    Motors doesn't work on drives from Duex 5
    899
    • fcwiltundefined
      fcwilt @Eken
      @eken
      Well you must have used it since the file is display correctly.
      Clicking on the </> icon enters three lines of characters used for pasting code into a post. I've reached the point where I just type in the needed characters (two sets of 3 ` characters).
      • fcwiltundefined
        fcwilt @Eken
        @eken
        I don't see anything odd in the file.
        It looks like the boards are mounted to a metal plate. If so, did you check for any shorts to the plate.
        If not at this point I think you need to get @dc42 involved - you may have a defective board or ribbon cable.
        Ekenundefined 1 Reply Last reply Reply Quote 0
        • Ekenundefined
          Eken @fcwilt
          @fcwilt
          Ok, thanks a lot for your time and effort!
          The board is mounted on brass extenders for PC motherboards, extra tall so there should be enough clearance.
          Hmm maybe I can find another ribbon cable just for trying something…
          I’ve never used the </> button, only knew about the ‘’’ 😀👍
          I'm not stupid, I'm just unlucky when I try figuring it out.
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Eken
            @eken
            Did you check to be sure there was no continuity from power in (positive or negative) to the metal plate?
            • Ekenundefined
              Eken @fcwilt
              @fcwilt
              Yes, nothing there.
              0V
              0.L ohm
              Have measured at multiple locations (+/- on Duet, Duex and PSU)
                Phaedrux Moderator @Eken
                @eken said in Motors doesn't work on drives from Duex 5:
                Does the ribbon cable have continuity on all it's pins?
                Ekenundefined 1 Reply Last reply Reply Quote 1
                • Ekenundefined
                  Eken @Phaedrux
                  @phaedrux
                  Yes it has.
                  So I didn’t bother looking for another cable to try with.
                    @phaedrux
                    This is a "new" Duex, ordered it 13 months ago and installed it this week.
                    When and where was the Duex purchased?
                    • Ekenundefined
                      Eken @Phaedrux
                      @phaedrux
                      End of 11/2 2021, RepRapPro.me
                        It would be out of warranty, but seeing as it hasn't been used until now, and the issue seems to be that the Duex is not being detected at all, I think we should cover it under warranty.
                        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                        Ekenundefined 2 Replies Last reply Reply Quote 0
                        • Ekenundefined
                          Eken @Phaedrux
                          @phaedrux
                          Thanks for the reply!
                          I’ve sent an email now.
                          • Ekenundefined
                            Eken @Phaedrux
                            @phaedrux
                            Recieved my new Duex yesterday and work out just great now!
                            Now I'm off to get use of some 3-point-independent-z-motor-super-mega-heavy-duty-auto-bed-leveling 🙂
                            Thanks for your help and thanks to Duet-team and reprappro.me for the quick handling of the warranty case!
                              Glad you're up and running now.
                              • Phaedruxundefined Phaedrux has marked this topic as solved
