    Faulty Toolboard 1LC V1.1?
    1.5k
    • tecnoundefined
      tecno @MartinNYHC
      @martinnyhc
      Looking at the picture there is no CAN terminator or is there?
      MartinNYHCundefined 1 Reply Last reply Reply Quote 0
      • MartinNYHCundefined
        MartinNYHC @tecno
        @tecno said in Faulty Toolboard 1LC V1.1?:
        terminator
        It is, but on the back 😉
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @MartinNYHC
          @martinnyhc
          OK, just checking 👍
            dc42 administrators @MartinNYHC
            @martinnyhc said in Faulty Toolboard 1LC V1.1?:
            😥 Will do so. Thanks for our support.
            No problem, I'm sorry for the inconvenience.
            Note to warranty processing: check F1 R32 R36 R47
              MartinNYHC @dc42
              @dc42 said in Faulty Toolboard 1LC V1.1?:
              Sorry, but what does that mean?
              T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                T3P3Tony administrators @MartinNYHC
                @martinnyhc Just @dc42 letting us know things that should be tested on the board. Please email warranty@duet3d.com. with this thread and we will take it from there.
                  That was for us, so that whoever checks your board knows what to look at.
                  However, there is a possibility that we may not need to replace your board. We made a change to the version 1.1 board that affects the Vssa reading a little, and I forgot to adjust the firmware accordingly. So your board might be close to the tolerance limit, allowing it to pass our test procedure but fail in your environment.
                  Do you have a multimeter? if so, then with power off, please measure the resistance of the green polyfuse on the board. It should be just a few ohms.
                    MartinNYHC @dc42
                    @dc42 It measures 0.9 ohms.
                      @martinnyhc, please can you install just the tool board firmware (not the other binaries) from https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 and then get a M122 report from that board. I've added extra diagnostics so that I can tell whether it is a tolerance issue or a fault.
                        MartinNYHC
                        31/07/2021, 20:59:38 	M122 B121
                        Diagnostics for board 121:
                        Duet TOOL1LC firmware version 3.4beta1+ (2021-07-31 19:12:33)
                        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                        Never used RAM 2592, free system stack 2789 words
                        Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.0%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.1%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                        Last reset 00:01:13 ago, cause: power up
                        Last software reset data not available
                        Driver 0: position 0, 760.2 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 36493, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
                        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                        Peak sync jitter 1/4, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
                        VIN: 24.0V
                        MCU temperature: min 31.7C, current 35.6C, max 35.6C
                        Ticks since heat task active 39, ADC conversions started 73034, completed 73033, timed out 0, errs 0
                        Last sensors broadcast 0x00000002 found 1 44 ticks ago, loop time 0, Vref 42954 Vssa 41196
                        CAN messages queued 451, send timeouts 0, received 528, lost 0, free buffers 37, min 37, error reg 0
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                        Accelerometer detected: yes, status: 00
                        I2C bus errors 0, naks 0, other errors 0
                        But still the same heater error.
                          @martinnyhc thanks, from your M122 report I can see that your tool board is definitely faulty. Looks like either the green PTC fuse isn't properly soldered, or resistor R47 next to it isn't properly soldered. Warranty replacement.
                            MartinNYHC
                            If you say that 😊 Sent an email as you suggested.
                              A Former User @MartinNYHC
                              @martinnyhc
                              I think I have the same problem.
                              Can you please help me
                              Cheers Richard
                                Phaedrux Moderator @A Former User
                                @gruna-studio I suggest you start your own new thread with your issue and include as much information as possible. Posting to other peoples threads saying you have the same problem is not a productive way to troubleshoot.
                                  A Former User
                                  @phaedrux
                                  Already done 2 days ago, no one has replied. 😕
                                  Problem solved by chaning toolboard...
                                  thanks
                                    @gruna-studio This one? https://forum.duet3d.com/topic/27666/tool-not-picking-up?_=1646967812005 I think I missed it.
                                      A Former User @Phaedrux
                                      @phaedrux yes 🙂
                                      No worries
                                      I can imagine there is lots of work
