    Faulty Toolboard 1LC V1.1?
    1.5k
    • MartinNYHCundefined
      MartinNYHC @dc42
      @dc42 It measures 0.9 ohms.
        dc42 administrators @MartinNYHC
        @martinnyhc, please can you install just the tool board firmware (not the other binaries) from https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 and then get a M122 report from that board. I've added extra diagnostics so that I can tell whether it is a tolerance issue or a fault.
          MartinNYHC
          31/07/2021, 20:59:38 	M122 B121
          Diagnostics for board 121:
          Duet TOOL1LC firmware version 3.4beta1+ (2021-07-31 19:12:33)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
          Never used RAM 2592, free system stack 2789 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.0%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.1%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
          Last reset 00:01:13 ago, cause: power up
          Last software reset data not available
          Driver 0: position 0, 760.2 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 36493, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter 1/4, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
          VIN: 24.0V
          MCU temperature: min 31.7C, current 35.6C, max 35.6C
          Ticks since heat task active 39, ADC conversions started 73034, completed 73033, timed out 0, errs 0
          Last sensors broadcast 0x00000002 found 1 44 ticks ago, loop time 0, Vref 42954 Vssa 41196
          CAN messages queued 451, send timeouts 0, received 528, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          Accelerometer detected: yes, status: 00
          I2C bus errors 0, naks 0, other errors 0
          But still the same heater error.
            @martinnyhc thanks, from your M122 report I can see that your tool board is definitely faulty. Looks like either the green PTC fuse isn't properly soldered, or resistor R47 next to it isn't properly soldered. Warranty replacement.
              MartinNYHC
              If you say that 😊 Sent an email as you suggested.
                A Former User @MartinNYHC
                @martinnyhc
                I think I have the same problem.
                Can you please help me
                Cheers Richard
                  Phaedrux Moderator @A Former User
                  @gruna-studio I suggest you start your own new thread with your issue and include as much information as possible. Posting to other peoples threads saying you have the same problem is not a productive way to troubleshoot.
                    A Former User
                    @phaedrux
                    Already done 2 days ago, no one has replied. 😕
                    Problem solved by chaning toolboard...
                    thanks
                      @gruna-studio This one? https://forum.duet3d.com/topic/27666/tool-not-picking-up?_=1646967812005 I think I missed it.
                        A Former User @Phaedrux
                        @phaedrux yes 🙂
                        No worries
                        I can imagine there is lots of work
