569 P5 S1											; physical drive 7 goes forwards
                                    M569 P6 S1											; physical drive 8 goes forwards
                                    M569 P9 S1											; physical drive 9 goes forwards
                                    M584 X0 Y1 Z2:5:6 E3                                    ; set drive mapping
                                    M350 Z16 I0                                   		; configure microstepping without interpolation
                                    M350 X16 Y16 E16 I1                                	; configure microstepping with interpolation
                                    M92 X100.00 Y100.00 Z400.00 E402.00   			; set steps per mm
                                    M566 X900.00 Y900.00 Z90.00 E3000.00	   		; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z720.00 E12000.00     		; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z400.00 E4000.00        		; set accelerations (mm/s^2)
                                    M906 X1400 Y1400 Z1400 E800 I30               		; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30                                            	; Set idle timeout
                                    M208 X0 Y0 Z0 S1                                   	; set axis minima
                                    M208 X270 Y270 Z260 S0                             	; set axis maxima
                                    M574 X1 S1 P"xstop"                                	; configure active-high endstop for low end on X via pin xstop
                                    M574 Y1 S1 P"ystop"                                	; configure active-high endstop for low end on Y via pin ystop
                                    M574 Z1 S2 						; Define Z to use Probe. Home to Min
                                    M558 P9 C"^zprobe.in" H10 F120 T6000 X0 Y0 Z1       ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                                    M557 X10:200 Y10:200 S50                           	; define mesh grid
                                    G31 X60 Y60 Z3.0 P25				        ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                    M950 S13 C"duex.pwm5" 					; Which pin BLTouch is connected to
                                    M307 H7 A-1 C-1 D-1 					; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     	; configure sensor 0 as thermistor on pin bedtemp
                                    M950 H0 C"bedheat" T0                              	; create bed heater output on bedheat and map it to sensor 0
                                    M307 H0 B0 R0.724 C166.5 D3.47 S1.00 V24.2              ; disable bang-bang mode for the bed heater and set PWM limit
                                    M140 H0                                            	; map heated bed to heater 0
                                    M143 H0 S120                                       	; set temperature limit for heater 0 to 100C
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8      ; configure sensor 1 as thermistor on pin e0temp
                                    M950 H1 C"e0heat" T1                               	; create nozzle heater output on e0heat and map it to sensor 1
                                    M307 H1 B0 S1.00                                   	; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S280                                       	; set temperature limit for heater 1 to 280C
                                    M950 F0 C"fan0" Q500                               	; create fan 0 on pin fan0 and set its frequency
                                    M106 P0 S0 H-1                                     	; set fan 0 value. Thermostatic control is turned off
                                    M950 F1 C"fan1" Q500                               	; create fan 1 on pin fan1 and set its frequency
                                    M106 P1 S1 H1 T45                                  	; set fan 1 value. Thermostatic control is turned on
                                    M563 P0 D0 H1 F0                                   	; define tool 0
                                    G10 P0 X0 Y0 Z0                                    	; set tool 0 axis offsets
                                    G10 P0 R0 S0                                       	; set initial tool 0 active and standby temperatures to 0C
                                    M501                                               	; load saved parameters from non-volatile memory
                                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" 	; set voltage thresholds and actions to run on power loss
                                    T0                                                 	; select first tool
                                    Don't understand what you meen with </> tag?
                                    fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @Eken
                                      @eken
                                      Well you must have used it since the file is display correctly.
                                      Clicking on the </> icon enters three lines of characters used for pasting code into a post. I've reached the point where I just type in the needed characters (two sets of 3 ` characters).
                                      • fcwiltundefined
                                        fcwilt @Eken
                                        @eken
                                        I don't see anything odd in the file.
                                        It looks like the boards are mounted to a metal plate. If so, did you check for any shorts to the plate.
                                        If not at this point I think you need to get @dc42 involved - you may have a defective board or ribbon cable.
                                        • Ekenundefined
                                          Eken @fcwilt
                                          @fcwilt
                                          Ok, thanks a lot for your time and effort!
                                          The board is mounted on brass extenders for PC motherboards, extra tall so there should be enough clearance.
                                          Hmm maybe I can find another ribbon cable just for trying something…
                                          I’ve never used the </> button, only knew about the ‘’’ 😀👍
                                          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @Eken
                                            @eken
                                            Did you check to be sure there was no continuity from power in (positive or negative) to the metal plate?
