    Alfawise U10 conversation
    My Duet controlled machine
    401
    • Perttiundefined
      Pertti
      Hi friends!
      I have an Alfawise U10 which has been waiting for duet wifi some time. The time has come now. Suddenly the original knob got stuck indicating that it was time to change the motherboard to duet wifi. The board fits the box ok, the endstops need to be wired so that they are "on" instead being "off".
      The Alfawise power supply gives 12.4 volts and the heat bed resistance is 0.6 ohms.
      Now the problem I faced was the heating of the bed and the nozzle:
      Error: Heater 0 fault: temperature rising much more slowly than the expected 1.8°C/sec
      T0
      Error: Heater 1 fault: temperature rising much more slowly than the expected 1.7°C/sec
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.26
      I ran the pid tuning but it did not help. Any suggestions what to do next?
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
      • alankilianundefined
        alankilian @Pertti
        @pertti
        If you post the PID values for both heaters it will help others help you.
        Perttiundefined 1 Reply Last reply Reply Quote 0
        • Perttiundefined
          Pertti @alankilian
          @alankilian
          ok, I try M303 T0 S205
          "Failed to get file list
          Directory 0:/macros/ not found"
          Is that ok?
          Warning: Auto tune of heater 1 failed due to bad curve fit (R=1.782, 1/C=0.0050:0.0049, D=9.8)
          M303 H0 S60:
          Pertti
            alankilian @Pertti
            @pertti
            Well something is wrong.
            Let's go back to the basics. Please post the following:
            • config.g
            • config-overrides.g
            • M98 P"config.g"
            THIS PAGE shows how to tune the heater models.
            Also, THIS PAGE shows a step-by-step tuning process.
            If you can post the console output while each step is running as shows in the example it will also help.
            Perttiundefined 1 Reply Last reply Reply Quote 1
            • Perttiundefined
              Pertti @alankilian
              @alankilian
              I updated firmware 3.3
              • hotend works fine now
              • bed doesn´t. Error: Heater 0 fault: temperature rising much more slowly than the expected 1.4°C/sec
                config-overrides.g :not found
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                config.g:
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
              M550 P"Alfawise U10" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
              M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X400 Y400 Z500 S0 ; set axis maxima
              M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              Pertti
                alankilian @Pertti
                @pertti
                Since there's no file config-override.g and there's no M501 in your config.g it looks like you tuned your heaters but forgot to save the tuning parameters and forgot to add the code to load them back when rebooting.
                Follow the step-by-step sequence on THIS page to tune, save and load the tuning parameters.
                • Perttiundefined
                  Pertti
                  @alankilian
                  I got results after hours of tuning:
                  M307 H0 B0 R0.086 C686.8 D1.84 S1.00 V12.5
                  Bed seems to heat up now.
                  I have an impression that RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15) solved the problem.
                  Many thanks!
                  Pertti
                  • dc42undefined dc42 marked this topic as a question
                  • dc42undefined dc42 has marked this topic as solved
                    alankilian @Pertti
                    @pertti
                    Excellent.
                    I'm glad you got it working.
                    Post a picture of something you print sometime.
                    I'd love to see something.
                    • Perttiundefined
                      Pertti @alankilian
                      Now printing chain links. A terrain model for modular building modules lies in front of the printer.
                      BTW I have no idea what is a reasonable max speed and acceleration for this kind of configuration.
                      And is there something else I could implement here?
                      Z-Probe and 2 end stops for z axis could be nice. My custom toolchanger has end stop stall detection, why not here?
                      Pertti
